Question about Amana ALW480DA Top Load Washer
Washer Pump leaking.....
Amana Model ALW480DAW. I would change out washer pump...Does anyone have instructions for removal/replacement? Your help would be greatly appreciated. Thank you in advance
    Problem Solver:
  • 7 Answers
Please refer to my instruction here
Posted on Jan 06, 2009
Amana ALW480DAW top load washer 9 yr old
You're not done yet. The washer pump probably is leaking. Lots of basements being pumped out in this area as a result of the snow.
Jan 16, 2018 | Amana ALW480DA Top Load Washer
Can't remove front panel on Amana washer
access through the back panel about 10 screws. Its likely the drain pump or one of its hoses.
Aug 23, 2009 | Amana ALW480DA Top Load Washer
Bad water pump on my washing machine
Is this a top loader? If so, these instructions should work for you since this is a Whirpool manufactured washer:
Replacement pumps can be purchased on line at or Both sites offer excellent illustrations and competitive prices, so shop both for the best price. The pump is listed under the heading for the Pump/Motor/Gearcase. Just use the model number off your washer for your search criteria.
This is a fairly simple repair, but if you have questions along the way, please let me know. I hope this helps you.
PS If my instructions aren't accurate, or if this is not a top loader, please post back with your model number so that I may be able to determine how your washer is contructed.
Jul 15, 2009 | Washing Machines
is this a whirlpool built amana? if so, its most likely a direct drive model, and when it doesn`t spin its likely a coupling between the gearcase and motor has videos on how its replaced, which isn`t too complicated to do...good luck
Apr 30, 2009 | Amana ALW480DA Top Load Washer
How do you diagnose a bad washer pump vs a cloged line?
Amana ALW480DAW seems to be not completely draining. When I start a new load water in basket becomes dingy and smells. Washer smells when it has not been used for a couple of days. We have checked the outflow and inflow drain tubes found no problems. It seems to spin and agitate normally, it drains to a point and leaves water in it, not visible in the basket. When we blow on the outflow tube when it is done draining there is still water present, we can hear it bubble.
Feb 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Model alw480daw Amana Washer, belt siezed, idler pulley free spinning, pump still rotates and works, tub spins. White hex drive under tub pulley is partially raised. Prior to problem a howling noise...
you could have a transmission porblem are you might have something in the washer basket cause the noise check basket maker sure there notting like a nail are some thing in hole of the basket an due see any oil leaking out tranmission are call a appliance service
Dec 13, 2017 | Washing Machines
Amana ALW480DAW Top Load Washer
sometimes the pump becomes stripped where the motor shaft goes into it.
Jan 22, 2008 | Amana ALW480DA Top Load Washer
Amana ALW480DA Top Load Washer Logo
311 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
