Home | Ruud | 5.0 Tons 12 Seer Split Central System Air... | CHANGE OUT
Ruud 5.0 Tons 12 Seer Split Central System Air Conditioner
Problem for Ruud 5.0 Tons 12 Seer Split Central System Air Conditioner
CHANGE OUT
By www_hoskinsh on Nov 14, 2008
I HAVE A OLD RUUD PACKAGE UNIT THAT NEEDS TO BE CHANGED OUT DO YOU HAVE A REPLACEMENT UNIT THAT IS COMPAREABLE TO THE OLD ONE TO MAKE IT A QUICK SWAP? MODEL#URGG-10E60JKR
Clarification Request
Posted by hvac teacher on May 03, 2009
I do not know if I am even allowed to get you a unit through this site. Reading fixya's rules I believe that we are not permitted to give each other personal contact information. If you can ok it with fixya... i can getya, what you need.
Posted by hvac teacher on Apr 22, 2009
I would also need the serial # and unit dimensions. I do not know where you are located. I am in
N.E.Ohio. Would it be worth the shipping costs to your location.
Let me know
Hvac Teacher
Posted by hvac teacher on Apr 03, 2009
I would need a model and serial number of the old unit. Is it a side or bottom connection? In most cases a almost direct swap out should be available for most package units.
Popular Solutions for Ruud 5.0 Tons 12 Seer Split
Questions and Unsolved Problems for Ruud 5.0 Tons 12 Seer Split
Do you recommend Ruud 5.0 Tons 12 Seer Split Central System Air Conditioner?
Answer
Answer
my small tank in the loft off the central heating is boiling over?
Answer
inside unit runs for several minutes then cuts out resulting in red,yellow and green lights... (More)
Answer
when this happens i open up the unit outside & there is only one test light flassing. i have to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ruud 5.0 Tons 12 Seer Split...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
