Question about Symbol LS2208 Handheld
Move to next cell in excel
How do I move to the next cell right after scanning?
  • Jeremy T. Boron May 11, 2010
    next cell down or over ?
You need to configure the scanner rather than excel. I you want to go right, you need to send 'Keyboard Tab' as a suffix to your barcode. Chapter 13 of the programming manual tells you the barcodes to scan.
If you need more assistanc .... dmm_singularis@hotmail.com
Posted on Jul 17, 2009
    Novelist:
  • 144 Answers
In Excel 2003 Offline help, i see this helpful note:
Change which cell is selected next When you press ENTER to finish working in a cell, Microsoft Excel moves you to an adjacent cell or leaves you in the current cell.
  1. On the Tools menu, click Options, and then click the Edit tab.
  2. To move to an adjacent cell, select the Move selection after Enter check box, and then select a direction in the Direction box. To stay in the current cell, clear the check box
for our Symbol scanner we are using this apparently is not working, but it might for you!
How to move the result of a formula up or down one cell
go google and type in --manual for excel version (what ever it is ) and down load the pdf file
go to a book shop and buy a Excel for dummies book
or e-bay and excel for dummies or other excel explained books
explaining it as a reply will be as confusing as the reply would be pages long
Oct 13, 2015 | Microsoft Excel for PC
How do you combine three excel documents into one
For simplicity I'll assume each Excel document is one worksheet.
We'll call them Document1 Document2 and Document 3.
We'll move Document2 and Document3 to Document1
Open all three documents. In Document2 click the EDIT menu, then select MOVE OR COPY SHEET... In the box TO WORKBOOK, select Document1, then click OK.
In Document3 click the EDIT menu, then select MOVE OR COPY SHEET... In the box TO WORKBOOK, select Document1, then click OK.
If you have a mouse with right click you can do it as follows:
Open all three documents. In Document2 right click the worksheet tab and select MOVE or COPY. In the box TO WORKBOOK, select Document1, then click OK.
In Document3 right click the worksheet tab and select MOVE or COPY. In the box TO WORKBOOK, select Document1, then click OK.
Jun 17, 2011 | Microsoft EXCEL MAC UPGRADE 2008 Upgrade...
Scanner displays on a same row in excel how do I get it to automatically move the curser to the next line on my second code scan
If you would like the scanner to drop down to the next line scan the barcodes Scan Options, Data Suffix, Enter from the Quick Start Guide that should have come with the scanner. If you do not have the QRG then download the Product Reference Guide from this link:
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880806apdf&sliceId=&dialogID=134926365&stateId=0%200%2014579837
The barcodes are on Adobe pages 222 and 223 of 342 in this manual.
Oct 15, 2009 | Symbol LS2208 Handheld
Can we use cut copy paste in excel
You do not need to cut copy or paste to get this to work. If you click on the cell that the formula is currently in, you will see that the border of the cell changes and in the lower right corner of the cell there is a small square. If you move your mouse pointer over that little square your pointer should change to a small plus sign. Click and drag to the right and the formula will automatically change to the next set of cells.
Mar 27, 2009 | Computers & Internet
Tab key on keyboard will not work for moving across columns excel
You need to go into options, open the transition box and un tick the "transitions navigations key" box... This same problem has been ignoring me... You can also fix the double clicking problem in here too... under "edit"
Feb 02, 2009 | Microsoft EXCEL 2004 for Mac
Need the ability to "tab" from field to field on right of kybd
When you press ENTER to finish working in a cell, Microsoft Excel moves the cursor one cell down by default. However, you can select the direction in which you want the cursor to move.
  1. On the Tools menu, click Options.
  2. On the Edit tab, do one of the following:
    • To change the direction in which the cursor moves, select the Move selection after Enter check box, and then select a direction in the Direction box.
    • To keep the cursor in the current cell, clear the Move selection after Enter check box.
Note When a range or set of ranges is selected, pressing ENTER moves the cursor within the range or set or ranges only.
Jan 22, 2009 | Logitech Marble Mouse Trackball
Cannot insert columns in excel spreadsheet. Comes up with error cannot shift object off sheet
This error message occurs if the following conditions are true:
  • The option Nothing (hide objects) is selected in the Display options for this workbook section in the Excel Options dialog box.
  • You create an object, such as a cell comment, in any cell in a column.
  • You try to hide the column to the left of the column that contains the object, the column that contains the object, or all the columns to the right side of the column that contains the object. Or, in some cases, you try to insert a row or column in the worksheet.
There are two ways to fix this problem.
Method 1:  Temporarily toggle the option from "Nothing (hide objects)" to All In Excel 2007, temporarily toggle the option from Nothing (hide objects) to All, and then insert the rows or columns as needed. To do this, follow these steps:
  1. In the upper-left corner of the Excel window, click the Microsoft Office button.
  2. At the bottom of the menu, click Excel Options.
  3. Click Advanced from list of options on the left.
  4. Scroll down to the Display options for this workbook section, and then click All under For objects, show:, and then click OK.
Notes To use the keyboard shortcut to toggle this selection, press CTRL+6.
If these steps do not let you hide rows or columns or insert rows or columns in Excel 2007, try the steps in method 2.
Method 2: Change the position property of the object to Move and size with cells To work around this issue, Excel 2003, Excel 2002, and Excel 2000, change the position property of the object to Move and size with cells. To do this, follow these steps:
  1. If the object is a cell comment, select the cell that contains the comment, right-click the cell, and then click Show Comment or Show/Hide Comments. Note This makes the comment visible.
  2. Move the pointer to the edge of the object until the pointer changes into a white arrow with four small black arrows on the pointer. Then, click the object to select it.
  3. In Excel 2003 and earlier version of Excel, click <object name> on the Format menu. Note In this menu command, <object name> is the name of the object, such as "Comment" or "AutoShape."  In Excel 2007, click Format <object name>.
  4. In the Format dialog box, click the Properties tab.
  5. Click Move and size with cells, and then click OK.
  6. If you want to hide the cell comment again, right-click the cell that contains the comment, and then click Hide Comment.
  7. Follow these steps for each object in the affected column as described in the "Cause" section. When you hide the columns, you do not receive the error message.
For more information, visit the Microsoft Knowledge Base article: http://support.microsoft.com/kb/211769
Nov 06, 2008 | Computers & Internet
Excel
Highlight the cells you want to format. Move the mouse to the highlighted area, press the right mouse button and make sure the locked option is on under the protection tab.
Make sure protect sheet is enabled. To activate it, press the review under the menu options and select protect sheet (if its on sheet) or workbook for more than one sheet.
Sep 15, 2008 | Microsoft Excel for PC
EXCEL
It is very useful to learn excel shortcut realy i thank you
Sep 26, 2007 | Microsoft Office Standard for PC
Symbol LS2208 Handheld Logo
4,312 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
