Question about Samsung PCK5315RX TV
Samsung PCK5315RX video problems
I have had the Samsung PCK5315RX for about 6 years. Not exactly the most reliable TV ever. About two years ago, I had to have the power supply replaced. The latest problem is that the video freezes as soon as the TV is turned on. The audio is fine but the video locks into one frame that's all distorted. When I turn on PIP, the PIP window video isn't froze (the main picture is still frozen), but the picture is in black and white. It doesn't matter what the video input is; DVD, satellite, over-the-air are all the same. I saw a mention in another site's posting that it might be related to a bad color chip. I'm no TV expert so I have no idea if that is right. This started occuring around the time the power company had to replace a faulty underground power line to our house. No visible signs that the TV recieved a power surge, but I thought I wuld mention it.
    Genius:
  • 1,074 Answers
Greeting from belize i have never heard about a tv freezing only a computer or a dvd. dvr vcr.however your problem is the color chip on your circuit board it needs to be replace take it to a tech to have it replace it will cost you about $80.00 to repair.good luck.
Posted on Mar 21, 2007
SOURCE:
HELLO I BOUGHT A 60 INCH SAMSUNG SMART TV ESUN8000, 6 MONTHS AGO, AND I NOTICE THAT IT HAS 3 WHITE DOTS. WHAT CAN BE THE CAUSE OF THE PROBLEM? I BOUGHT THE TV AT BEST BUY, DO YOU THINK THAT THEY CAN H
sound like you have samsungs dlp white spots plague, which just gets worst. samsung are aware of the problem, so you need to get in touch under the warranty.
Nov 25, 2013 | Sony KDF-42WE655 Television
Composite video inputs roll vertically
Sync seperator problem, sounds like. Could be bad cable, but I rather doubt it....accordianman
Jan 31, 2008 | Samsung PCK5315RX TV
Samsung tv remote to the memorex dvd player
Go online to search for Samsung customer support and call them to see if it will be compatable.
Jan 02, 2008 | Samsung PCK5315RX TV
No video
More likely a blown lamp...accordianman
Oct 08, 2007 | Samsung PCK5315RX TV
I get no picture on samsung pck5315r TV
no picture & sound ok as sound is there means your power supply &high voltage section is ok problem is in video section 1 crt is glowing or not if not check its supply. 2 check crt base or any connector for loose 3 check supply to video & crt base(g2) 4 check for video signal is coming to video sectuon from processor ic. 5 loose print if any. hope this will help
Sep 30, 2007 | Samsung PCK5315RX TV
Red,blue,and green separating
I think it is a degaussing problem which is due to magneic effect. if you can 1 check any magnetic thing is mot close to tv. 2do not change the direction of tv while watching. 3call tech to degauss it by a coil called degaussing coil. good luck.
Sep 27, 2007 | Samsung PCK5315RX TV
Samsung PCK5315RX TV turns off
you tv problem is intermittent have a tech resolder you tv circuit.also have him check the power supply you could be having problem with the component there.probably the regulator diode or cap.good luck
Aug 01, 2007 | Samsung PCK5315RX TV
Curved horizontal lines in picture
Its Sounds like Convergence Circuit,If you take the Back off and look on the right side you should see a Board with Big black Ics Mounted beside a Large Heatsink,Mark the wires where they go and Make sure the POWER is Off Pull the Board out and Inspect the Connections from the ICS,you find Circle Breaks,They need to Be resoldered and That should fix the Set....
Jul 20, 2007 | Samsung PCK5315RX TV
Televison & Video Logo
81 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
