Question about Pioneer SD-533HD5 53" Rear Projection HDTV
Flashing Green Our HDTV Projection SD 533HD5 has recently started to flash green colour overlay on the screen - it is like the colour settings can not stabilize and are adjusting constantly. Think of your really old tv where instead of static, the colours constantly changed. How do I fix this?
I would guess that your problem is similiar to mine but mine is with the color red. The CRT went out which is a 400 dollar part and who knows how hard to fix.
Posted on Jan 11, 2007
Pioneer SD-533HD5 53 in. Rear Projection HDTV Television - Need Manual ....
ManualsLib has the manual for the SD-533HD5 here: https://www.manualslib.com/manual/384249/Pioneer-Sd-643hd5.html . (The manual covers two models.) Once you modify the picture parameters (starting from STD, REF THEATER, GAME), these are stored as the User mode. If you press Menu when done changing the parameters, that input should maintain the User settings for the last setting until you change the Picture type. If you modified the parameters for STD and then return to that input and change the Picture to GAME, any modifications to the GAME picture parameters will become the new User Mode. See page 50 of the manual for the details: https://www.manualslib.com/manual/384249/Pioneer-Sd-643hd5.html?page=50#manual .
I hope this helps.
May 27, 2017 | Pioneer SD-533HD5 53" Rear Projection HDTV
How do i switch my sd-533hd5 to hdtv
the only way to do this is u most upgrade ur cable box to hd box then connected to a component with the color green blue and red on the back of ur tv
Nov 03, 2010 | Pioneer SD-533HD5 53" Rear Projection HDTV
When I turn on the sd-533hd5 the picture has a green hue until it warms up. This can take 5-10 min. Mark
Hi,thats sounds like its the green tube override may need to replaced, or the green circuit drive transistor defective;
that is all i can say from here,may be maked check by a technician?
hope that give an idea about the problem
regards Alan
Oct 20, 2010 | Pioneer SD-533HD5 53" Rear Projection HDTV
My sd-533hd5 53in.the colors will divide into the blue green and red. then blow a fuse ?
from what i have had in the past was with this problem was convergence problems but it seems to be something originating from your main board.
Nov 06, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
Screen flashes green a couple times then shuts off
you need a new green CRT. The lines were retrace lines which are the first sign of a tube developing a short eventually the green will short completely and cause the set to shutdown.
Feb 04, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
My television has a green tint to the picture...help
go into the tv picture settings and there should be an option for colors and try turning the green down, sorry its not an exact solution but i dont own one so just trying to help
Dec 30, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer sd-533hd5, STKs changed, getting blue screen but not pict
Did you have double image before changing the stk's ? If not then there was no need to change them.. Pioneers are known for bad solder connections especially in the power supply section.. suggest checking that when you changed the stk's that there are no solder bridges between the pins of either stk ICs
Dec 22, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
89 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
