Question about Pioneer HTD-520DV System
Picture darkens slowly, dissapears, then re-appears only to darken again
The picture keeps fading in and out. The image will get darker and darker, then the blue screen will turn on, although I can still hear the sound, but it is quiet. The image will re-appear again a minute later, and repeat the cycle over and over again. I have tried different inputs on the tv, but nothing seems to work. Do you think the cables themselves are bad, or is the unit toast???? Thanks so much, Shelley
snakehead
  • 1074 Answers
SOURCE: Pioneer PRO-510HD Elite
since your tv is 6yrs old it could be that the video circuit has cold solder that needs to be resolder if that does not work then a focus on the video circuit by replacing the component there, it could be an ic or transistors or diode.if you are not a tech get one to look at your set.good luck.for further help email me at nicodhem@yahoo.com
Posted on Apr 06, 2007
ice man
  • 68 Answers
SOURCE: sound 'changes' when using different input sources
try to check the auidio setting on the dvd itself. make sure it is set to 6.1. I think it is set for 2.1..change the setting and you will be just fine. good luck
Posted on Apr 08, 2007
  • 1153 Answers
SOURCE: please help
Could also be the cable, set are now designed if no signal to shutdown, so first check media box by calling cable company and or replace and try another just to make sure.
Posted on Aug 27, 2007
SOURCE: To fix the pitch black screen
just take the positive cable off your battery and that will reset in to the factory settings and that should fix it
Posted on May 13, 2009
tvservice306
  • 458 Answers
SOURCE: Pioneer PDP-RX06XE has no picture
check PDP 436XPE UNIT may be Y board short...or need factory restore to the original state....
Posted on Nov 18, 2009
Copy darker
go into the menu and look for copy/print settings. you should see an option to lighten or darken the copy. It should look like a ascending /descending slider. tap to the left for lighter or to the right for darker
Nov 27, 2013 | HP Officejet 5610 All-In-One InkJet...
Why is my picture darker than normal
It may be the backlighting has been readjusted by someone other yourself. Whenever you go on battery, I'm sure you've seen the screen darken a bit. This is the backlighting being turned down to save battery life. There is usually a blue function "fn" key that allows the user to brighten or darken the display. Look at the blue icons in the F1-F12 keys. The one to brighten the display looks light a sun and the one to darken the display looks a full moon eclipsed. Press and hold the fn key and tap the desired function key to brighten or darken the display.
Jan 13, 2012 | Toshiba Computers & Internet
We purchased a Samsung LN46C630 less than a year ago. Within four months we noticed that the speakers would fade away and return at sporadic intervals, some quite long. Since then it seems to getting...
THE PANEL THAT DARKENS IS A DEFECTIVE PANEL TRY LIGHT PRYING TWO OPPOSED DIAGONAL CONERS OF THE TV WILL ITS DARK IF YOU MANADGE TO GHANGE THE IMAGE QUALITY PANEL IS DEFECT FOR AUDIO EITHER ITS THE SOURCE THE MAIN BOARD OR SPEAKERS
Mar 27, 2011 | Samsung LN46C630 TV
Hannspree HF 257 25'' monitor only stays on fo a few seconds and then gradually fades to black, another monitor works fine so the computer is not the problem. The computer was just moved to a new...
Is the power light staying on or does that go out as well?
If the power light stays on and if you darken the room, can you see a faint image still on the screen by shining a flashlight at it (close). If there is a faint image it is either the inverter or the backlight tube.
JC
Jan 31, 2010 | Hannspree HH251H 25" LCD Monitor
PICTURE SUDDENLY DARKENED AND IS FADING AFTER 4 DAYS
you may have just put it into fade out. find thee fade out control and reverse it the mode. hope that works.
DFD
Apr 11, 2009 | Televison & Video
Darken print
Read your instruction book its all in there.
We all need to learn how to do these things but sometimes its best just to sit down a read the book for 1 hour or so.
Anyway to make a document or photo print darker;
Go into Printer preferences
Effects
Check the box; Simulate illustration
Then move the contract bar to you setting you require
You have other option in the as well such as;
Vivid photo
Image optimizer
Photo Optimizer pro
Photo Noise Reduction
Jan 26, 2008 | Canon PIXMA MX310 All-In-One Printer
Screen darkening from right side
1 lool
change lcd panel ok
Jan 19, 2008 | Lenovo ThinkPad R51
Logitech webcam
in my view the hardware ciruit (IC) may develop heat that make this problem, change IC
Dec 26, 2007 | Logitech Webcam
Faint screen image
when you first power on using lower right (power) button, wait 6 seconds for the intro screen to finish. The upper left (up) button increases screen contrast. Hold this one down for a few seconds and the screen should darken. The middle left (down) button decreases contrast.
If this doesn't work, try turning off by holding the power button.
Hold down upper left AND upper right while turning unit on. This initiates diagnostic mode and contrast is darker by default. Bottom of screen is a button test area which darkens a symbol for each successful button press. Use it to diagnose a button problem. Turn off power and on again to leave diagnostic mode.
I wish you success playing with the Etrex.
Dec 07, 2007 | Garmin eTrex GPS Receiver
Sony warms up - picture slowly becomes dark
You are losing screen voltage or whats called the boast voltage most likely. This is probably being caused by a bad capacitor in the sweep power supply. You will need to get a service manual as well as use an ESR type capacitor meter to find the bad capacitor(s). Good Luck
Jun 05, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Pioneer HTD-520DV System Logo
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
