Question about Ruud UBHC Air Conditioner
Model #uacc 030jas - BTU/H and SEER
I have a RUUD Model model #UACC 030JAS, S/N 3528-F0589 6343 and would like to know what the BTU/H equals and the SEER
Many thanks
  • elroy_13683 Nov 29, 2008
    Many thanks, that helped me out.
    Elroy
    Sergeant:
  • 359 Answers
That is a three ton unit and most likely a 10 seer rated seer rating are posted 6 months in cool and 6 months in heat to get the number on the unit if you are more interested in heating rating of heat pumps the aher or annual heating efficiency rating is of the most importance in this category the unit posted very well
Posted on Nov 24, 2008
What is the fan motor capacitor rating for a RUDD model UACC-030JAS
For a fan motor capacitor we need to know what motor is on it. The units model will not help in this case. On the side of the out door units fan motor will be a sticker/tag with a lot of info. HP, volts,rpm.... And somewhere on that tag should be a "cap 5 uf" 7.5uf....
Most likely a 5 or 7.5. if and 370v or 440v rated. Either one is fine when it comes to the 370/440 value.
May 27, 2015 | Heating & Cooling
I have a Ruud AC model UACC-056jas serial number 3170 F1085 5657. Does anyone know the tonnage?
That would be a nominal 5 ton BTU unit or 56,000 btu....
At 12,000 btu/ton you can see that it is just a bit short of 5 ton but larger then 4 ton....actually about 4.75 ton....
heatman101
Apr 12, 2011 | Heating & Cooling
I have a Ruud Achiever ii UALA-030JAS, I want to now, how many tons is it?
In the model number the 030 stands for a nominal 30,000 btu output....at 12,000 BTU per ton that translates to approx. 2.5 tons of air conditioning with a properly matched coil.
heatman101
Nov 11, 2010 | Heating & Cooling
I have a Ruud Model # UACC-036JAS. Any idea on
Hi, yes the number you are showing me 036 indicates its a 3 ton unit. For every ton of cooling, you will have 12,000 btu's of cooling. 36 divided by 12=3 ton unit. Its showing me also its a Ruud Handler 2.0 ton which would be a Model# UACC-024JAS? If your mobel number is the one you gave me, UACC-036JAS, this is a 3 ton unit, absolutely no questions. I hope I have been of help to you. I am a licensed air conditioning / Refrigeration /Heating Contractor. Let me know if I have been of help.
Sincerely,
Shastalaker7
PS If this is a split system with the indoor air handler and condenser outdoors, both coils must be the same tonnage for it to work for you properly. You can't have a 2 ton indoor evaporator coil with a 3 ton condensing unit.
Jun 28, 2010 | Ruud Handler Air Conditioner
I have a ruud achiever 10 model upgc-030jas and a high eletric bi
I'm using a calculation of VxA=W. Assuming your system is 240 volts and total amperage of system with 15 amps, I come up with 3600 watts or 3.2KW. Because the outdoor temp was above 35 deg F, the electric heaters probably did not cyle on to frequently if at all. Your calculation sounds reasonable to me. To determine exactly how many KW your system is using, you will need to determine exactly how many volts and amps your unit is running at...both indoor and outdoor units if this is a split system.
I've included a link to a website that helps the homeowner to determine the KWh.
I hope you found this helpful and good luck in your endeavor! :-)
http://www.sci-ed-ga.org/modules/k6/elec/elec.html
Feb 26, 2010 | Heating & Cooling
Ruud UBHC Air Conditioner Logo
1,566 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
