Question about Marantz SR-680
Receiver turns off by itself
Hello, I have had my Marantz SR-680 for about 8 years now and I am still very happy with it. Lately, I have noticed that the receiver will turn off by itself while I am listening to a CD. If I wait a few minutes, it will turn back on. Sometimes it happens in the first few minutes of turning on the receiver, sometimes after it has been on for a few hours. The problem does not seems to cocme and go. It might happen twice in one week, then it won't happen for 3 or 4 weeks. Does anyone have any ideas? Thanks!
  • Anonymous May 18, 2009
    Ik heb ook een marantz 74sr680/02b die zichzelf automatisch in en uitschakelt!!! Dacht eerst dat het aan de sleeptimer lag maar die staat op off.
    Wie kan mij helpen???
Duncan
  • 219 Answers
SOURCE: Marantz SR 7200
Sounds like it is zapped (fried outputs). Time for a trip to the repair shop. Good luck.
Posted on Jan 29, 2007
SOURCE: Marantz sr 500 going to "protect" mode when on.
Change the audio amplifiers IC´s because are on short circuit
Posted on Oct 02, 2008
SOURCE: marantz sr 66u receiver
KAKO SI MIMI
Posted on Dec 19, 2008
DickCanFixIt
  • 948 Answers
SOURCE: Center channel goes muffled after a while of use.
It is likely that something overheating is causing the problem, but nothing should be overheating. Cleaning won't hurt and may help but it is likely to require repair of the faulty component, perhaps a failing capacitor or amplifier.
Posted on Dec 29, 2008
killer_clown
  • 86 Answers
SOURCE: NO POWER - MARANTZ SR-5000
you mite not have to reset it, try checking ur fuses, it could of triped the cicrut when the power went out, normaly thats what happens unless it was a direct contact then, u mite wanna go get a nother receiver, and what i mean by direct contact, i mean like directly pluged into the wall
hope that helps
Posted on Feb 13, 2009
Marantz SR-6300 receiver frozen in the CDR mode
It may be weird but it's a small suggestion formerly often occurred at Sony Trinitron TVs building years of 80/90 . maybe the same kind of problem.
A select button internally lingers on the selected matrix usually has priority
Nov 27, 2015 | Marantz SR-6300 Receiver
Tip
Marantz SR-7200 reset
This was documented on the Marantz website briefly a year ago and is no longer available. My SR-7200 develops "click/pop" problems and a reset cures it of these issues.
While powered "off," on the front panel, press: A/D + FP +Dimmer (3 buttons) and power the unit on.
This reverts to original (out of box) settings. You then must reprogram input sources, speaker setup, levels and radio stations.
on Oct 03, 2011 | Marantz SR-7200 Receiver
Marantz SR-7200 volume -29dB blinking
Check Speaker connections at BOTH ends and double check to see that they are on the right terminals.
If you need a manual . the Marantz site will have one . PLus they may have FAQ notes for that receiver
Cheers
Mar 01, 2014 | Marantz SR-7200 Receiver
Marantz SR-14 EX 5.1 Channels Receiver fuses.
Changing the type of fuses in your receiver will not change your sound quality at all.
Jun 07, 2012 | Audio Players & Recorders
Error numero 2 marantz
Hello Allisonvasqu,
It's not exactly an answer, you have this problem about 5 years ago and I'm with this problem now. Could you solve your problem ? How could you solve it ? Thanks !
Dec 17, 2010 | Marantz SR-780 Receiver
Hello i have a marantz receiver sr7400 fuse
Unplug the unit. Carefully unscrew the screws for the case. Probably 4 screws, 2 on each side of the unit. Remove the cover. Look for the fuses, and replace with exact same type/specs of the faulty fuse. If the fuse, is on a printed circuit board, be careful dislodging the fuse. Hope this helps.
Apr 07, 2010 | Marantz SR-7400 Receiver
I need the remote control code numbers for the SR-18 so I can turn it on with my Direct TV remote.Do you know what they are?
the best thing to do is a code search per the directv manual and hope the Marantz powers off when you find the code.
If it turns off, you have won half the battle. Save the code and try turning the Mar back on.
The issue is that these universal satellite remotes are very limited on there funtionality with audio systems.
Keep in mind that if you find a code that turns it on & off, you will probably be limited volume only. If you get those three functions, you are very happy and call it done.
Hope this helps.
This goes for all sounds systems and not only Marantz.
Jan 19, 2010 | Marantz SR-18EX Receiver
What is the error POW 5 on a marantz sr 7500
I have a POW 5 failure on a marantz sr 7500. Anybody know how to fix?
Jun 02, 2009 | Marantz SR-7400 Receiver
79 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
