Question about Hotpoint RVM1425 Microwave Oven
Hotpoint RVM1425 I heated a muscle relief heat pack in the microwave. I think it's filled with sand?? After that the microwave wouldn't heat anything. I still have power and the glass plate still rotates. When I try and select a power level I get the message..power level may not be changed at this time. Also, the small fan that automatically activates when using tha microwave sounds different..a deeper roar/sound?? Any help would be greatly appreciated!! Thanks, Mark
  • Hotpoint Master
  • 9,100 Answers
The first thing I would suggest is to turn off the breaker or unplug it from the wall for a few minutes to "reset" it, then try again. If a reset doesn't fix it, I would think you may have a defective magnetron. When you heat something of very low moisture content, it can lead to microwave energy not being fully absorbed, but instead being reflected back to the magnetron. This can damage it. This is usually best left to a pro to repair. In case it might help, your owner's manual can be found online at: http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Use%20and%20Care%20Manual&SKU=RVM1425BA
Posted on Nov 21, 2006
Our microwave is not heating. When you turn it on it appears to be working, the dish rotates, the light is on, you can hear it running, it's just not heating the food. Is this repairable?
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Dec 22, 2010 | Hotpoint RVM1425 Microwave Oven
Microwave oven will not heat? Could it be a fuse. The fan makes a louder noise than before it stopped heating. One side blows hot air the other side blows cold. Not sure what to do
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Dec 15, 2010 | Hotpoint RVM1425 Microwave Oven
Wont heat, burning rubber smell, hotpoint microwave
If there is spark please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is leaking and sparking to the ground. It is quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Now keeping clear switch on , use a cup of water inside to test.
If you notice any buring smell shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is no heating the magnetron/capacitor/temperature cut off is faulty
Sep 24, 2010 | Hotpoint RVM1425 Microwave Oven
Microwave has power, but will not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
dfj
Apr 25, 2010 | Hotpoint RVM1425 Microwave Oven
MICROWAVE WILL NOT HEAT
check the door safety switches ... remove the cabinet and check the micro switchs you find involving the door with a volt/ohm meter
Nov 03, 2009 | Hotpoint RVM1425 Microwave Oven
Will not heat
heatman101
p
Oct 22, 2009 | Hotpoint RVM1425 Microwave Oven
Acceptable distance from cook top surface to microwave?
Sorry but your subject line got cut off. I'll assume you're talking about the distance from the cooktop to the top of the microwave (bottom of the cabinet to which it's mounted).
Here's how the installation instructions spec it:
  • "Make sure the bottom edge of the cabinet that will be above the microwave oven is at least 66" from the floor and 30" from the cooking surface."
So it's measured from the cooktop to the top of the microwave, not the bottom edge.
And I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
You can also download your owner's manual form the link I posted above.
Jun 25, 2009 | Hotpoint RVM1425 Microwave Oven
My hotpoint rvm1425 is not heating anything up
est the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
Thediode and capacitors can br tested. The capacitor must bealloweddischarge before testing, or you risk to get electrocuted, evenifpower is off. Capacitors can get discharged by shorting theirtwocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
Mar 07, 2009 | Hotpoint RVM1425 Microwave Oven
Will not heat product
You can but for the safety aspect I would get a qualified engineer.
If it's too expensive buy a new one, don't take the risk to save a few £/$.
Mar 21, 2008 | Hotpoint RVM1425 Microwave Oven
THE MICROWAVE DOESN'T HEAT UP?
Is the unit under warranty? If not, you can try to remove the cover and see if there is a blown fuse in the section that powers the Magnetron. How old is the unit? Typically, no heating of food, indicates a bad Magnetron (tube).
Good Luck,
- Jim
Jan 24, 2008 | Hotpoint RVM1425 Microwave Oven
Open Questions:
See all Hotpoint RVM1425 Microwave Oven Questions
Hotpoint RVM1425 Microwave Oven Logo
437 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
