Question about Refrigerators
Refrigerator is not level
My floor is not level, and the front legs are not enough to level it, how do i raise one leg even higher when its already fully extended
  • Anonymous Mar 14, 2014
    18'
    Scholar:
  • 66 Answers
You need to have this frig in a place that will allow the adjustment of the legs to level it. You may need to level the floor or move the frig to a different location. You can put one inch boards under the legs that are at the lowest partion of the floor and adjust it farther that way but truely the best way would be to level the floor.
Posted on Nov 14, 2008
How to make the freezer door on a kenmore elite 74033 tilt
Refrig of the year: Kenmore Elite 74033 Refrigerator
Consumer Reports Rated: Excellent
Hello Charles,
Just when I'm thinking Sears SERVICE is NOT some sort
of sad/bad joke... you put in a Kenmore Elite Model number...
continued search found your Owners Manual... Pages 10 & 16 are what you want
The front should be slightly higher than the rear to aid in door closing... (page 10)
Your refrigerator has two front leveling legs-one on the right and one on the left. Adjust the legs to alter the tilt from front-to-back or side-to-side. If your refrigerator seems unsteady, or you want the doors to close more easily, adjust the refrigerator's tilt using the instructions below: NOTE: Tools Required: 11/16" wrench or flat blade screwdriver.
1. Turn the leveling leg to the left to raise that side of the refrigerator or to the right to lower it. It may take several turns of the leveling leg to adjust the tilt of the refrigerator.
NOTE: Having someone push backward against the top of the refrigerator takes some weight off of the leveling legs. This makes it easier to adjust the legs.
2. Open both doors again and check to make sure that they close easily. If the doors do not close easily, tilt the refrigerator slightly more to the rear by turning both leveling legs to the left. It may take several more turns, and you should turn both leveling legs the same amount... (page 16)
`` After that...
All you have to do to maximize that efficiency is keep the closure area free of pizza boxes, ice cubes or errant frozen food bags.
Hope this was helpful...
Kenmore Elite 74033 Refrigerator Review Kenmore com
Feb 12, 2016 | Kenmore Refrigerators
How to level Admiral atf2110dr refrigerator
HS,
Most refrigerators have wheels in the back which are non-adjustable, and in the front they will have wheels and adjustable leveling legs. When I am setting up a new unit, I usually put a screwdriver handle under the middle of the front edge of the refrigerator to raise it up a little and run the leveling legs down until they touch the floor. This will give a little backward tilt to your refrigerator but it will also help your doors to close better. Hope this helps!
Jul 10, 2015 | Admiral Refrigerators
We have a Whirlpool refrigerator model EB9SHKXVQ02 that is not level. The front of the unit is at least a half inch higher than the back and we see four wheels but only one leveler on the hing. How do...
Place a cedar shake on the low side of the floor align with the rear roller, slide the unit into position and adjust the front leveling legs.
Oct 30, 2013 | Refrigerators
Vibrate on spin cycle
Most times this is a simple leveling problem. On bottom of all washers is little leveling legs, they turn out to raise and turn in to lower. Most the time as gravity spins, it is always better to have the front legs little higher the the back legs. Meaning have the back of washer a little lower then the front, it seems to carry gravity back and makes up for the gravitational force.
Apr 07, 2012 | GE Profile WPRE6100G Top Load Washer
The fridge door will not stay closed. I changed the gasket, tightened the door screws, cleaned the contact area and it still pops open.
After all the good ideas you've already tried, the next things on your list could be:
(a) level the floor under the fridge - they often sag under the heavy weight of a loaded fridge due to moisture/rot.
(b) level the fridge itself - using the leveling legs. If the fridge continues to have a problem with
the door poping open, try raising up the front of the fridge above level.
(c) unload the door pockets - making the doors lighter may help solve the problem.
Aug 17, 2011 | Refrigerators
How to level a Whirlpool Conquest refrigerator 2009 after moving it from a different house? The left front now wobbles.
To level your refrigerator:
Remove toe grill. Use flat-blade screwdriver or 3/8" socket wrench to adjust the front rollers. Or Turn the leveling leg clockwise to raise the side of the refrigerator or counterclockwise to lower it. Which ever applies to your unit.
Note: Having someone push backward against the top of the refrigerator takes some weight off the leveling legs. This makes it easier to adjust the legs.
Aug 04, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a samsung dryer front loading. it seems that the dryer is not balanced as it wobbles while drying. today the noise got worse, until i pulled the drum toward me then it went back to just wobbling. is...
It is nice these days as many washers and dryers are self leveling with just a little effort. The rear legs have the self leveling setup but if you dryer is old the adjusters maybe rusted. Try this... look at the front from a few steps back you will see the front two legs, they will probably be even. Unplug the dryer and slightly pull away from the wall, not to far as the dryer hose may disconnect. Tilt the dryer forward pivoting on the front legs (just raise the back a couple inches off the floor) and then let it drop. if the legs are self leveling this act may have leveled things. If the legs are rusted a little more aggression is needed maybe with the help of a parts solvent spray (56 or WD-40 etc.)
If your dryer is older then you have adjustable legs that need to be rotated one at a time until the dryer is level.
Feb 02, 2011 | Dryers
Need to get refrigerator levelled. How do I do it
Jan 16, 2011 | Refrigerators
Open door and whole unit moves, it dosen't come with back legs, or does it??
No most don't have rear legs. However, they usually will have front legs that screw down past the wheels/rollers to prevent it from sliding around under normal conditions.
You may have to remove the grill in the front (if present on your model) to adjust the wheels/rollers "up" out of the way while lowering the legs to level it, and they should also act as "brakes" to a degree if the floor/surface is relatively level.
Hope that helps,
Good Luck
Oct 31, 2009 | Kenmore 60721 Refrigerator
I work in a restaurant that uses a delfield upright.it has sliding glass doors on top,and solid doors on the bottom. it is a refrigeration unit only.the bottom door hinges are always falling off. i say its...
Yes. The unit should sit level.
Screw the front legs out to level it up.
If that does not give enough height,
Have someone help you tilt it to the rear and place small wood blocks under the front legs.
Mar 17, 2009 | Refrigerators
Refrigerators Logo
259 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
