Question about Hoover U5780-900 Windtunnel Cyclonic Bagless UprightVacuum
No pwer Vavuum died won't come back on, I have power in the plug.
  • 4 more comments
  • collinsd Dec 20, 2008
    second windtunnel just purchased and it just cuts off. power is in cord.
  • Anonymous Dec 28, 2008
    I have the same problem!! I waited several days and it still won't power on. I wonder if it has a reset switch somewhere near the motor?
  • rgrayjr Jan 01, 2009
    was vacumning when power went off. pickup tube was clogged, unplugged and waited for cool down, still won't work...Can anybody help, is there a reset button somewhere
  • mike644 Jan 09, 2009
    about 6 months old and it just stopped working. I waited 30 minutes and still nothing... will try again tomorrw, but I would highly discourage anyone from buying this vacuum. I also have a dirt devil that cost the same that sits in my garage because the beater bar loses traction even though the belt is new.
    I should've just bought the dyson, but instead I have 2 $200 vacuums that don't work :(
  • Anonymous Jan 31, 2009
    cant find reset button
  • Anonymous Feb 19, 2009
    This vacuum shuts off after 15 minutes of use and we have to wait a couple of hours before it will start up again. Thorough cleaning of filters helped a little, but didn't solve the problem.
Our Hoover U5780-900 stopped working while using the attachment. We let it cool down for about 5 minutes and it fired back up. It appears to shut down when it overheats.
Posted on Nov 18, 2008
Unplugg from wall and wait 30 minutes for the thermal protecor to cool off....
Posted on Jan 01, 2009
Vacuum died no power when I was useing it. Tried changing outlet still doesn't work.
Posted on Nov 23, 2008
My Electrolux Rapido wet&dry won't start. The battery is empty and the blue light flashes when I plug in the charger.
this sounds totally silly but is the power button on the vacuum actually off? Had the same problem, where the battery was completely empty i didn't know my son had switched the vacuum on put it on charge and the light was flashing. I took it off the charging stand pressed the power button then put it back....now charging perfectly. Anyone who doesnt have this appliance will think you sound stupid but its just a clicky button so visually the button looks the same on or off.
Apr 04, 2013 | Electrolux Zb4106wd Rapido Wet And Dry...
My kirby G6 2000 no pwer
More than likely you have a short in your power cord. however if you want to know for sure take machine apart until you can put an elec meter on switch where cord is attached. plug machine in and test the end of cord that is attached to switch if you have 120volts at that point its your switch thats bad. if you have no voltage or anything less than 110volts at the switch replace cord
Jan 14, 2013 | Kirby Ultimate G Bagged Upright Vacuum
I have a brand new KitchenAid mixer that is 5 years old and never used. I unpacked it this morning and it won't turn on, no noise, no movement, nothing. Help.
Please check manually the motor and see if it moves freely. Now make sure that the power plug and the connections to the switch are not tampered , check the continuity of the plug to the switch and to the motors.
If you notice any dirt or insects make sure that this has not clogged on the motor. If so clean using a degreasing spray- WD40- would be recommended.
If the motor is tight , lightly oil or degrease using the spray while manually rotating.
Once this is done connect the power while taking all precaution. Use the meter to check the flow of the circuit to the switch and to the motor. If there is a trip switch see that it is reset.
If there is power to the motor and still it does not work the brushes might be dirty and might need a cleaning/ reset.
Jul 07, 2011 | Vacuums
Cuisanart 10 c programmable coffeemaker won't work; no light comes on & it is plugged in. It has been working fine.
Check it's fuse inside, a blown or open fuse will cause won't work. Similar also happened if the cord wire is already open. Same goes also if the power switch is already defective. Either of those I mentioned will cause the unit not to work.
Thanks for asking.
Jun 25, 2011 | Vacuums
There is no power...seems like a motor problem. The bag is clean...the mouth is clean the plug us in...NOTHING! I took mouth off and manipulated/pushed in that power press area that engages the motor on...
The front safety switch must be pushed in by either the hose or head (or manually), before the on/off switch will operate. The most common reason for no power is a bad cord. Second most common is worn carbons in the motor, and third is a bad switch.
Dec 25, 2010 | Kirby G4 Bagged Upright Vacuum
Why wont the self propelled brush on the hoover wind tunnel work. large belt is ok. the small belt looks 0k.
no don't do that,have a little patience.check where the self propelled assembly is and see if anything got in there,something might be loose and the teeth are meeting each other.thats a good vavuum.i have 2 but their not self propelled.try taking the belt off the self propelled machanisn and try it again.if it works then something is keeping the propelled machanism from working.dig a little deeper,what do you have to lose?
Mar 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover power drive vacuum cleaner simply shut off and died
my hoover vacuum is very hard to push forward but easier coming back.Any help will do.
Jan 24, 2009 | Hoover U6311-930 Power Drive Bagged...
My hoover power drive vacuum simply died. It just shut off. I checked the plug, etc...I just can't get any power...Can you help?
If no light or motor sound cord is probably bad. Look near AC plug or just replace the plug end. Check with ohmmeter for continuity with switch ON.
Eureka 5892AVZ Bagless Upright Vacuum has become extremely noisy
This link will give you a copy of the owners manual that will help you some
http://www.eureka.com/service/manuals/80244.pdf
Hope this helps. biigg53566
Dec 06, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Hoover U5780-900 Windtunnel Cyclonic Bagless UprightVacuum Logo
555 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
