I just moved and I'm trying to set up my computer and another computer wireless. I cant remember my network key or pass word. I can go on line if I plug in. But I have no service wireless. HELP!!
    Sergeant:
    Champion:
  • 275 Answers
Which wireless router u are using?
Posted on Nov 14, 2008
I can't remember the password for my router to let my ipod connect to the internet
Are you speaking about wireless network key?
For this, you will need to check the settings of the router.
Connect the computer to the router with the Ethernet cable.
Open the setup page of the router and check the wireless network key.
Read this How to find wireless network key from the router
Jun 22, 2012 | D-Link Computers & Internet
I cant find my password
Are you looking for wireless network key WEP WPA ?
For this you will need to check the wireless settings of your network.
Connect one computer to the router with the Ethernet cable. Open the setup page and check the settings.
Dec 12, 2011 | Linksys Wireless-G WRT54G Router
Need to secure my router
Try the following procedure on a computer that's directly connected to one of the router ports with an ethernet cable. This procedure will not work if you're connected wirelessly. Open a web browser, such as Internet Explorer, and type in http:192.168.1.1. A window should pop up asking for a user name and a password. Don't enter a user name and type admin for the password. Hit ok. The router setup screen should come up. Click on the Wireless tab and then the Wireless Security sub-tab. You can set up encryption on your wireless network using this screen. First select the security mode you want to use. I believe WPA gives better security but I've had some trouble using it on older computers. I use WEP. I've been able to get this encryption scheme to work with all of my computers. Next select the type of encryption. I like 128 bit 26 hex digits. Next enter a pass phrase and hit generate. The pass phrase is like a password. It should now generate four 26 character keys made up of various letters and numbers. Write down the first key and make sure you've checked the 1 box for default transmit key. Save your setting and exit. You wireless network is now secure. If you try to connect to it using a wireless device you will be prompted for a security key. Depending on the operating system you're running, you may just be able to enter the pass phrase or you may need to enter the 26 character key you wrote down. You should only have to do this once for each of your wireless computers. After the first time the computer connects to the secured network it should automatically remember the security code. I hope this advice helps you out.
Apr 19, 2011 | Linksys Wireless-G WRT54G Router
I believe my system is being hacked. How do I secure my router if I can't find my software.
Try the following procedure on a computer that's directly connected to one of the router ports with an ethernet cable. This procedure will not work if you're connected wirelessly. Open a web browser, such as Internet Explorer, and type in http:192.168.1.1. A window should pop up asking for a user name and a password. Don't enter a user name and type admin for the password. Hit ok. The router setup screen should come up. Click on the Wireless tab and then the Wireless Security sub-tab. You can set up encryption on your wireless network using this screen. First select the security mode you want to use. I believe WPA gives better security but I've had some trouble using it on older computers. I use WEP. I've been able to get this encryption scheme to work with all of my computers. Next select the type of encryption. I like 126 bit 26 hex digits. Next enter a pass phrase and hit generate. The pass phrase is like a password. It should now generate four 26 character keys made up of various letters and numbers. Write down the first key and make sure you've checked the 1 box for default transmit key. Save your setting and exit. You wireless network is now secure. If you try to connect to it using a wireless device you will be prompted for a security key. Depending on the operating system you're running, you may just be able to enter the pass phrase or you may need to enter the 26 character key you wrote down. You should only have to do this once for each of your wireless computers. After the first time the computer connects to the secured network it should automatically remember the security code after that. I hope this advice helps you out.
Jan 16, 2011 | Linksys Wireless-G WRT54G Router
My daughter set the router up and then moved out with the setup disc and she doesn't remember the pass code. My signal is not secure and my neighbors all use it. How can I make it secure? It always wants...
How to secure the wireless network
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Aug 04, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Router wont allow ipod to join network?
You need to make sure that youre trying to connect to the right network or network name and you need to enter the network key if the wireless network is secured. if cant remember the network key you need to access the router page and on the wireless setting you can obtain the network key, you can also personalize the network name and network key and the security as well for you to remember easily
Thanks for using Fixya
Jul 31, 2010 | D-Link DIR-625 (790069292637) Wireless...
I can not get my ipod to connect to wifi what do i
1. access your router's GUI:
click on internet explorer, type in the address bar: 192.168.1.254, then click on GO or ENTER
it will bring up NETWORK AT A GLANCE PAGE OR THE GUI
now at the top page click on HOME NETWORK, then click on WIRELESS SETTINGS or EDIT STTINGS (it'll asked you to enter a system password. if you cant remember it just click on 'I forgot my password and it'll give you a clue. and f you still cant remember you can click on 'I still cant remember my password and this this time it'll allows you to change it but first you have to enter the sytsem key that can be found at the bottom part of the modem under the bar code the one inside the parenthesis its a total of 10 numbers)
Now, just click on home network and wireless settings again then it'll bring up IDENTIFY NETWORK PAGE.
change the network name to your last name or any name, then for the wireless channel, change it to 10, make sure its WEP-OPEN, then select use custom pass phrase then enter 10 numbers that would serve as your wireless pw. then at the bottom part find power setting then change it to 10, then clicked on SAVE.
now on your ipod try to find the network name the you created then if it asked you for the wep key or pw...that's gonna be the 10numbers that you're about to create on the GUI.
Feb 02, 2010 | 2wire 2700HG-B Router (2700HGB)
I cant remember my passkey. I have cd
Take an invented-in-Norway paper-clip, and straighten one end.
Push the end into the small hole in the back of the router.
This will reset the router to its "factory-default" settings.
Then, run the software on the CD to assign a new pass-key.
Oct 09, 2009 | Kensington (K33348) Bluetooth Wireless...
Finding encryption key
This should work give it a try:
1)go to control panel
2)click on internet connections
3)wireless network setup wizard
4)click next
5)set up a new wireless network
6)next
7)Automatically asign a network key
8)set up a network manually
9)print network settings
Dec 21, 2008 | IBM ThinkPad T40 2373 Notebook
Can not remember or find network security key
You may need to access the router's setup page to check the security key or the network key you have set up to the router. To do this:
  1. Launch IE and type 192.168.1.1 on the address field using a computer that is wired to the router. It is the default IP address of the router. It will then ask for a username and password. By default, there is no username and the password is admin.
  2. Once you're in the router's user Interface, click Wireless tab. There is a sub-tab under Wireless which is called Wireless Security. Click on it.
  3. There you will find the type of wireless security you have enabled in your router as well as the network key.
Hope this helps!
Nov 22, 2008 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
