Question about Palm TX Handheld
Palm TX: Digitizer problems - can't use all functions; i.e.all those on bottom row of screen. Soft reset and touch-screen alinement exercise doesn't seem to work.
  • 2 more comments
  • mherz Dec 01, 2008
    In general, the digitizer works fine. But at the very bottom of the screen, the touch registers about 1/4" high. So all the icons along the bottom are inaccessible; tapping on them instead registers as a tap on whatever is just above them. Anywhere else on the screen, a tap is entirely precise.
  • RealtyPro Dec 06, 2008
    I have the same problem. Now how do I repair it?
  • mcracman Jan 19, 2009
    After an endless looping restart and having to hard reboot the device, it came back, I restore data from computer and restart; then everything came except the inferior part of the digitizer. No icons nor place to write the graffitti
  • Franistan Feb 17, 2009
    I have this same problem -- not only the bottom 1/4" of screen, but also the rightmost 1/4", when I'm in screen rotate mode is nearly unaccessible. The vast majority of the screen is accessible, but as I near these edges, I'm unable to reach that edge.
    I followed dssails advice, a little dubiously at first, and that did work for me; we'll see if it drifts. I simply recalibrated the digitizer, but tapped the targets biased to the center of the screen (i.e. not the bullseye of the target, but two rings inward closer to the center of the screen.) I did this for the lower right target and the upper left target, then tapped bullseye in the center. I'm working fine now.
I developed the same problem after owning my TX for about a year and a half. I found an acceptable solution by experimenting with the digitizer. Instead of tapping the very center of the bullseye, I tapped off center until I found an acceptable setting where accessing functions anywhere on the screen would work for me.
Posted on Dec 02, 2008
Calibrating touch screen never ends. just keeps on displaying targets, I just keep tapping
The Palm TX is notorious for digitizer failure which is what it sounds like you have. The are 3rd party solutions such as power digi which you can google. However it seems that the best method will be to replace the digitizer with a glass one. The plastic digitizer that Palm originally installed is not very reliable over time. There is a seller on e-bay that specializes in this and other Palm repairs. I believe it's called itsnotthere. You can also try to do it yourself. There are numerous demos on the internet that show how to do this if you are handy. Hope this helps.
jazzkatz
Aug 14, 2009 | Palm TX Handheld
BOTTOM OF SCREEN NOT WORKING,
This happens a lot with Palm digitizers. The only permanent solution is replace the plastic digitizer with an upgraded glass type. Before considering that, see if removing screen protector helps. (yeah, didn't think so. Worth a try!) Try Powerdigi, a better calibration program. Get it from http://www.palmpowerups.com
It worked for me.
Jul 03, 2009 | Palm TX Handheld
Touch screen problem
Digitizer is out. Take to a cell phone store to have replaced but be prepared to pay out the nose
Jul 03, 2009 | Palm Treo 700p Smartphone
My TX's Top Left quadrant of the touch screen has lost "sensitivity" but generally the whole screen is out of calibration.
have you tried using the built in calibration function on your phone? calibrate it again and again untill you can touch each point just once. if this doesnt work you may have damaged that part of the digitizer and you will have to replace the screen.
Jun 12, 2009 | Palm TX Handheld
Palm T/X touch pad not responding
pls reset the device like this and then align it
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=7125,E=0000000000337448967,K=6865,Sxi=8,case=obj(887)#hard
if problem persists then yes u are gettin screen alignment problem bcoz of digitizer fault it is faulty u want to do it then go to below link
buy the digitizer and change it urself see the video
http://www.gethightech.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=PA1693&Category_Code=_TUNG
PLS RATE ME FIXYA FOR THE HELP
Mar 20, 2009 | Palm TX Handheld
Palm Tungsten E/E2 digitizer - fragile?
Palm one is in trouble because of problems like this. They don't work on it but you can buy parts to try it yourself. I never had the problem myself but similar conditions. I do windows based units now.
Dec 30, 2008 | Palm Tungsten E2 Handheld
Cannot top the bottom of the screen
It is an issue with the Grafitti  on the device, you can try a Hard reset on the device.
Dec 24, 2008 | Palm TX Handheld
Palm tx
This has some suggestions for the TX digitizer issues
http://palmdiscovery.netfirms.com/nfblog/2005/11/29/palm-problems-pt-2-digitizer-fixes/
Jan 06, 2008 | Palm TX Handheld
Touch Screen does not work at all
My touchscreen was acting batty, not responding where I was touching. The solution for me was to:
1. remove my screen protector
2. Take a piece of paper, fold it in half, and scoop under the lip the case where it holds the touchscreen in to fish out debris that were distorting how the digitizer recorded.
Nov 14, 2007 | Palm TX Handheld
Touch screen
Its a digitizer problem...If you want to know how to fix it read this article....Save some good money you can fix it yourself!
http://theopoon.rinnovative.com/cgi-bin/viewpost.cgi?p=20060308081647
Oct 13, 2007 | Palm Z22 Handheld
Palm TX Handheld Logo
837 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
