Question about Hotpoint RGB745 Gas Kitchen Range
Propane gas burner now has red flame instead of blue
We own a Hotpoint Propane gas stove and recently it is showing a red yellow flame instead of blue on a few surface burners. Should I try to clean it or adjust it? And how? Propane gas company asked me not to use it and have one of their servicemen come up to the house for a service call. I don't think it is that serious. Do you?
  • Anonymous Jan 13, 2009
    the flames on the fire are red
5 Suggested Answers
reddyanantha
  • 205 Answers
SOURCE: How to turn on oven?
mam please check the gas line is open and if the unit is idle for long time the gas line may choked so first you check the gas line.
Posted on Sep 07, 2009
EMSRSERVICEG
  • 426 Answers
SOURCE: broiler flame too big, right rear burner has yellow tips. was converted from natural gas to propane
you can turn the supply valve down
Posted on Jan 13, 2010
joboo1
  • 257 Answers
SOURCE: Propane gas burner now has red flame instead of blue
Hi, If you have the same problem with your stove , furnace and water heater, Then you look for things in common that would cause the problem. Any change in the flames is an indication of a change in the fuel/air mix. The item that would be common to all would be the pressure diaphragm. This is not something a customer should work on without a through knowledge of how they work. I think you would be well advised to have a service call. Good Luck!
Posted on Feb 10, 2009
heatman101
  • 43501 Answers
SOURCE: I have a Hotpoint gas
Pull the knob off and behind the knob is a small screw that adjusts the flame...
heatman101
Posted on Dec 27, 2010
Black smoke coming from oven while preheating
CLEAN the OVEN put a drip pan under stuff when cooking
Dec 21, 2013 | Premier 24 inch Compact Gas Range w/ Solid...
FLAME IS YELLOW INSTEAD BLUE for sunbeam gas range
Yellow usually means more air than gas mixing at the burner. The top of the stove lifts off. There are adjustment screws in front of every burner. Turn the burner on after first locating the screw. Turn the adjustment screw until desired flame is achieved. You want a flame with a yellow tip and the body of the flame blue. Please be very careful not to get burned. Hope this helps.
Jan 20, 2011 | Sunbeam SNS3GMNBB (Gas) Kitchen Range
Just recently our 10 year old stove started smelling funny only when its on. the burner burns but the flame is yellow and was normally blue. I understand the air fuel mixture could be off, how Do I fix...
Gas flame on all gas appliance should burn clear blue.
Yellow flame means you need to clean the burners.
This applies to stoves, oven, furnaces, water heaters
I did a google search for: clean burners on gas stove.
There was more information and helpful tips on those links than I can honestly repeat here, including how-to videos.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on appliance.
Jan 03, 2011 | Hardware & Accessories
Propane stove burns yellow & creates soot
clean the orfices and tubes and then if possible adjust your air mixture setting also
Sep 21, 2009 | Frigidaire FGB24S5A Gas Single Oven
Feb 10, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Flame way too high and yellow-Frigidaire Model #FGF328GM
call an approved frigidaire gas technician as it is possible that the jets in use are not for the propane gas
they are probably natural gas jets which have a larger jet size
the air shrouds around the jets have to also be adjusted to get the blue flame
you may be able to have it checked out under warranty as it is new
if you touch it your self , the warranty will be void
Mar 11, 2017 | Kitchen Ranges
Why is my stove causing a thick coat of soot to buildup on my pots?
you have to adjust the air intake holes at the valves. this will give you a blue flame.
Aug 16, 2008 | Coleman Propane Grill Stove 9921-700
What could be wrong with a gas stove hot point(2 yrs old)that has lots of black in the oven when using and also black on bottoms of pans when using burners on top? it just started doing this...
The flame is 'yellow tipping'. This means there is incomplete combustion and will leave black soot on everything. Did you recently start using propane? If so the stove will need to be converted to propane use, or the incoming gas pressure is too high. You may need a gas professional to check the gas pressure.
Jun 07, 2008 | Kitchen Ranges
Hotpoint RGB745 Gas Kitchen Range Logo
1,693 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Justin Duby
Justin Duby
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
