Atec televsion codes for sky + remote control
  • 2 more comments
  • stan_stitson Nov 15, 2008
    I have a Atec television and cannot get a code for sky+ remote control..................
    All i need is a code not product to buy........
    I need code for sky+ remote to work a ATEC AV420D television, has anyone got a four digit code please......................
    OK lets see if anyone has got a three diget code for a ATEC AV420D television for sky+ remote control...................
  • stan_stitson Nov 23, 2008
    thank you to everyone who took time to answer and i will be using fixya again............Great
    President:
  • 624 Answers
There is no code for your TV, they have the codes for 90% to 95% of all TV's, but yours is one of the 5% to 10% they do not have.
You can try this method to see if you can find one that works with your TV.
Identifying remote TV Remote Control Codes (Blink Back)
If there is not a 3 digit code listed for your customers TV receiver then use the four digit method to find a code that works. The following steps will allow this code to be identified.
1. Press the TV button on the Sky remote
2. Hold down Select and the Red buttons together for approximately two seconds, until the Red LED on the Sky remote blinks twice.
3. Key in 990 on the remote.
4. Key in 1 on the numeric keypad and count the number of times the Red LED blinks. The number of blinks will indicate the first digit of the code
Note that a 0 is represented by no blinks where you press the key. (My code is 081 so first time I tried it on my old Digibox remote I thought it wasn't working! And coming from a software background, I had a weird expectation that 10 blinks would be used for a 0!!!) Niall Gillespie
5. Input 2 on the numeric keypad and count the blinks to identify the second digit of the code.
6. Input 3 on the numeric keypad and count the blinks to identify the third digit of the code.
7. Write it down and keep it safely.
Posted on Nov 21, 2008
  • 4,806 Answers
Read this
http://www.satcure.co.uk/tech/digicode2.htm#mycode
i don't think there are any
sorry
regards
  • 3,037 Answers
Universal Sky remotes don't support Atec tvs.
I also found that since this is a non US brand, the following link does not sell your remote but has a model number if you want to order one from the manufacturer
http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=AV420WD&uuid=12267901466680&brand_pn=ATEC_AV420WD
Let me know if I can help you out in any other way
Posted on Nov 15, 2008
  • 728 Answers
To find the correct code, you may have to get a universal remote which comes with a whole set of codes for your tv to get the remote set right.
    President:
  • 2,712 Answers
Sorry to say, but there are NO codes for the Atec TV on a Sky+ remote at the moment. You could try the manual code search:
1. Press TV on your Sky remote control.
2. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
3. Key in the number of the channel on your TV that you use for watching satellite TV (For scart switching, this may be one of the other buttons on your remote e.g. help, i or a colour button).
4. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
  • Swilin Sampson
    Swilin Sampson Nov 15, 2008
    Just checking to see if my solution helped or not?
  • 685 Answers
037, 096, 104 try these ones let me know if any of them work
  • Juanita Vega
    Juanita Vega Nov 15, 2008
    sry 0070 were in front of the numbers
  • 734 Answers
I got codes for TEC not ATEC
499,037,245,275,502,304,363,365
  • 2 more comments
  • futureloginn
    futureloginn Nov 15, 2008
     following numbers: 0060, 0154, 0156, 1265, 0695, 0845,1145,1045.Hope these numbers help you out. Please take a moment to rate this info, by using the rating system below. Thanks.
    Another website which specializes in sky codes says one of the following numbers is a setup code: 0156, 536, 063, 271, 098, 117, 232, 530, 581, 130, 473, 088, 182, 064.
  • futureloginn
    please follow the above site for more code ---
    http://www.digitalspy.co.uk/satellite/re...
  • futureloginn
    futureloginn Nov 20, 2008
    try them--
    037, 398, 514, 104, 449.065, 397, 387, 607, 446, 397, 236
  • futureloginn
    try a last ==
    246, 263, 377, 037, 064, 065, 310, 300, 383, 399, 391, 402, 547, 292, 239, 312, 609, 322, 339, 515, 236, 389, 035, 191, 232, 245
  • 19,396 Answers
  • Ginko
    Ginko Nov 15, 2008
    Try also scnning the code, since the code is not available.
    See
    Sky Remote Codes-How to scan
  • Ginko
    Ginko Nov 21, 2008
    The three digit code for ATEC had never been released.
    You need to perform a scan with the remote, that is the way it works when codes are not distributed.
