Question about Bugaboo Cameleon - Tailored Fabric Standard Stroller
The frame wont click into place
When I pressed the 2 round white buttons on top of the frame supports they appear to be stuck in so I can no longer put the seat into 3 positions as it doesnt lock nto place anymore, its almost as if the mechanism springs arent working. It just moves from horizontal to upright with no clicking in between which i seem to remember what used to happen
  • 1 more comment
  • rachelski Nov 22, 2008
    We have exactly the same problem - the little round discs are stuck "in" and won't click back into place. I read elsewhere that someone emailed Bugaboo directly to ask for replacement parts (even though out of warranty) and they did appear, but I've tried this and haven't heard anything yet.
    In the meantime, my husband now has the buggy in 43 pieces all over theh living room floor so he may be able to sort it out. If he discovers a magic solution I will let you know...!
  • kyllemimi Nov 28, 2008
    I have excactly the same problem...and I called bugaboo and was on hold as number 3 for 45 minutes...nothing happened. I wrote them 2 times...no responce. It is quite annoying after paying 1000 usd for a stroller...use it for only a year...and then on top not able to get any response!!!!!!!!
  • moliver101 Feb 15, 2009
    We had the same problem and mailed Bugaboo through their website (bugaboo.com).They knew exactly what we were talking about and sent replacement white buttons within a week - no proof of purchase required, which was lucky as we bought it years ago in the UK and are now in NZ and haven't got the receipt. We dealt with the support person in the Netherlands responsible for Australasia who got the Aussie suppliers to send the buttons through. Buttons were easy to install and once I put the frame back on the chassis (thanks for the reminder YenGr) it all worked fine.
My daughter has just brought me a Bugaboo which is 25 months old (one month out of warranty) and after several hours work I have figured out the problem.
The reason that this seems to occur after a year or so is, I believe, related to the fact that the housing in which the white button sits is made of thermoplastic and is not dimensionally stable. For the button to work properly both the circular hole in which the button sits and the button itself must be circular and the button must be very slightly smaller in diameter than the housing. If either of these are slightly distorted the button will stick.
The other thing to know is that when the cradle is off the chassis the button will always be in the 'in' position. What pushes it out is the pressure of the part of the chassis on which the cradle sits when you push the cradle onto the frame (you can demonstrate this by getting a screwdriver or thin dowel) and pusing down on the plate within the socket on the cradle that sits on the chassis - when you do this the button will pop out and when you take the pressure off it will pop in again).
If when the cradle is attached to the chassis the button is not out, give it a few quick sharp presses on one side to make sure it isn't binding on the plastic within it sits.
This should releases it.
The cure? You need to dissamble the button assembly and spray some silicone lubrication or similar and make sure the various parts are working smoothly. Also you need to check to see if the white button is binding on its black housing. If it is, then carefully use some wet and dry paper or similar abrasive on the circumference of the button until it stops binding
Having figured out how this works I have to say that I consider the mechanism to be a very poor one considering the price that is charged for Bugaboos. If they took a little more care and made sure the button and housing wouldn't distort with age and bind, the problem wouldn't exist.
Hope this helps.
Posted on Feb 14, 2009
    Problem Solver:
  • 5 Answers
We had a similar problem, the right-hand hinge of the frame would not lock and the button was permanently down. What had happened was the handle extension switch housing had come unscrewed and slipped up the frame, causing a small spring to fall out. The lock switches each have a spring which pushes down on a rod inside the frame to lock the hinge. To access the spring, unscrew the handle extension housing and slide it up the aluminum frame. I replaced the missing spring and the frame works perfectly. If the problem is with the spring, this should work. Alternatively the problem may lie inside the lock switch housing, which contains a very simple mechanism which slides the lock rod up and down. This can be unscrewed as well. As far as I can tell, the actual hinge assembly itself is a sealed unit and can't be opened, but hopefully, you won't have to.
Good luck,
Ben
Posted on Jun 25, 2009
Of course I don't know when you bought your bugaboo.
But I had the excact same problem. I wrote to bugaboo and found out they had 2 years of warrenty - and they right away send me repair parts for this. These only lasted for 2 months and I had the excact same problem again. My daugther even flipped all the way backwards in her stroller and almost fell out with the head first - so be carefull. I wrote them again and now they are sendingme a full replacement frame. I am still nervous to use the stroller. But will give it a try. I think the stroller is notr strong enough for having big children lying all the way down to sleep (my daughter is only 16 months and still needs to nap) . I asked them if I could return the full stroller and they could give me the money back...they never answered. But lets see how it goes this time.
But to everybody that has a Bugaboo with a little bit ****** kids (my daughter is 26 pounds and LONG) be carefull with having them lying all the way down to sleep...it is dangerous!!!
