Question about Kenmore 22422 Top Load Washer
Top load washer will not drain
We have a top load washer. My husband says it will fill with water and spin but it will not drain. He thinks the pump might be gone, but before we make any rash discisions I wanna know what we are dealing with. Please help!
  • Anonymous Nov 16, 2008
    the machine is not draining the water and making noise.
    Scholar:
  • 131 Answers
Just by your descriptions,you may have trash/blockage in the screen/filter on the inlet side of the pump.to check this before pulling anything apart,take the drain line(with water in the tub of course)& drop it well below the water line in the unit(use a bucket).the water should run fairly fast out of the washer,if not you have a blockage.be sure to get as much water out of the tub as you can if you attempt this yourself.either way let me know & we'll see if we can get it corrected.thanx for using fix-ya!!!
Posted on Nov 29, 2008
Washer won't fill with water
Hi Allen, this is JK. I see that you are having trouble with your washer (FEX831CS) not spinning or filling with water. For the washer not spinning, check the drain hose length and make sure there are no restrictions. The concern could be with the timer or the drain pump. For the washer not filling, I would check the water pressure, pressure switch and the water inlet valve. If all of these suggestions pan out and the problem still persists, think about what may have happened prior to this occurrence. For instance, did you notice any error codes, odors, or other strange functions prior to this issue? If you are still having these issues and can think of anything in particular, please feel free to reconnect.
Mar 23, 2014 | Frigidaire FEX831CS Top Load Stacked...
My washer was filled with water but wont spin.. makes little noise but no spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 18, 2011 | Maytag PAV5157A Top Load Washer
Washer fills with water and drains but will not agitate or spin out
heatman101
Sep 26, 2010 | GE Profile WPRE6100G Top Load Washer
WASHER SPIN CYCLE WON'T WORK. IN ANY CHOSEN SPIN CYCLE MODE. FILLS , WASHES BUT WON'T SPIN OR DRAIN WATER.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Sep 18, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Our washer filled with water and will not drain. There is no action at all. Water just sitting in washer. Washer will not work Help
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 10, 2010 | Whirlpool LSR6332K Top Load Washer
GE Profile top load washer purchased 2003 water comes out from under washer when spin and drain cycle on. this not mentioned in trouble shooting area. think it is water pump or whatelse can it be?
It has to be in the water exit path somewhere - is there a pump sump inspection? Is there a hose split? Likely the drain hose, or where it connects to the machine. Has the pump split open? Can you remove the machine cover and inspect it while it is doing a cycle so you can see where the water is coming from?
Apr 26, 2009 | Washing Machines
May tag washer spin cycle wont spin
check the pump ,,, if pump wont pump out the washer wont spin till it gets down so low / larryyb
Dec 05, 2008 | Maytag PAV2300 Top Load Washer
Washer won't rinse and spin
clean the drain hose, but make sure you have a container to catch the water and lot of debris will come out. Then unplug the washer and put water on spin cycle to drain water, after draining water remove the pump filter located next to the drain hose turn left to open and clean more debris. I found my husband wedding band I thought he lost it on purpose. You will be surprise how much funk is in that filter. Turn pump filter to right to close and put cap back on hose. Don't call the repair guy. Hope this helped.
Darlene, New Orleans
504-296-4391
Jul 24, 2008 | LG WM-1832C Front Load Washer
Kenmore 22422 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
