1993 Nissan Pathfinder Logo
Posted on Nov 14, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water pump I need to replace the water pump on my 93 nissan pathfinder. How do I get the harmonic balance wheel off? I cant get the timing belt cover till I get that wheel off. I can't get to the water pump till I get the timing belt cover off.
Gary Queen
Level 2:
Scholar:
  • Expert 85 Answers
  • Posted on Nov 14, 2008
Gary Queen
Expert
Level 2:
Scholar:
Answers
85
Questions
0
Helped
45796
Points
253
You should not have to do all that. Let me know if you dont get diagral(sometimes happens)
  1. Drain the cooling system.
CAUTION When draining the coolant, keep in mind that cats and dogs are attracted by ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old. water pump - 0900c1528018cf80.jpgFig. 1: Water pump assembly-Z24i and KA24E engines Fig. 2: View of the water pump assembly-VG30E engine
  1. Remove all drive belts.
  2. Unfasten the fan shroud securing bolts and remove the fan shroud assembly.
  3. Unfasten the water pump retaining bolts (note the different size bolts on the VG30i and VG30E engines), then remove the water pump and fan assembly, using care not to damage the radiator with the fan.
If the fan is equipped with a fluid coupling, do not tip the fan/pump assembly on its side, as the fluid will run out.
To install:
  1. Remove all traces of gasket and/or sealant from the pump-to-cover mounting surfaces. Install the water pump and tighten the M6-size mounting bolts to 3-7 ft. lbs. (4-10 Nm). Tighten the M8-size bolts to 7-12 ft. lbs. (10-16 Nm) on Z24i engines, or 12-15 ft. lbs. (16-21 Nm) on KA24E, VG30i and VG30E engines. Always use a new gasket between the pump body and its mounting.
The KA24E engine uses a liquid gasket. Carefully scrape any old gasket material from the mounting surfaces, then apply a 0.079-0.118 in. (2-3mm) continuous bead of liquid gasket around the entire mounting surface.
  1. Install the fan shroud assembly.
  2. Install the drive belt and adjust the tension.
  3. Refill and bleed the cooling system (refer to ), then start the engine and check for coolant leaks.
Feel free to reply with any questions or comments
2answers
Harmonic balancer /water pump
most water pumps I believe have a weep hole that drips out coolant basically letting the person owning the car know that it is time to change the water pump. but then again have you checked to see if the water pump hoses are secure and aren't cracked?
How do i repair oil leak
yes, you will need to remove that plat as well as the harmonic balancer. if you do not have a harmonic balancer pulley puller your local parts house should have one. you will also need a new timing belt as the old one will have been stretched if not recently, within the past few days, been installed.
1helpful
Does the harmonic balancer need to be removed to replace the water pump?
Hello mue037,
Yes, the harmonic balance pulley must be removed as well as the timing belt. The water pump is driven by the timing belt.
Regards,
netvan
How to remove the timing chain plate
Take the shroud & fan off , loosen alternator and air conditioner remove belts, remove belt pulley off face of water pump, drain radiator, remove water pump, remove belt off harmonic balancer, then pull harmonic balancer off of crank shaft, remove bolts from timing cover, and that will get you to the timing chain plate take the bolts out and remove it.
I have a 2000 nissan sentra my harmonic balance is bad according to a autozone person it moves when the car is on and he told me it needs to be replaced because it has play i need to replace and find out...
The harmonic balancer is integrated with the crankshaft pulley, and if replaced requires taking the bolt out from the side of the 4 cyl. engine.
I would recommend that an experience engine rebuilder perform the service.
Inspect the Harmonic Balancer:
The harmonic balancer (vibration damper) is inspected for signs of wear in its center bore.
  • Also inspect the rubber mounting for indications of twisting and deterioration.
  • The outer ring can slip, causing an out of balance condition. Replace any harmonic balancer that has slipped.
  • With the cylinder head removed and the piston at top dead center (TDC), make a visual comparison. Do the timing marks for TDC on the timing cover and damper appear to be accurate.
  • Be sure the damper is the correct one for the vehicle. The wrong one can be worse than none at all.
  • Sometimes a damper can become loose on the crank. Check the keyway for wear that can result from improper damper installation, the wrong size key, or a loose damper hub to crank fit.
  • Be sure all pulleys are straight. A damaged pulley can force a crankshaft to bend during engine operation.
This is a general guide on replacing the harmonic balancer, but there are other instructions that the rebuilder would follow to actually do the service for you:
To remove the harmonic balancer, the cylinder head and timing cover must be removed and the piston should be at top dead center (TDC).
  • Install the vibration damper by pounding it on, or use a special installation tool.
  • Generally, the damper is installed unit it bottoms out against the oil slinger and the timing sprocket.
  • If in doubt, install the water pump and pulley, and then pound the damper into place until its pulley aligns with the water pump pulley.
  • It is advisable to use the installation tool, because pounding on the damper can cause stress on the crank thrust bearing surface.
  • It is best to stand the engine block on end and support the crankshaft if the damper must be pounded on.
  • Some vibration dampers are not pressed-fit on the crankshaft.
  • Be sure to install a large washer behind the damper retaining bolt on these engines; otherwise, the damper might fly off, causing damage and a safety hazard.
2answers
Replacing waterpump in1999 nissan pathfinder
Water Pump Removal & Installation To Remove:
  1. Allow the engine to cool and drain the coolant from the radiator and both engine block plugs.
  2. Remove the fan shroud and both radiator hoses.
  3. Remove the drive belts.
  4. Remove the water pump pulley.
  5. Remove the crankshaft pulley.
  6. Remove the timing belt covers.
  7. Remove the water pump.
Water pump removal/installation 7924vg20.gif
To Install:
  1. Install the water pump with new gasket.
  2. Install the timing belt covers.
  3. Install the crankshaft pulley.
  4. Install the water pump pulley.
  5. Install the drive belts and fan shroud.
  6. Install the radiator hoses.
  7. Install the coolant drain plugs.
  8. Refill the cooling system.
1helpful
How do you replace the water pump on a 2001 Ford Escort ZX2?
hello there:
to replace you're water pump you will have too also do the timing belt the water pump is going to be internal you will have to remove the timing cover and remove the wheel splash guard and left front tire to be able to get to cover you will also need to remove the drive belt accessory belt the alternator possible the a/c pump and make sure you have go the number 1 cylinder top dead center on the exhaust stroke and remove the harmonic balancer to get in to the pump then you will have the do believe eight bolts to remove the water pump install in reverse.....hope this helps you out...sincerely D.Jones
1helpful
2answers
2answers
BAD HARMONIC BALANCER
this site is lame ,i just called a dealership and got the answers i needed,i got no help here
2answers
Mazda astina water pump
It most likely runs off the timing belt. check there behind the timing belt cover.
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
