Question about Mitsubishi VS-45609 TV
Mitsu WS48511 green curves up at bottom, down at top
It appears that the green channel (only) curves away from the top and bottom of the screen - almost like a parabola. Seems like a convergence amp (guess), but I have no idea where to start.
I took two photos to better-define the issue, which may be seen at
http://www.nulspace.com/pics/mitsu01.JPG
and
http://www.nulspace.com/pics/mitsu02.JPG.
Sorry in advance for all the reflection clutter in the screen - I've had to move the tv out onto the deck (orders from the missus).
Thanks for any and all suggestions!
  • rlacm Nov 14, 2008
    Excellent - thanks for your help. I assume these are the STK392-042 parts that I see discussed everywhere? Also assuming the resistors will show visible signs of damage (overheating, etc.) to help me know which ones to go after?
    Thanks again...
  • 905 Answers
Your going to need to get new convergence IC's to correct this problem and there may be some resistors to replace on the IC's circuit as well , most likely
hope this info is worth a fixya and if you need more help I'll be happy to help
electech
Posted on Nov 14, 2008
  • jason Nov 15, 2008
    you can type in your STK #'s at this site to see the equivalent
    on the next page will be the PDF file to open and look at its specs. (just click on the PDF box for it)
    http://nte01.nteinc.com/nte/NTExRefSemiP...$$Search?OpenForm
    ( in the box just type in stk and the numbers and click search )
    as for the resistors you will need to check them for low value as they all will not show that browning on the board, most likely in your case you wil not see that either , so testing the resistors will need to be done , but if you do find one like that then most likely there will be other low valued resistors also to replace , the safe value range is as this ( 10% above or below said value ) ( best range 5% above or below said value )
    but there may not be any bad resistors , just bad stk
    if you run into any problems , just ask me and I'll help
    electech
The top half of the screen is scrambling with wavy lines. Can this problem be fixed?
If you go into the customer menu and select convergence--instructions will appear on screen--select advanced and a grid of lines will appear.
If red or blue are skewed and will not adjust you have a convergence problem-If model ws48511 I have complete do it yourself instructions for this kind of fix.
YOU can post a photo here of what the picture looks like--I will attach one of a typical convergence problem--no two look the same but you will know if this is the problem you have.
SD TECH
Feb 17, 2010 | Mitsubishi WS48511 48" Rear Projection...
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
I have a rainbow effect on my television screen.
the deguesing is not working of your tv.or maybe you have a load speaker near the tv. take it away near the tv it damage the color of your tv set.
Nov 15, 2008 | Televison & Video
Panasonic PT-53WX54 curved bottom
its the problem of convergence in the unit that needs to be repaired
for how to repair please click the above link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Oct 06, 2008 | Panasonic PT-53WX54 53" Rear Projection...
RCA 56 inch hdwidescreen
Did you use the Automatica Convergence to try and straighten it out? If that does not help, you can manually adjust the convergence.
Jul 12, 2008 | RCA HD56W58 56" TV
When Turned on Picture curved at top and bottom
I would try soldering your convergence amp ICs. Mitsubishi has had some issues with sparse solder at the ICs Dress up the solder a bit and see if this helps. If not you will no doubt need to replace the ICs there are two of them and they cost about 10.00 each. Let me know if you need anything further.
Jan 31, 2008 | Mitsubishi WS-55809 55" Rear Projection...
WS55711 mitsubishi RPS - Dec 2002
This sounds like your convergence correction amplifiers have malfunctioned. These Integrated Circuits often burn out after a few years (STK392-110) they can be replaced with a higher version (STK392-150) However it is important to have the biasing circuitry checked to make sure nothing has burnt out as a result of the ICs malfunctioning. If you have a background in electronics you can repair this problem with very little effort, however if you do not have a background in electronics, I would suggest that you have your TV serviced by a qualified TV technician.
I hope this helps,
Thank you,
Shuttle83
Oct 15, 2007 | Mitsubishi WS-55711 55" Rear Projection...
Uh oh... the colors are curved and wacky
replace the amplifier IC chips for the convergence.  part # stk392-???  could be from 040 to 120..  90% chance that'll fix it.
Oct 08, 2007 | Panasonic PT-47WX49 47" Rear Projection...
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Screen is distorted on the top and bottom
Loose connection on convergence board, you could tapp and should go back to normal, find loose conn. and solder back.
Sep 09, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi VS-45609 TV Logo
107 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
