Question about Sony DAV-SA30 System
After a while the system starts crackling and eventually sound deteriorates to thundering in speakers
I have had the system for about 2 years. Just recently it has started crackling across all the TV and video channels sometimes as soon as it is swithed on but sometimes the problem comes on after a number of hours. It has been intermitant for about 4 months but has now got progressively worse. It now happens every time. It starts by a bit of faint popping across all the speakers then gets worse by crackling in time with the broadcasted sound until over a minute or two it becomes so distorted that the speakers seem to just thunder. Sometimes switching the function channels is enough to clear it but this can some times lead to total loss of all sound. Otherwise I just switch it off for a while. I have unplugged and replugged all the connections, moved the system away from the other TV devices and changed the scart connections from my other TV. Any ideas?
Hi, I have exactly the same prob and I belive that it is in the amp module?! I am going to take mine in for repair as my other sony HT amp has just give up the ghost, (STR-DE435), it has a protector prob and is probably not worth repairing, although it is a great amp. If anyone knows the solution to this prob it would be great to hear it!!!
Posted on Jan 05, 2007
I have a SAmsung HTZ310R home cimema system and recently been experiencing audio drop out. I stream movies from my PS3, and play BD's, watch DVD's. Havent had any issues until recently, when sound started...
Sounds like a couple of coincidental but unrelated symptoms.
Optical cables need precise seating and no tight bends.
Muffled, channel-specific sound is usually on the analog end. Speaker connections maybe.
Mar 17, 2010 | Audio Players & Recorders
Turned HK3470 system on and as soon as sound is
Look for shorts across the speaker terminals, too. If you have an ohmmeter, turn the receiver off, disconnect the speaker cables and measure across the output terminals for shorts.
Feb 14, 2010 | Harman Kardon HK 3470 2 Channels Receiver
Toshiba 42H81 speaker crackle
It could be the board or the speakers itself.
Check see if ur air tv have any crackles?
If not u can rule it out the speakers.
Tries it with diffrent cables,see what happen.
The prob.still there it ur electronic board.
Aug 27, 2009 | Toshiba 42H81 42" Rear Projection...
2 y/ old Samsung DLP TV (HLR6167) - no sound
your problem is most likely not the Tv i bet you are using an air antenna arent you
Feb 16, 2018 | Samsung HL-R6167W 61" HDTV
I have a Behringer MX8000A mixing desk. It has worked fine for a few years, but recently it's started playing up. After a varying amount of time (sometimes as soon as you turn it on, sometimes 10-20minutes...
To solve this problem ,replace voltage regulators for +18 and -18 volts with lm338. these have a higher current rating and are directly replacable.
Tech
Jun 21, 2008 | Audio Players & Recorders
Akai model lct2721ad. tv.
Mine does this all the time. It appears to be a factory flaw. The only way around it is to set the channel you are watching to "MONO" and the crackling sound will disappear.
May 11, 2008 | Akai LCT2721AD 27 in. LCD Television
RCA 32V550TYX1 - sound and picture crackle and pop.
Dust does cause some problems but not this mabe bad audio ic or bad speakers or capacitor near audio ic or bad tuner could cause this sorry for so many suggestions I oun a video repair shop i gave you all the things it could be
Thanks Doctor video
Nov 12, 2007 | RCA 32V550T 32" TV
My speakers have almost constant crackling noises
Hello, there is no chance that you can fix this problem by replacing speaker wires. Resoldering the output stages as well as area around the microprocesor could be the efficient solution. If you need more info please advice.
Apr 12, 2007 | Sony DAV-BC150 System
Sony DAV-SA30 System Logo
302 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
