Question about Zanussi Dryers
Need to get a rubber drum belt - Zanussi Dryers
Bought a new dryer
Posted on Nov 16, 2008
Won't spin
Sounds like a loose or worn belt, a bad drum bearing, or something is jamming the drum. The rubber smell is the drum belt slipping.
Sep 15, 2014 | Washing Machines
My kitchenaid washer has a burning smell
Hi, a slipping or severed belt will produce a burned rubber smell. A belt supports the drum and ensures its smooth movement. If it wears, the drum's movements weaken and finally come to an abrupt halt. In addition, a slipped or severed belt usually produces a burned rubber smell. Refer to the washing machine manual to review how to locate the belt. If the belt is no longer around the drum's center, shift the belt back to its original position. If rubber fibers are discernible or cracks are apparent, change out the worn belt for a new one.
Thank you.
Jun 05, 2012 | Washing Machines
My Magtag Neptune TL 6800 started making a horrible squealing noise then smoke started coming out of the washer. What do you the problem may be?
You need to replace the belt needed to spin the drum. It sounds to me like you may have been overloading the drum, putting too much stress on the belt. Over time, it has begun to " burn rubber" as it spins, causing smoke, or worst case scenario, the motor that turns the belt is locking up as the drum spins causing friction on the belt.
Aug 17, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Rubber band on drum keeps slippig off
The big rubber band is the belt. Check the idler pulley at the motor ,make sure the belt is threaded on the pulley right and the belt is where it should be on the drum. Don't know what model machine you have but check anything the drum rides on such as a pulley.Hope this helps.
Dec 23, 2010 | Maytag Washing Machines
Heating works but drum doesnt turn.
Try turning drum, or remove top from dryer to confirm if belt has gone. When turning drum there should be some resistance as the belt fits around the drum
Feb 18, 2010 | Whirlpool LER4634J Electric Dryer
Loud noices when running,some burned rubber smell
The only rubber part is the belt that drives the drum around. The belt rides on a tensioner which has a pulley on it with a bearing built into it. When the bearing goes bad the pulley will not turn freely causing the belt to get hot and smell. Its time for a new pully and bearing assembly for your dryer
Jan 31, 2010 | Dryers
Maytag washer, buring rubber smell, drum won't turn
the drum should run free if not the bearing have gone and seized they will need to be replaced. hear is a video there are others you can find the bearing kit on line using the model number https://youtu.be/WGolkFlgl3Y
Jun 22, 2017 | Maytag Washing Machines
Error code 004-321 on dell 3010cn
This error means that your Drum Cartridge belt isn't aligned properly or the sensor for it has become dirty.
Open the top of the printer and look inside. There should be a blue tab on the right side to unlock the drum assembly. Unlock it and lift the assembly straight up to remove it from the printer.
Now, look at the thing you just pulled out -- the drum assembly -- and you should see a black rubber belt. If you turn the wheels that operate it, you'll see that the rubber belt is not centered, so the sensor can't see the little silver plate.
Pull gently on the rubber belt to re-center it, then reinsert the drum cartridge and close up the printer.
Jul 13, 2009 | Dell 3010cn Laser Printer
HOW DO I ?
You probably need to thread the new belt over the drum by removing the circular rubber front seal temporarily. After putting the seal back on, ease the belt into the correct position and thread over the pulley on the motor. You will probably find it easier to put it over the pulley wheel of the motor first, with the belt partially off the drum. Then rotate the drum manually whilst easing the belt over it.
Mar 24, 2008 | Dryers
Dryers Logo
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
