Question about KitchenAid Refrigerators
Problem with frig
The freean came all out of my frig...how can I fix it...and put freean in it again
  • gpereyra Nov 15, 2008
    thank you for writing back...the model is two door kitchenaid about 3 years old and what happen was that I was trying to connect to water and a copper wire broke in half and a cool compressed air come out...
    thank you
    jesus
    can you tell me if I had a friend ac guy help me how would I know how much freon to put...and can I just go to home depot and buy a filter dryer and what is it by the way..thanks and yes your helping me alot...
    jesus
    Problem Solver:
  • 18 Answers
What makes you think the freon came out? How old is it? What is the model#? You need specialty tools in order to put freon back in, and you must use the correct amount.
Posted on Nov 14, 2008
  • Krames
    Krames Nov 15, 2008
    That is not good. The fridge will need to have the tube repaired, then a valve brazed on and a new filter dryer, then recharged, this will cost approx 150 -300 $ depending on the servicer. Hope this helps.
  • Krames
    Krames Nov 15, 2008
    The tube you broke is a capillary tube a metering tube for cooling,  the dryer captures any moisture and impurities in the system so not to damage the compressor or plug the capillary tube this cannot be picked up at Home Depot it must be picked up at a refrigeration parts site, and the system uses r134a if your ac is proficient he should be able to repair this no problem, the amount of freon neede is on the model # tag.
How do I fix ice build up at the back of the fridge compartment?
make sure door is closing properly,and turn temp down,or should I say up,warmer
Feb 17, 2015 | Refrigerators
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
Model 253. 54362409 boards get power but water and ice wont dispense
check the fill silonoid on the back of the frig where the water line connets to the unit.. that is the solinoid
sounds like it is clogged up.. usally happens after a few years with hard water or well water. if that fixes it try putting a inline filter before the frig to keep it from happing again.
Nov 11, 2009 | Refrigerators
Ice maker has stopped making ice. did this before, cost over $200 to fix last time. shaft that kicks ice out froze up and wouldn't release ice.
If the cubes keep sticking, they are probably too small which is caused by too little water presure to the frig. You need 30 pounds PSI to frig so make sure there is no RO system connected to it. Thaw the ice and start again.
Aug 26, 2009 | Refrigerators
The freezer door pops open when the refrigerator door closes
there was an service flash on some type of these frig's but the fix was only a small spacer on the frig door where the gasket meet the frame not a very good fix to save frustation try less force or then again try to gap the gasket a bit not too much to allow air to enter too much
Aug 19, 2009 | GE Refrigerators
Sub zero unit 501R is not staying cold.
you need to get its dial unit changed. if somehow u can fix it urself, then all the best...
Aug 17, 2009 | Now Hear This Classic Absolute Zero Main /...
Ice in frig air vent
you did just fine defrosting it but, when you put everything back in don't overpack it, leave room for the air to circulate. the heat from the bottom unit will cause enough condensation to leak down the air vent and the it will refreeze blocking your vent again
Jul 24, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Have a haier aes44b compact frig, just stopped working, any reset or simple fix ?
IS THE COMPRESSOR RUNNING?IF NOT YOU CAN PUT A 3IN1 STARTER KIT ON IT($10)TO SEE IF YOU CAN GET IT TO START AGAIN,LET ME KNOW-MIKE
Dec 06, 2008 | Refrigerators
Frig not cooling and now freezer is frosting
Val sounds like a defrost problem..go ahead and defrost your freezer again... check your evaporator drain your fan motors let let me know and I can help you Krazytech
Mar 27, 2008 | Maytag MZD2766GES Side by Side...
Frigidaire upright freezer and frig with freezer on top
it might have low volatge to compressor and burned out overload try unplugging it again wait a few hours and plug it back in it might start working good luck if it doesnt try replacing relay overload compasator they sell a kit called a 3 n 1 start kit
Aug 27, 2007 | Frigidaire 14.1 cu. ft. Upright Freezer...
Refrigerators Logo
66 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
