Question about Viking VIPR161 Kitchen Hood
Won't stay up unless you hold button down and won't go down unless unplug!!
My hood is a couple of years old and just started not staying up unless you hold one of the 4 speed's button's down. It will only stop and operate on speed 1 but at least it works. To put is down you must unplug it and ten plug it back in, then it goes down. If you leave it pluged in it will go up and down all by itself every so often.
My benz won't stay running unless I hold the gas down constantly
sounds like a fuel pressure issue check fuel filter lines& linkage
Sep 04, 2012 | 1992 Mercedes-Benz Mercedes Benz 300 Class
Won't stay running. starts but then dies within a few seconds
clearly sounds like fuel starvation, I would be looking at the throttle body, they need servicing every couple of years, they fill up with like grease and block tick over hole.....
Mar 06, 2018 | 1991 Mitsubishi Montero
My Kenmore 80 series dryer won't stay on unless I
Aha!
You are going to make me guess!
I am guessing you have to hold the start button down.
So.
Try a new start button first.
If that does not fix it, replace the timer/control unit.
God bless your efforts.
Jan 05, 2018 | Kenmore Washing Machines
The power button on my Dyson DC19T2 won't stay on
The switch is broken. If you are handy, remove the old switch and match it up at a hardware store or a Vacuum repair shop. It shouldn't cost much to have it replaced by a proffessional either.
Nov 18, 2011 | Dyson Vacuums
How do I find the security code for my Matsui VP 9606 VHS Player
Try this
Unplug from wall for 30 minutes, then plug it in again. Power it on, and then PRESS CH UP & REC/QTR BUTTONS TOGETHER on your machine ~ (haven't tried it via the remote) Should then come up as "Pin OK" on the blue screen
I don't think it will give problems after that. Should stay unless you unplug for 30 minutes, the buttons won't reset the video.
Nov 17, 2011 | Video Cameras
I have a kenmore elite King size Quiet Pak II dryer that won't stay on unless i hold the button down and even when i do that the dryer is not getting hot.. Any suggestions would be...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 10, 2011 | Dryers
Kenmore 90 series dryer, the button to turn it on won't stay depressed unless you stand there and hold it down. is there a part i can get for it to fix it or should i just get a new dryer?
heatman101
Aug 11, 2011 | Dryers
WINDOW XP WOM'T SHUT DOWN
Hold the power button in for a few seconds it will shut down. Then unplug system and push the power button down with it unplugged then replug it in and power up again. Then do a proper shut down again to see if the problem fixed. I hope this assisted you. John
Feb 07, 2011 | Microsoft Windows XP Professional
I was doing about 55 mph when my truck stopped. it starts rite back up, but won' stay running unless you are pressing the gas as soon as you let off it dies out but will start rite back up
This is probably your cam sensor on the front passenger side of the engine on the front of the crank shaft get the part from the nearest dealer cost is under $40.00. It takes about 10 minutes. The timing pointer is part of the hold down for the sensor. Unplug the old sensor and undue the hold down bolt, twist back and forth as you pull it out. Reverse procedure to install new sensor.
Jul 20, 2010 | 2000 Ford F250 Super Duty Crew Cabs
One year old heater
Try to hold the button down for 30 seconds at least before turning the knob to ON.
If you are doing this and it still goes out after you let up on the knob, then it may needs a new flame sensor.
Jan 14, 2009 | Reddy Heating & Cooling
Viking VIPR161 Kitchen Hood Logo
26 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
