Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
MAGTAG STACK WASHER
What dose 1E mean? washer want spin.
  • Anonymous Mar 17, 2014
    magtag washer want spin
  • 641 Answers
The 1E error codes relates to a lid lock failure. You should replace the lid lock switch. Good luck!
Posted on Sep 09, 2007
Washer from flashing 1E & leaking
LG Washing Machine Displaying Fault Code IE or 1E WM2016CW WATER INLET ERROR // Water not entering washing machine correctly
The manufacturer has assigned this error or fault code to indicate that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Aug 02, 2015 | LG WM2016CW Front Load Washer
I have a LG WD-1018C washer that wont spin out .. it just keep starting and stopping in about 30 second intervals ... an error code has just come up ... 1E ...can you help please ? Steve
The IE or 1E error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Feb 20, 2015 | LG Washing Machines
Pump 14292 for power washer
Water should come out the tip even if the mechine is not running if the water is on. So there for now water is flowing through the punp at all witch mean you have a problem with a restriction of water flowing through the pump . What dose it do with the engine running dose the blow out valve open and water come out there . Dose the pump spin .Is there water in the pump oil .How often do you use the mechine and is it kepted in the cold over the winter with out winterizeing it Give more information mabey i can help you but it dosn't sound to good now
May 28, 2012 | Briggs & Stratton Garden
My magtag 5000 series washer is flashing error code F21, It was in the middle of a wash cycle and now the door is locked and it won't open. How do I at least get the door open. I have unplugged the
Unplug the washer. Then plug it back in and press the button that turns it off. This should unlock the door. Same thing happened on mine and there was a kink in the drain hose. Once I unkinked the hose, unplugged it, plugged it back in, turned it off, then I was able to run a drain & spin cycle to get the water out of the load that was in the washer. I then ran a full wash cycle (they'd gotten stuck in the first drain & spin cycle of a wash) and everything seems to be fine now.
Dec 04, 2011 | Maytag Washing Machines
I keep getting the 1E code. I go into the washer and try and rearrange the load, and want to be able to restart the load but can't do that. Typically it happens when there is only about 10min. left in...
Hello there and thank you for choosing fixya
  • The error code of "IE" signifies a water inlet error. This means that your machine is not filling to the proper water level, and may be fixed by ensuring that machine's water supply is properly connected and turned on.
  • If every thing there checks out fine then the inlet valve on the machine is faulty and needs to be replaced ...
  • drain error will result in an error code of "OE." This means that your washer is not properly draining. Ensure that your drain hose is free of kinks and clean. Your filter also must be clean
    An error code of "FE" represents an overflow error. This means that the water level is too high, and the machine will start draining itself automatically.
    An error code of "E1" represents a leakage error. This means there is a leak in one of your hose connections.
Aug 04, 2011 | LG WM-2077C Front Load Washer
The washer on my double stack won't drain or spin.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Without a complete model number, I'm guessing but usually, washers have a lid lock built in that prevents the washer from draining or spinning unless the lid is closed.
If the lid lock is defective, the washer probably won't go into spin mode.
Check yours for the lock, where it attaches and replace it. It's probably not too expensive.
Oct 27, 2009 | Kenmore Washing Machines
Washer won't drain
look for blockage in hoses and pump.
Sep 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
178 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
