Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Blackink wont print
I changed the cartg out and it still wont print
  • sgriggs37 Nov 14, 2008
    the printer is a 5300 easyshare aio
  • jbrooks857 Nov 15, 2008
    It did this before, I put in a new print head a in July, and have
    not used 2 black cartarges and no black again. Sent an e-mail
    maybe I can get another print head. I glad I did not scrap the old all
    in one from Hp
    Problem Solver:
  • 5 Answers
Remove and install the ink cartridges..then print a demo page (press photo and copy button at the same time)if the print of the text in the demo page is light or faded press the menu, scroll down until you see clean printhead then press the ok button, choose deep clean and press ok..after it clean try to print again a demo page and compare it to the other one if it has improvement try to perform again deep clean but if it has no impovement call kodak aio hotline 18004216699 and you might need a replaement printhead .
Posted on Nov 16, 2008
When printing on a card there is line across image
i think ur pring cartage is empty
so replace ur cartge
Jan 30, 2010 | Evolis Office Equipment & Supplies
Blackink wont come through
Try a deep clean
1 Start menu /control panel .printers faxes.
2 Right click printer icon
3 Select printer preferences
4 Click on maintanance tab
4 Click on head clean.
Aug 03, 2009 | Epson Stylus C46 InkJet Printer
Keep getting a U071 error message for cartge Y
Open the printer cover and check to make sure only one Yellow cartridge is installed. If so, try the following:
Remove each of the other cartridges, one at a time as necessary and see if the error message changes. Start by lifting the cover, then wait for the printhead to move to the left so you can access the cartridges inside. Pull out one of the other cartridges ( not Y) by pushing its front tab back then close the cover. Check the display, repeat as necessary. The error should have changed to U043 (bad or missing cartridge) once you remove the bad cartridge. When you replace it, the printer should work. My guess is the Magenta or Cyan cartridge is causing your error.
Apr 14, 2009 | Canon Office Equipment & Supplies
If theres a way print with just the blackink cartalidge just to see if this thing works?
yes.. once you click print.. you get printing options... look there and change to greyscale or ..just black and white
Jun 09, 2008 | Office Equipment & Supplies
Canon MP 460 re-filled cartridges
what I've done is buy two ink cartges and then you can fake out the printer by installing them back and forth between the full cart and the empty ones. I like the option of refilling the cartges. What I did was take the cartges out. drill a small hole it the acess hole so I could refill each ink color and reseal the hole up (with a small plug) took a needle and heated it up. to make a small air hole for the ink to be able to get out (breather hole). then set them aside. I then took the two other ink cartges and installed them. faking out the printer to think that it had new cartgrs in it. tried to print some pages then put the filled cartges back into them. Some times you might have to do this a couple of times but once it takes all you do is to make sure that the ink cartges are ALWAYS FULL. I have been running for some time without haveing a problem. I hope this helps
Jan 25, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Colour won't print - HP Deskjet 5150 Inkjet Printe
hi, remove the color cartg take a tissue paper and run it horizontaly on the nozzel, if u can notice the three colors, ur cartridge is ok, may be the contact area of the cartridge,try to clean both the surfaces, and install the exact driver for the printer which will give you the cartridge maintenence options. let me know??
Dec 16, 2007 | HP DeskJet 5150 InkJet Printer
Printing problems
hi, whenever u replace any of the cartrgs in the printer ,u first need to run the alingment procodure from the maintenence option, even if u have not replaced the cartg, run the alingment from the printer properties first, and then u can get a proper output. let me know
Dec 05, 2007 | HP DeskJet 5150 InkJet Printer
Can't print!
The problem is that the sensor that detects when the door is properly closed is sending the wrong "status" to the printer.
Find that sensor, and make sure that it is working properly.
Nov 09, 2007 | Office Equipment & Supplies
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