Posted on Feb 18, 2009
Scanner does not appear to work
If you put something in and click "acquire", do you get the same white image?
Jun 08, 2015 | Office Equipment & Supplies
I phone 4 wont come on or shut off
Press the round button and the power button at the same time until apple logo appears. Then release buttons - phone will boot fine now!
Nov 27, 2013 | Apple Iphone 4s I Phone 4 S Factory...
My iPhone is stuck on the white screen but i cant really use it..i tried to restore it on itunes but i cant since it has a passcode but i cant type it in because the screens white and i cant see the...
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least ten seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Jan 27, 2011 | Apple iPhone Smartphone
How do you align the colors?
Press MENU button and ON-SCREEN MENU will appear. Press
POINT LEFT/RIGHT buttons to move a red frame pointer to
IMAGE ADJUST Menu icon.
Press POINT DOWN button to move a red frame pointer to the
item that you want to adjust. and then press SELECT button.
The level of each item is displayed. Adjust each level by
pressing POINT LEFT/RIGHT button(s).
Move a red frame pointer to
the item to be selected and
IMAGE ADJUST MENU
IMAGE LEVEL ADJUSTMENT
Press POINT LEFT button to decrease contrast, and POINT RIGHT
button to increase contrast. (From 0 to 63.)
Press POINT LEFT button to adjust image darker, and POINT
RIGHT button to adjust brighter. (From 0 to 63.)
Contrast
Brightness
Press either POINT LEFT button or POINT RIGHT button to obtain
better balance of contrast. (From 0 to 15.)
Gamma
To store manually preset image, move a red frame pointer to
Store icon and press SELECT button. Image Level Menu will
appear. Move a red frame pointer to the Image 1 to 4 where you
want to set and then press SELECT button.
Image Level Menu
Move a red frame pointer to any
of Image 1 to 4 where you want
button.
Store icon
Press SELECT button at this icon to
store the adjustment.
IMAGE ADJUST
Menu icon
Press POINT LEFT button to lighten red tone and POINT RIGHT
button to deeper tone. (From 0 to 63.)
White balance (Red)
Press POINT LEFT button to lighten green tone and POINT RIGHT
White balance (Green)
Press POINT LEFT button to lighten blue tone and POINT RIGHT
White
Jan 22, 2011 | Sanyo PLC XU35 Multimedia Projector
How do I fix one of the frame support buttons on a Bugaboo Cameleon, as the lefthand button is stuck?
Do you mean the tilt buttons? If so you need to disassemble the buttons, which can be done with two screwdrivers one a thin slot type the other a phillips. Here's the process: 1. Behind the white button is a screw. Remove it using the phillips screwdriver. 2. You'll now have a black housing with a white button held in by three white tabs. 3. Free the white button from the housing by pressing inwards on each of the three tabs with the slot type screwdriver. 4. You'll now have a black base, a spring and a white button. 5. Sand the circumference of the white button evenly until it slips easily in and out of the black surround. A little silicon spray is a good idea. 6.Reassemble and repeat for the other side.
Jan 16, 2011 | Bugaboo Cameleon Jogger
My ipod touch wont let me go 2 themain meun but i
Press and hold the Sleep/Wake button and the Home button (It's the round button located on the device right below the screen) at the same time for at least ten seconds, until the Apple logo appears. Sometimes just pressing the home button will bring you back to the home screen regardless of where you are on your iPod.
If that doesn't work, try: http://support.apple.com/kb/HT1394?viewlocale=en_US
Dec 24, 2009 | Apple iPod touch
I have a bugaboo chamelon pram , the two round white knobs at the side for reclining seem to be stuck and wont click back into place !! making the carrycot?pushchair unstable
If the Cameleon is under two years old then it is covered by the warranty. The best thing to do is to contact the retailer you purchased the pushchair from or contact Bugaboo direct (www.bugaboo.com). They should arrange for a set of replacement buttons for the seat frame and instructions to be sent to you. If it is out of warranty, you'll just need to purchase these spare parts from them.
Sep 15, 2009 | Bugaboo Cameleon Jogger
Bugaboo frame will no longer click into position.
There is only one place in England that can repair the handle www.buggypitstop.co.uk every where else they will tell you you have to buy a new Chassis £290.00 joke
Aug 11, 2009 | Bugaboo Cameleon - Tailored Fabric...
Lamp life indicator reset
Click Sanyo Support to download Instruction Manual copy and check page 39 for details about Lamp Reset procedure.
Apr 30, 2009 | Sanyo PLC-XT16 Multimedia Projector
Bugaboo Cameleon - Tailored Fabric Standard Stroller Logo
492 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
