Question about Haier HVF060A Wine Cooler
Water leaking from unit
Started a couple of days ago, water has been seeping from under the unit. I checked inside and found that the bottles of wines are also wet. The inside back metal plate is also wet. The motor is still running and the unit is still keeping the temperature. What could be the problem? Thanks for the help.
  • 237 Answers
It may be the drain line is not dripping into the catch bucket under the back side, visually check to see if the line is reaching into the bucket and that it's not clogged up on the inside of the unit floor. The back panel being wet may just be condensation in between cooling cycles as the frost melts. If the unit is OK with keeping temps the refrigerant charge is likely OK.
Posted on Nov 24, 2006
SOURCE:
What can cause floor in the back, (behind the front passenger seat) to be soaked with water (& I mean SOAKED) ?
I assume there are no leaks in the windows or sunroof.
One probable cause, is the Air Conditioning unit. On all cars there is a drain line for the AC unit. As a unit runs, it produces condensation. (Just as a bottle of cold water produces condensation in a warm, humid area). That water has to go somewhere, so there is a drain at the bottom of the system. That drain (which comes out under the car, usually centered under the dashboard area), can become clogged or pinched and leave the water to accumulate in the system base, (again inside the car, under the dash). When this happens, the water will seep under the carpet and find the lowest area, which in this case, is the floorboard in the back seat area.
Jun 10, 2014 | 2013 Chrysler - 200
Much water under front carpet of 2002 Toyota Sienna. seems to coming from up under dash on firewall I think, what say you.
If the Water smells like Antifreeeze then it is your HEATER CORE
If the water smells like Water or Dirty Water, then you have a LEAK.
Here is a TRICK..
Get an Aresol Can of WINDOW CLEANER.... Spray completely around your Windshield on OUTSIDE EDGES... YOU WANT IT FOAMY.
Get an AIR HOSE and BLOW the Windshield from the INSIDE and see where the leak is coming from.....
It has ALWAYS worked for me
Apr 08, 2013 | 2002 Toyota Sienna
I have water seeping from the bottom of the unit.
That is very common when the water heater springs a leak...the water will seep through the inside and run out the bottom...
Check to see if it is still under warranty...if so then call the installer to have it replaced...if not then replace it with any new one..
heatman101
Jul 12, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Every couple of days there is a puddle of water coming from unit..shut off water source and still leaked water?! HELP!
Is the hose from the freeze compartment in the drain pan? Or is the drain pan leaking? The unit is going into a defrost and that is where the water is coming from. It drains into a drain pan where it evaporates over time......Check the drain line and the drain pan. Is there ice in the bottom on the freezer maybe the drain is pluged inside and the excess is seeping out the door during defrost. Hope this helps....
Mar 11, 2011 | Refrigerators
How to resolve our "lack of water" issue..within the last few weeks, the water dispenser's water flow lessen with each day-now it does not just doesn't work
there may be a problem with the water lines or bottles in the fridge compartment is frozen raise the temp in the fridges to about 38 for a couple of days and this should unthaw the lines
Apr 13, 2010 | LG LFX25971ST Bottom Freezer French Door...
Water in drivers side footwells front & rear
What about a leaking heater core... If the defroster is on and your winshield fogs up temporarily when the car is first started, that is a good indication of a heater core thats leaking water inside the car... Have that checked, Im guessing its your problem..
Jan 25, 2010 | 1989 Ford Probe
Thermal coupling in wine chiller
No, I would not recommend putting water into the chill chamber since if there is a "gap" hole in this compartment, the water could get inside the unit's electronics etc.. which could at the very least short the unit and at worst electrocute you as you take the bottle out/touch the unit. That's the problem with this or any other Peltier/thermoelelectric type of chiller. They are only good for maintaining an ALREADY cold bottle's temperature, not for chilling it rapidly. There is no good or inexpensive way to get better chilling from these types of units. It's the law of themodynamics and heat transfer. Water is the best/safest/most inexpensive medium to use, not chilled air or even super cold air. Cold air or even super cold air just does not match the chilling potential of a liquid like water. The reason why 50F air is no problem, for you to be out in for hours, but 50F water you'll get hypothermia in 20-30 mins.
The best unit for chilling a warm wine bottle is the cooper cooler. Go to www.coopercooler.com. It uses ice and water and sprays the ice cold water over the bottle while spinning it to chill it quickly. This unit is great since it can also chill single serve drinks like beer/soda etc so is more versatile than the other chillers. Cheapest is about $59 which is much less than the waring at ~$100
Feb 01, 2009 | Waring Wine Chiller - Black
Water seeping around fitting on back where water line fastens tp
Where does the water seep from?
The compression fitting you speak of is for the ice maker and through door water (if you have it.).
If water is on the floor, then chances are the drain pan underneath the unit has a hole in it, or for some reason, the water is not getting to the pan.
If water accumulates inside the freezer, check that the tube leading to the pan on the bottom of the refer is not clogged in some way.
If the water is in the refrigerator side, there may be a hole in the tank for the through the door water dispenser. It would leak everytime the icemaker dropped ice and refilled.
Jan 19, 2009 | Amana ARS2464B Side by Side Refrigerator
Water seeping out the bottom of my wine cooler
there should be a drain pan that you will periodically remove. Condensate (water) is a normal byproduct of all refrigeration devices. Also look for a drain fitting that you can run to a waste line.
Nov 25, 2008 | U-Line Wine Captain (2015WC) Wine Cooler
Haier HVF060A Wine Cooler Logo
904 people viewed this question
Top Haier Furniture Experts
Colin Stickland
Colin Stickland
Felizardo Erilla
Felizardo Erilla
Steve Allison
Steve Allison
Are you a Haier Furniture Expert? Answer questions, earn points and help others
