Question about Kenmore 24032\24036 Top Load Washer
800 series , pomp and spinning is ok but whashing not working
The machine gets water , also pomps out , spinning is working but when its the washing time the motor stops with a sort of buzz sound and after short time the bi metal stops the cycle . The motor was changed for a new one and the same problem remains .The machine is 80 series and has 4 speed .
  • alijahanafro Nov 25, 2008
    I changed the timer and The problem was salved. thank you .
    Sergeant:
    Champion:
  • 291 Answers
Sound like your speed control switch on the console that you set and if not your timer is going out but the switch is only a few dollars and thats what i'd do first.
Larry
Posted on Nov 25, 2008
My washer is maintaining water and continues to run after the cycle is complete?
You have problem with pomp or swich put pomp to work .Replays pomp or switch.
Dec 12, 2016 | Washing Machines
My beko wb 6004 ns doesn't spinning to dry the clothes
the issue is in the timer . have a qualified technician change it with a new one . thanks .
Jun 14, 2013 | Washing Machines
THE POMP MAKE NOISE ...BUT WATER DONT' EXIT
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jul 13, 2011 | Coffee Makers & Espresso Machines
LG intello front load washing machine not starting Select cycle as always and press start nothing then it beeps and flashes all lights
check filter and drain pomp...if ok check motor brushes .. bsc appliances 07779933829 postal service too.
Feb 26, 2011 | Washing Machines
Wont drain for spin cycle
in the previous statement i meant to say,if its plugged and cant drain then it wont advance to the spin cycle
Oct 16, 2010 | LG WM0642H Front Load
Hello! Our Bosch-Siemens clothes washing machine SIWAMAT 2105 has the following problem: When it want to eliminate water, the water pomp doesn't work(we hear just some noises). We already manually...
Make sure you use high efficiency detergent.  The front load machines take a special kind of detergent to make them run smoothly.  Check your drain hose for clogs, and clean the pump again.  If none of these fix the problem, you will probably need to replace the pump.
Nov 07, 2009 | Siemens WIQ1633 Front Load Washer
After first washing,water pomp does not getting water out of machine.
Just Go Call A Matholmagitionelangotaneonlenstonameernisinker
Aug 07, 2009 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
88 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
