Question about Tappan TEF242 Electric Kitchen Range
Need owners manual for Tappan TGF334BCWb oven
I need to replace the igniter and need the manual
    New Friend:
Looking for Owner manual for a Tappan Gas Self Cleaning Oven Range - Model No. TGF 365BEWB
Posted on Jul 02, 2013
aborcass
  • 2651 Answers
SOURCE: need an owners manual
here it is
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/318200506en.pdf
Posted on Apr 04, 2008
huuum
  • 750 Answers
SOURCE: Tappan gas range burner ignition
Hello paultoledoWelcome to fixya.
I'm Huuum and happy to assist you,
You said, You got a 5-year old Tappan gas range. Two of the burners don't ignite, the other two and the oven are fine.
What do you need to do to fix the problem?
Sounds like a yes from where I'm sitting, your right on target, buying a new spark module will fix it.
That sounds like the spark modules.
I think you are correct!
Let me know if you need me!
Please remember to leave a solved rating!
Huum
Posted on Sep 24, 2008
duby1990
  • 370 Answers
SOURCE: Older Tappan range oven not lighting.
There is no way to light the oven manually. The gas valve will not open until the oven ignitor draws enough current. But replacing the ignitor will fix ya up.
Posted on Nov 19, 2008
  • 108 Answers
SOURCE: Tappan TGFS26C, Oven igniter not even
Lets take the oven problem first. Sounds like you have a Hot Surface Ignitor problem. This is the device that glows and lights the burner. You can buy a universal ignitor at most appliance or heating and air conditioning supply houses. Note carefully how the old one is mounted. You may have to make some adjustments to mount the new ignitor, but it MUST be close to the gas burner like the old one! You don't smell gas because the gas valve will not open until the ignitor is hot. All ignitors work with the same voltage, so simply connect the new wires to the old ones.
I'm not certain if you have a standing pilot for the stove top burners or electronic ignition. Remove the top panel to check. If you have a gas pilot, relight it. If electronic ignition, clean the ignitors. If that does not solve the problem you may have to call a technician, as these systems can be complex.
Hope this helps.
Ray
Posted on Nov 22, 2008
SOURCE: Tappan Millennia Stove/Oven
I have a delay when trying to turn on to use the over, then an exploding sound. What is this? Is the ignitor going bad?
Oak Park, IL
Posted on Jan 04, 2009
Desperately searching for User Manual for Tappan Wall Oven Model 12-4990-00-04.
Hello Owner, thank you for your inquiry!
I understand that you need the use and care manual for your Tappan wall oven, 12-4990-00-04. If the model is older than ten years old manufacturers will not keep that information available. You might be able to perform a search for antique models online for any additional information. -Matt
Jan 11, 2016 | Frigidaire Ovens
TAPPAN GAS RANGE MODEL NUMBER MPF500PBWD
the owners manual will not give you any repair info. Only use instructions. Your model has an oven safety gas valve that opens only after the secondary pilot heats the end of capillary properly. You may need to clean/replace the pilot assembly OR replace the oven safety valve. If you need the valve, look on ebay because these things are over $275 from Tappan.
Aug 21, 2014 | Tappan MGF500PBW Gas Kitchen Range
Indesit oven keeps heating
Tappan gas range, TGF334BCWB. I can NOT stop the broiler burner from lighting. I have unplugged the 110 power and I light top burner with a striker. However when stove is plugged in to the power the broiler burner lights and continues to burn. The oven knob is turned OFF. The only way to stop the broiler is to unplug the power.
Mar 11, 2014 | Whirlpool Accubake SF362LXTS Kitchen Range
Tappan built in oven display not working
Find the owners manual and check to see if it has a sabbath day mode if not you will need a oven control which has the display assembly
Mar 17, 2013 | Tappan Ovens
User manual for a Tappan mod TMV151FS
You can download your owner's manual here.
Jan 01, 2009 | Tappan Microwave Ovens
Nov 19, 2008 | Tappan TGF320 Gas Kitchen Range
Tappan Series 110 Gas Stove Owners Manual
stovetop works well, oven will not ignite. Whats up?
Feb 04, 2008 | Kitchen Ranges
Tappan - Model 36-3052-23
I suspect you may have a bad igniter. They will still glow nice and hot, but if they are weak the gas valve will not open. This is actually a safety feature. Depending on which type you have, the glow bar igniter is supposed to draw a certain current potential before the gas valve will open. Here's the current readings for both types: Round Glow Bar: 2.7 to 3.2 amps Square Glow Bar: 3.2 to 3.7 amps I would try to to determine if the igniter is good or bad before proceeding with a gas valve replacement. Generally, the igniter is a common fail item. Let me know if this helps.
Sep 06, 2007 | Tappan MGF500PBW Gas Kitchen Range
Tappan TEF242 Electric Kitchen Range Logo
292 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
