Question about ViewSonic N3250W Television
After powering on our unit flashes about 9 different solid colors
None of the buttons or remote will respond, nor will the picture show up when the cable is plugged in. We checked all the power and cable cords - they work fine. Also, we took it to a repair shop who wanted almost $300 for the internal-motherboard-somethin-or-other and another $100+ for labor.
Then I figured I would just get rid of it on craigslist, which I posted for $75. I am getting full offer responses and higher bids! Is there something that I am missing here? It is a broken tv! If it's a simple problem I can fix, I would like to. Any thoughts??
  • pkj88 Jan 25, 2009
    My N3250W is giving exactly same problem flashing different colors. Not responding to any buttons or remote. Still looking for solution.
Hold menu+enter+power buttons to reset the TV. See this post:
http://www.fixya.com/support/t115143-tv_just_flashes_different_colors
Posted on Nov 28, 2008
  • IamInventor May 31, 2011
    Regarding the N3250w in question?? It sure pays to recycle!! I just found this monitor yesterday at the local recycle yard. Someone tossed it away as it seems it was flashing funny colors?? Until today that is!! Thanx for the simple cure!!! What a score!!!! - JLC - www.webstarts.com/IamInventing.com
Monitor flashes different colors
Monitor has been successfully broken with fall.
Aug 31, 2017 | Samsung P2370HD 23 in. TV
Screen changes colors only
Hold the Vol+ Vol- buttons down and turn on the power switch in the back of the unit.
The screen should turn blue and some square in the middle of it.
The noisy square is actually the bios being reset.
Once the unit turns itself off, you can turn it back as usual.
Note: Some of these units require a 3 button reset.
In that case hold Vol+ Vol- and Menu at the same time while you turn the power switch on in the back of the set.
I hope it was helpful.
Jul 07, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
Monitor shows nothing on screen, power button on solid, none of other buttons respond.
plz try by removing the connector of the monitor from the back of cpu while keeping your monitor power on. if you get any message in the monitor then your monitor is ok. then open your side cover and try by resiting the ram, you have to swithch off your pc before opening your side cover. If you dont get any thing in the monitor then *********** board is having problem
Apr 13, 2009 | Computers & Internet
Lost cd player code
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Jul 31, 2008 | Audio Players & Recorders
Remote do not want to accept satellite tuner code
Jul 22, 2008 | Yamaha RX-V3800 Receiver
Iwave universal remote
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
May 24, 2008 | Philips PM435S Remote Control
Universal remote for Samsung Hitron
Cheers!
IrishDruid
May 23, 2008 | Samsung TV Remote Control
Help me..
These are the codes for an RCA tv: 0047, 0019, 0051, 0018, 0038, 0090, 0135
Cheers!
IrishDruid
May 22, 2008 | RCA Universal Remote Control
Sylvania TV does not respond to my my RCA remote control
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Cheers!
IrishDruid
Apr 28, 2008 | RCA Universal Remote Control
Unresponsive buttons
First, try unplugging the unit for a couple of hours. That should reset the internal microprocessor. If that fails, try pushing all of the buttons one at a time. If one of them is stuck, nothing will work properly. You should be able to feel the button working. Report back here with your results.
Dan
Mar 12, 2008 | Sharp XL-MP130 CD Shelf System
Televison & Video Logo
271 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