    See
    Genius:
  • 1,550 Answers
Try this two code
0520 and 1903
    Sergeant:
    Champion:
  • 347 Answers
Hello Stan, try the following codes on your televison:
0421
1608
1004
1903
0216
0520
Good luck,
Dahaka
  • Santiago Vallejo
    Santiago Vallejo Nov 15, 2008
    Have you tried with 420?
    Genius:
  • 1,239 Answers
Hi i found some of codes ILO CODES: 0421, 1608, 1004, 1903, 0216, 0520.Good Luck !
  • ABHISHEK.C
    ABHISHEK.C Nov 16, 2008
    hi i understand your problem go to how stuff works.com you can bye the code there or go to logmein.com
  • 1,879 Answers
Www.remote-codes.com
  • monk3ybidzness
    monk3ybidzness Nov 15, 2008
    Sky+ Remote Control code for Atec:
    Try these "possible" codes : 0421, 1608, 1004, 1903, 0216, 0520
    Looks like that the Sky+ Remote Control manufacturer can't keep up with the millions of TV makes and model manufactured everyday.
  • monk3ybidzness
    Sky+ Remote Control tech support doesn't have it either.
    Genius:
  • 1,913 Answers
2 Suggested Answers
SOURCE: Sky remote codes
I'm having probs too with a new sony bravia 40 inch
Posted on Mar 25, 2008
How do I program universal remote control atec tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Feb 16, 2015 | Universal Remote Control Televison & Video
What is the code for LG 37LE4500 TO WORK WITH SKY REMOTE CONTROL
I also have an LG TV. I used this 4 digit code: 0742.
TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
Mar 12, 2011 | LG Televison & Video
Unabel to use sky control for sound
You have to programme the correct code for your TV into the Sky remote.
You can get these via "Sky Active" (if your box is connected to a phone line) or from the Sky website, or google search: "Sky remote codes".
However your sky remote wont necessarily control more recent televisions unless you have a REV8 remote control. You can check this by taking the battery cover off your remote and looking at the sticker inside. If it says RC1600/00 you're probably not going to be able to control your TV. REV4 and REV6 are more likely to work - but not guaranteed. If it says REV8, then you are probably not using the correct code or you're not programming the remote correctly.
If you have REV8, the correct code for your TV (according to Sky) is: 0678 or 1678 or 0254
Sky remote code finder page is here: http://sky.uebv.com/
Sky guide to finding your remote code and programming remotes is here:
http://www.sky.com/helpcentre/tv/sky-remote-control/program-your-sky-remote-control-to-work-with-your-tv/
Please rate my solution if you find this helpful. Thanks.
Oct 13, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Procedure to code in for rca312w remote to ge televsion
Turn on the TV, press and hold down the TV key, while holding down the TV key enter one of the four digit codes, the LED light should go off, if not, repeat the steps using a different code....hope this was helpful...
May 28, 2010 | RCA RCR311B Remote Control
What is the code for a sky remote control to user on an ATEC 32" tv?
I do not know what version sky remote you have but I'm not sure it matters. I could not find any codes for your Atec TV anywhere. Chances are it's a new manufacturer possibly a home brand. This is a brand sold manly in a localized area. But because of the web it allows it's sale anywhere.
The first link is to Sky.com help. The second is basically telling you if your TV isn't listed give them time.
I will ad that I have seen some issues with the picture of Atec TV's not being properly display when used with the Sky system.
Sorry I couldn't be of more help. I will keep an eye out for update regarding your remote and TV. If one pops up I'll post it to this thread.
"HAPPY (insert preference here)" and "MERRY NEW YEAR" To you and yours.
http://www.sky.com/portal/site/skycom/skyhelpcentre/producthelp?nodeId=73a6e9e0-0ade-4eed-810b-cec670799bcc&articleId=11320303
http://www.sky.com/portal/site/skycom/skyhelpcentre/producthelp?nodeId=73a6e9e0-0ade-4eed-810b-cec670799bcc&articleId=5111510
Dec 21, 2009 | Acer Televison & Video
I NEED A CODE FOR SKY REMOTE
Hi.
Here available codes for Sky Remote: sky remote codes
Nov 05, 2009 | Televison & Video
Code to program my remote systemlink 3 rca to my jvc televsion
Im trying to program my remote to my orion televisison how do i do that?
Jan 06, 2009 | RCA RCU300WBL Remote Control
Sky remote code
there isnt a code. No point in going through them all either.Manafacturers being korean didnt think of it when making it..
Feb 23, 2008 | Televison & Video
Sky remote codes
Dec 23, 2007 | Televison & Video
Televison & Video Logo
149 people viewed this question
Top Televison & Video Experts
