My flat screen wont power on
I am wondering if my flat screen requires it own power connection??? it has a standard power connection on the back just like a regular crt monitor or computer tower i plug it in and the power lights up green and just blinks does this model require a power converter??? or something other than you standard cord if you need any additional info please let me know thank you Jason
p.s. the product is a vison flat screen model name MR19-H1AD
product name V1922DB
INPUT:100-240V~ 20-60 Hz
  • 1 more comment
  • dbrown3 Dec 18, 2008
    I have the exact same problem.
  • evilhippie Jan 21, 2009
    what the hell my screen goes white if i press the down button while the power is blinking green other then that it does nothing at all
  • Gary Kane
    Gary Kane Nov 15, 2013
    There is a defect with the wrong cap on the power board. Open the back of the monitor and look for a leaking cap on the power board. Parts are available at Radio shack.
I called ProMedia and spoke to their Tech Support folks. The blinking green light means that the powerboard within the LCD has malfunctioned. It will require servicing if under warranty. If out of warranty it was suggested that buy a new one because of cost.
Posted on Jan 12, 2010
  • 47 Answers
The monitor should be plugged directly into a wall socket. It has a universal power supply in the monitor that automatically compensates for either 110VAC/ 60Hz or 220VAC 50Hz.
There are a limited number of compatible video resolutions (from the PC's video card) that are supported. The best setting will be 1280 x 1024.
The manual can be found at: http://www.promedialcd.com/001/usa/index.php?page=v1922db
Posted on Dec 28, 2008
Screen going out is this a standard issue with these televisions just wondering picture went out and it wasn't bumped or moved at all. just wondering thanks
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board....
May 08, 2016 | Polaroid FLM-1911 19 in. LCD Television
My RCA 32la30rq hd tv takes 5 hours to turn on. I checked the power board and all the capacitors seem fine. I am wondering what is wrong with it.
Fixing the problem requires more than "checking" the power board. It will be necessary to make voltage checks and use test equipment to locate defective components - including capacitors.
Jan 03, 2014 | RCA 32la30rq 32 Black Tv 720p - Lcd - RCA
Why does my MAG Innovision MA-32EF1ASP Flat Screen TV not function properly?
Have your hand ready when you turn the set on and instantly change the input to get back to the tuner in the set--some sets will shut down if hooked to a input with nothing connected.
Also if using a box connected to that input unplug box and set--wait and plug both back up to allow them to reboot.
Let me know what you find--not likely a reset will cure this but possible.
Apr 03, 2012 | Televison & Video
My Dynex TV wont power up. After a recent power outage,my flat screen never powered back up.
try uplugging it both from the tv and the outlet. you may need a new power cable. Was it connected directly or through a surge protector?
Jul 25, 2011 | Dynex DX-LCD32-09 LCD TV
I hooked my ps3 to the hdmi connection in the back,neither the system or the tv recognize the connection, i get a blank screen.I know the hdmi cable is good because I tested it.Any suggestions?
It could be that the PS3 is outputting a higher resolution than your TV can handle. Here is an excerpt from the PS3 manual:
If the video output settings do not match those required for the TV in use, the screen may go blank when the resolution is changed. The screen should, however, automatically go back to its original resolution after a while. If the screen remains blank for more than 30 seconds, turn off the system. Then touch the power button on the system front for at least five seconds to turn the system on again. The video output settings will automatically be reset to the standard resolution.
http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Mar 09, 2011 | Televison & Video
While watching tv the screen will go blank, sound
It might be a loose solder connection inside,try to prove it,the next time it goes blank,firmly give a whack to the back or bottom of the set,if it flashes back......sholud be a loose solder conn that a competent technician can find and repair
Jun 02, 2010 | JVC AV-32F704 32" TV
Bought with no power cord. Does this take 120 volts directly to the plug, or is there a power supply that's needed?
Look on the back of the Monitor.
If it has the same power connector as the computer.
Then it is standard 110 60 hz.
If not then you are missing the black box with the transformer and electronics to convert to the monitors proper voltage requirements.
Most flat screen monitors sold in the US are standard 110v/6hz.
And use the same modular power plug.
Oct 31, 2009 | eMachines E17T4W 17" Monitor
Samsung flat screen only clicks. Will not turn on
If it is a LCD it could be a bad power supply or the inverter board.
Both require a service man and could be costly..
Feb 06, 2009 | Televison & Video
Sony KV36H5500 WEGA TV (flat screen tube) will not turn on
Pull the back Off Disconnect CRT board connected at End of picture tube then turn set on and see if it comes on with volume, high voltage you can feel front of tv for static elect.... Let me know what happens then i can tell you what is wrong with TV.
Dec 27, 2008 | Sony KV-32XBR85 TV
P/S replacement in Gateway 2000 model year Tower
Gateway may have a unique non standard pinout for its P/S. I would match up the colors in sequence on the new PS and see if the old harness had the 6 pin connector and graft them into the new harness. The colors are standard for voltage.
Feb 11, 2008 | Antec TruePower Trio 550 (TP3550) 550-Watt...
Televison & Video Logo
988 people viewed this question
Top Televison & Video Experts
