Question about SanDisk Sansa c200 MP3 Player
Freezing at refreshing database
After downloading music it froze at refreshing database, how do i fix it?
  • dantweinstoc Dec 20, 2008
    unplugged from computer then stuck on refresh playlist screen
  • 8,596 Answers
Download the Sansa Firmware Updater and update the firmware - available from Sandisk's website.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Feb 28, 2009
Refresh freeze
hello Mr .
You Can Download Free MP3 From Youtube By This Site : video2mp3.net
If you didn't found Your Favorite Music In Youtube Try These Sites : Beemp3.com or 4shared.com
Jun 25, 2009 | SanDisk Sansa e260 MP3 Player
Frozen sansa at refresh database
This is from the Sansa Website at http://www.sansa.com/support/sansa_e200/faqs
My e200 freezes on the “Refreshing Database” screen
STEP 1 – Reset the device
  1. Press the Power button and hold it for approximately 10 seconds.
  2. Release the Power button once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware Updater
I this helps please dont forget to rate my answer.
Mar 07, 2009 | SanDisk Sansa c240 MP3 Player
Sansa clip is stuck on Refresh Database Screen.
1ST: Just try to 'reset' by holding down the main center button AND pushing UP on the lock/off-on button, for about 8-9 seconds,
It will then 'refresh' the database, shouldn't lose anything,
OR:
MANY problems can be fixed ultimately by the following;
REFORMAT the SansaDisk Clip by finding it in My Computer and right click then just 'format' the thing. THEN drag and drop new music into it (or books), DRAG and DROP, you apparently erase the thing with a 'FORMAT' ....BUT - it's .sys files remain and it is like new {as in empty}
This usually fixes almost anything, should even erase a virus (I'm guessing) but shouldn't hurt it.
Good Luck!
-simple 'drag and drop' from my MUSIC folder seems to work just fine for me...
Jan 02, 2009 | SanDisk Sansa Clip MP3 Player
Add music and refresh database to sd card
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Aug 10, 2008 | SanDisk Sansa e200 MP3 Player
Refresh database (frozen )
Connect your mp3 player to your PC then turn it off by holding power button until it shuts off, switch the hold switch to HOLD then press and hold the REC button on the side until the mp3 player shows a black screen and your PC shows that it found a 16mb removable media, now download the file from the below link. Run it and it should fix your problem, but note that all your files will be erased.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
Jan 22, 2008 | SanDisk Sansa e250 MP3 Player
Refresh data base freezes
If your SanDisk is locking up try holding the power button down. It will force it to shut down. If you continue to get that error you probalby need to update/reload the firmware. Check out the sandisk.com website. Go to the music and video link and then select forums under support. If memory serves me correctly I had to download the file to my PC and then copy it to my Sandisk to get it to load. I lost all my songs but it fixed the problem.
Dec 19, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e280 froze
It is probably because you have folders inside of folders inside of folder... i just had the same problem and copied all the songs in a folder into the main folder IE
dont do this
sansa>music>artist>album>music file
do it like this
sansa>music>artist>file
Dec 04, 2007 | SanDisk Sansa E280 MP3 Player
Frozen screen says: refresh database
tyr taking the battery out or try holding the power button and the play button at the sametime for 20 secs.
Oct 21, 2007 | SanDisk Sansa e260 MP3 Player
Frozen in refresh database
download some firmwire from http://sandisk.com/Retail/Default.aspx?CatID=1376
Aug 15, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa  c200 MP3 Player Logo
83 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
