Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Top load whirlpool washer
how do I remove the top of the washer
    Genius:
  • 1,028 Answers
You don't remove the 2 screws on rear of console lift and roll console back remove 2 brass colored clips on eack corner remove lid switch plug pull cabinet forward and off
Posted on Nov 15, 2008
How do I take off the top of my washer?
Whirlpool/Kenmore Top-Load Washer Disassembly - YouTube
? 4:08
https://www.youtube.com/watch?v=j8_TzloPCwY
Dec 6, 2012 - Uploaded by RepairClinic.com
Repairing a Whirlpool/Kenmore top-loading direct drive washer? ... Whirlpool Washer Repair & Diagnostic ...
Whirlpool / Kenmore Washer - How to Remove the Outer ...
? 1:49
https://www.youtube.com/watch?v=vogysB7XOc8
Jul 14, 2008 - Uploaded by Bill Newberry
This video shows you how to remove the cabinet on a Whirlpool, Kenmore or ... Whirlpool/Kenmore Top-Load ...
Dec 15, 2015 | Washing Machines
How to take top off whirlpool cabrio washer top load
remove about 6 or so screws on the back (top) then slide the top forward about a 1/2 inch then lift.
Jul 22, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
My LTE5243D top load stacked washer is about 10 years old. How do you take the front panel off to access the washer's motor coupling?
To gain access to the washer components, the front panel between washer and dryer must be removed first.
Remove the two top screws securing thethis panel to the unit.Tilt the transition panel down and pull itstraight out.Remove the two screws located behind the washer top.Pull the washer top forward to disengage the top locks. Disconnect the washer lid switch harness. Lift the washer top off the unit.Remove the two screws from inside the top of the washer front panel.Lift up on the front panel to release the catches near the bottom of the panel andremove the front panel.
Apr 24, 2012 | Whirlpool LTE5243D Top Load Stacked...
How do you remove the back from a kenmore top loader washer
Assuming that this is a basic top load, direct drive machine, you seldom need to remove the back.
See the following for how to release the console and pull the cabinet.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=0da65cea0e338fe930b1fde153a243f0
And,see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Also see the Whirlpool / Kenmore Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Dec 18, 2010 | Kenmore 24032\24036 Top Load Washer
Replacing water inlet valve for Whirlpool Duet
Thats a two man job that you are trying to do yourself. The top of the washer has to be removed to replace the valve. Get some help to remove the dryer from the top.
Mar 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washing machine spins but does not aggitate what do i need to do?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Also see the Whirlpool / Kenmore installation and operations manual for top load direct drive washers.
Also look at the Whirlpool parts list for top load direct drive commercial washers (the consumer model is basically the same.)
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
The Whirlpool / Kenmore top load direct drive washer uses an agitate shaft from the transmission with splines on its' top that fit into slots in the agitator. If the slots in the agitator are damaged / worn, the washer may not agitate.
Remove the fabric softener dispenser, remove the top agitator cap (a short screwdriver works well), and you'll see a 1/2" square drive bolt. Use a 1/2" socket extension to remove the bolt, pull up on the top agitator and carefully turn it over. You should see four plastic "dogs" that allow the top agitator to turn one way only. If they are worn, they are easily replaced.
After removing the top agitator, you should see a bolt (I think it's 5/8").
Carefully remove the bolt and the rubber washer under it and the main agitator should come off. You'll see the top of the transmission agitator shaft with it's splines. Check them and the slots inside the main agitator.
If the splines on the transmission agitator and main agitator are OK, the washer spins and drains and the timer moves through its' cycle, the problem points to an agitate gear in the transmission itself.
See the parts PDF for the transmission.
Replacing the gear in the transmission is a bit complicated (and messy) but it's a lot less expensive than a $170 transmission.
If you decide that you want to work on the transmission (it's not really that hard) post another question on Fixya and I or someone else should be able to walk you through it.
Oct 09, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool top-loader LSQ9200LQ0
Im no expert, just pretty handy with all things mechanical...hope this helps:
http://www.appliance-parts-warehouse.com/whirlpool-parts/Whirlpool-Washing-Machine-Parts/Whirlpool-Parts-LSQ9200LQ0/Whirlpool-Parts-82574.cfm
Jan 26, 2009 | Whirlpool LXR9445JT Top Load Washer
Clothes mover of whirlpool top-loading washer is loose. Agitates.
You need to replace the agitator dogs inside the clothes mover (agitator). take of the top then the cover, remove th bolt and take the top half off. you should see four "dogs" that need to be replaced.
Jan 25, 2009 | Whirlpool LSQ9600L Top Load Washer
Remove top from Kenmore 101.24722300 washer
rberliner The complete instructions you can find here: http://www.askgene.com/2007/01/26/whirlpool-kenmore-washer-direct-drive/how-to-remove-the-cabinet-on-whirlpool-direct-drive-washer-2/ Gendos...post back
Feb 20, 2007 | Kenmore 24722 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
156 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
