Question about Jensen XA2125 Car Audio Amplifier
No green light no sound no red light but have power
Got it second hand worked fine then stopped no burnt wires or ristores in side no sound
  • 3 Answers
Check both fuses?
Posted on Nov 15, 2008
What can cause the brake lights not to work on my 2008 Honda Accord
there are several things. A blown fuse. A bad brake switch. There should be power at the red wire all the time and power at the light green wire with the brake pedal depressed. As, likely as it may sound all the bulbs could be burnt out (it does happen).
Jan 16, 2016 | Honda Cars & Trucks
What wire to solder on the ciggy plug?
Red is your positive black is ground yellow constant power green is a wire that does not need to b used nor the yellow unless u want constant power to the unit positive red wire goes to the front of your ciggy adapter black can go on edit hie side of the two grounds that hold your ciggy adapter inside the socket hope this sheds some light on it
Mar 03, 2014 | Passport 8500 X50 Radar Detector
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
Wiring for 2005 sprinter tow bar
1=yellow wire left hand indicator 2=blue wire reverse lights 3= white wire earth to ground 4= green wire right hand indicator 5=brown wire side light 6= red wire stop lights 7 =black wire side lights
Mar 19, 2011 | Mercedes-Benz Sprinter Cars & Trucks
My amp stopped workin, when i turn the stereo on, the green light is on, then when the music starts to play it turns red and stops working,
The red light on amplifier relates to power supply while the green light is indication of sound functionality. An amplifier that allows sound to generate should display both red and green lights. Howeever, some amplifiers would display only green as long as the sound is functioning.
Solving the problem
First, a red light still on means the power connections to the amplifier is fucntional least requirng repairs.
Second, the green ligh should turn on once the stereo were tuned up to produce sound. If the stereo is still on only least produce sound on the amplifier, check on the connection wires between stereo to amplifier that may have disconnected due to woofing or dubbing sound generals with unfirm wiring.
Third,
Jan 28, 2011 | JVC KS-AR7501D Car Amp
2006 F150 no brakes light all other lights work
Does this include the CHMSL ( Center High Mount Stop Lamp ) ?
The turn signals work fine when you say all other lights work ?
If so could be 2 things.
1. The BPP ( Brake Pedal Position ) Switch
1.1. The BPP has 4 wires on it
1.1.1. Tan w/ Red stripe & Pink w/ Light Green stripe are the shift interlock
1.1.2. Light Green w/ red stripe & Light Green wires are the Brake lamp part of the BPP.
When you have the brake off, the Light Green w/ Red stripe wire should have power on it ( from fuse #2 ) and when you press on the brake pedal, the Light green wire should also have power.
- If only the Light green w/ red stripe wire has power with the brake on and off, and the Light green wire never has power, the BPP switch needs to be replaced.
- If the Light Green wire does not have power ( and you are use of the ground you are testing with ) fuse #2 is blown.
- The fuse for the brake lamps ( Fuse #2 in the cab fuse panel ).
-- This is if the CHMSL is also not functioning
Jan 26, 2011 | 2006 Ford F-150
I have two dimmer switches in the same box side by side. one goes to three pot lights, the other goes to a halogen track light. these have been working for 5 years. the lights have burnt out and been...
Sounds like the transformer in your track light. In the box where the green light is, the voltage is converted by a small transformer from 120v to 12v for the halogen lights. With the breaker off, try jumping out the dimmer going to the track light (disconnect the dimmer and connect the two loose wires from box together). With the breaker back on, if you have 120v power on the wires (black/white) going into the track light transformer (measured at the track light), and the green light won't come on, I'd say it's the track light transformer. You may have to replace the whole track if you can't get the transformer as a part.
Apr 22, 2017 | Lutron ELECTRONICS MAW-600H-LA SMART...
I need to wire a towbar to my lt 28 but have no wiring info
Trailer socket pin1 (yellow) to left hand indicator (Black/White) at L/H Lamp, Pin2 (blue) to fog (Grey/White) at R/H Lamp, Pin3 (white) to Chassis Earth, Pin4 (green) to right hand indicator (Black/Green) at R/H Lamp, Pin5 (brown) to right hand side light (Grey/Red) at R/H Lamp, Pin6 (red) to brake (Black/Red) at either Rear Lamp, and finally Pin7 (black) to left hand side light (Grey/Black) at L/H Lamp.
Mar 25, 2009 | 2004 Volkswagen Eurovan
Jensen XA2125 Car Audio Amplifier Logo
88 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
