Question about HP Office Equipment & Supplies
I have a hp desk jet model 710c printer. I have cleaned and aligned the printer. The color red does not print. A test print will not print RED. Do you have any suggestions on what to try?
  • Asish Sharma
    Asish Sharma May 11, 2010
    Have you verified color cartridge...change to check...
    Master:
  • 638 Answers
Simple.the ink in the colour cartridge is over.usually pink and yellow mix to form red any of the 1 colour is over.just get your cartridge refilled or buy a new cartridge.the printer is absolutely perfect.
thanks.
Posted on Nov 14, 2008
LaserJet 2605dn Printer: HP Color Laser Jet 2605 printer far left side blac...
Faded prints are possible due to following reasons.
1. Fogged red mirrors inside the Laser box
2. Alignment of the Laser Box
3. Calibration Problem
4. Cleaning Problem
I will guide you with simple steps first, if this dosen't work working with laser box is little tough & time consuming, hence will describe later.
To Calibrate the colors, Press the 'Green Button' in the front panel, use the arrow keys to navigate through menu.
Select 'System Setting' by pressing the green button again, navigate using the arrow keys and select the 'Calibrate Color', select green button to select and confirm to 'Calibrate Now'. This will take few minutes.
In addition to that, to clean the paper path, select the green button and use the arrow keys and navigate thru' menu and select 'Service'. select using the green button and navigate through menu and select cleaning option. This will take few minutes.
Try printing some documents and check whether you have fixed. If you have not got the original print quality, Let know to guide you more technically.
May 17, 2010 | HP LaserJet 2605dn Printer
Print quality problem with Windows 7 and HP DeskJet3650.
You need drivers for win 7 only for the two printers you have .some of the mfg, have not got all the bugs out as yet. Im in the same boat .had to get a new model so i could print. Check windows web. site for driver 7up dates.hope this helps
Feb 25, 2010 | HP DeskJet 3650 InkJet Printer
New tri-color ink cartridge prints only red
Are the Jets clean and unobstructed? Depending on printer model, have you cleaned your print heads? Consider also it may be a defective cartridge.
Sep 09, 2017 | HP OfficeJet t65 All-In-One InkJet Printer
Red color faded and red color is mis-aligned.
Hi We've been seeing alot of the HP Color Laserjet range of laser printers coming through with a "prints lightly with red" or "red is faded" fault report, we've been able to resolve the problem mostly by cleaning the scanner. Misalignment is normally resolved therafter by calibrating the machine using its calibration function. (if it has one) Wouldnt suggest this gets tried unless one is familiar with stripping and reassembling these machines though. Hope this helps.
Mar 23, 2009 | HP Office Equipment & Supplies
Red will only print on test page.
So what you need to do is clean the cartridge from the printer toolbox..do all the three steps cleaning..(clean cartridge,prime cleaning,intermediate cleaning)..
once the cleaning is done..try to make a copy..if its still the same..change both the ink cartridge and then try to make a copy..if it resolves the issue then cartridge is defective..if it does not resolve the issue then printer is defective..
Mar 09, 2009 | HP DeskJet F380 All-In-One Printer
HP Deskjet 710c
either the cartridge ink is dried up or near to empty.or the printer settings are selected in colour and made black printing off.
Dec 10, 2008 | HP DeskJet 710c InkJet Printer
88 people viewed this question
Ben Johnson
