Question about HP Office Equipment & Supplies
I am trying to change the number of rings for my fax to respond on my officejet 6210 all-in-one. The manual says to click on setup and and press 4&3. Nothing happens. Am I using the right set-up or what?
  • a1134w Nov 14, 2008
    Is 6 the highest it will go? I need at least 8 rings!!
  • HP Master
  • 1,879 Answers
  1. Press Setup.
  2. Press 4 this selects Basic Fax Setup and then press 3 to select Rings to Answer .
  3. Type the desired number of rings.
  4. Press OK to save the settings.
Posted on Nov 14, 2008
  • monk3ybidzness
    monk3ybidzness Nov 14, 2008
    Maximum Rings To Answer is 6, adjust / lower down the other device rings to answer.
  • monk3ybidzness
    The answering machine must be on the same phone line as the
    all-in-one.
    The answering machine must answer the call FIRST before the
    All-In-One.
    The number of rings to answer for the All-In-One should be GREATER than the number of rings to answer for the answering machine.
  • 73 Answers
You should press 4 and then press 3
BUT!!!
notice that this setting will work only if your printer is set to receive faxes automatically
  • HP Master
  • 13,433 Answers
YES, press setup, then press 4 and then press 3 and follow the instructions
    Scholar:
  • 181 Answers
On printer control panel, select setup, then select #4 (basic fax setup), then #6 (ring & beep volume). Select OK, then press either the left or right arrow until uthink the number of rings u want have been seen on that appears - then press OK.
  • 1 more comment
  • fixyy Nov 14, 2008
    after you followed that step follow this as usual
    To set the number of rings before answering from the control panel
    1 Press Setup.
    2 Press 4, and then press 3. This selects Basic Fax Setup and then selects Rings to Answer.
    3 Enter the appropriate number of rings by using the keypad.
    4 Press OK to accept the setting.
    ok should be pressed after u select the settings or it will not work as u setted.
    Set the number of rings before answering You can specify how many rings should occur before your HP all-in-one automatically answers the incoming call. Note This setting only applies if your HP all-in-one is set to receive faxes automatically. The Rings to Answer setting is important if you have an answering machine on the same phone line as your HP all-in-one. The answering machine must answer the call before your HP all-in-one. The number of rings to answer for the HP all-in-one should be greater than the number of rings to answer for the answering machine. For example, set your answering machine to answer in 4 rings and your HP all-in-one to answer in the maximum number of rings supported by your device. (The maximum number of rings varies by country/region.) In this setup, the answering machine will answer the call and the HP all-in-one will monitor the line. If the HP all-in-one detects fax tones, the HP all-in-one will receive the fax. If the call is a voice call, the answering machine will record the incoming message.
    follow this procedure to test your fax set up
    Test your fax setup You can test your fax setup to check the status of your HP all-in-one and to make sure it is set up properly for faxing. Perform this test after you have completed setting up your HP all-in-one for faxing. The test does the following: Checks the fax hardware Verifies that the phone cord is plugged into the correct port Checks for a dial tone Checks for an active phone line Checks the status of your phone line connection The HP all-in-one prints a report with the results of the test. If the test fails, review the report for information on how to fix the problem and rerun the test. To test your fax setup from the control panel
    1 Set up your HP all-in-one for faxing according to the setup instructions in this chapter.
    2 Make sure you have inserted the print cartridges and loaded paper before starting the test. For more information, see Replace the print cartridges and Load full-size paper.
    3 Press Setup.
    4 Press 6, then press 5. This selects the Tools menu and then selects Run Fax Test.
    thanks.
How can I set my ring number in my phone and my fax machine before answering?
1. Press Setup.
2. Press 4, and then press 2.
3. Enter the appropriate number of rings by using the keypad, or press
change the number of rings.
4. Press OK to accept the setting.
this is link to the manual for your model http://h10032.www1.hp.com/ctg/Manual/c00644922.pdf if you like to learn more for your device.
Sep 19, 2011 | HP Officejet 4315v All-In-One InkJet...
Hi my hp 640 will not answer a fax call, but will answer only if we pick up the hand set.
Issue When the all-in-one product is sharing a phone line with voice calls, some calls are interrupted by fax tones. Follow the steps below to solve the problem.Step one: Check the Rings to Answer setting If Auto Answer is enabled, the HP fax product will answer the phone line when the number of rings reaches the number of rings specified in the Rings-to-Answer setting. When voice calls will be received on the same phone line as faxes, set to rings-to-answer to 6. If you do not want the fax to answer automatically, either turn off Auto Answer from the front panel and receive faxes manually (this may result in lost faxes) or subscribe to a distinctive ring service from the phone company (if available). Refer to the Answering faxes manually section below to learn how to answer faxes manually or refer to the Using distinctive ringing section below for more information about using distinctive ringing. The Rings-to-answer setting for the HP Officejet 500 and 600 series products can only be checked or set using the all-in-one software on the computer. The Rings-to-answer setting for the HP Officejet 500 and 600 series products can only be checked or set using the all-in-one software on the computer. Follow the steps below to check or change the setting for all models except the HP Officejet 500 and 600 series:
  1. Depending on the model, press either Menu , Setup , or Fax Setup repeatedly until Basic Fax Setup appears in the display.
  2. Press Enter (or Start or OK ).
  3. Press the right arrow button repeatedly until Rings to Answer is displayed, and then press Enter .
  4. The number of rings before the HP fax product answers will be displayed.
    • The setting is correct if it is 6. Press Cancel or Stop (Stop Fax) to exit the menu.
    • If the number is not 6, press the right arrow button until 6 appears in the display and then press Enter (or Start or OK ).
Aug 30, 2011 | HP 640 Inkjet Fax Machine
HP L7650 will not auto answer incoming faxes
To set the answer mode to manual or automatic via the control panel
? Press Auto Answer to turn the light on or off, as appropriate for your setup.
When the Auto Answer light is on, the device answers calls automatically. When
the light is off, the it does not answer calls.
To set the answer mode to manual or automatic via the embedded Web server
1. Open the embedded Web server, click the Settings tab, click Fax in the left pane,
and then click the Basic sub-tab.
2. Select On or Off in the Auto Answer drop-down menu in the Other Basic Fax
Settings section.
If you turn on the Auto Answer setting, you can specify how many rings occur before
incoming calls are automatically answered.
same phone line as the device, because you want the answering machine to answer
the phone before the device does. The number of rings to answer for the device
For example, set your answering machine to a low number of rings and the device to
answer in the maximum number of rings. (The maximum number of rings varies by
country/region.) In this setup, the answering machine answers the call and the device
monitors the line. If the device detects fax tones, it receives the fax. If the call is a
voice call, the answering machine records the incoming message.
To set the number of rings before answering via the control panel
1. Press Setup.
2. Press Basic Fax Setup, and then press Rings to Answer.
3. Enter the appropriate number of rings by using the keypad, or press the left or right
arrow button to change the number of rings.
To set the number of rings before answering via the embedded Web server
2. Select a number in the Rings-to-answer drop-down menu in the Other Basic Fax
Settings
section.
Dec 02, 2010 | HP Officejet Pro L7650 Printer
How do I set number of rings on Hp Officejet J3680 All In One Printer?
1. Press Setup.
Also make sure the Auto-Answer button is on to receive fax automatically
For more information or to download the manual for your printer - Click here
You can save the manual on your desktop by clicking the SAVE ( floppy disk icon )
Oct 21, 2010 | HP J3680 Officejet All In One Printer
How do i get a fax confirmation sheet from my 6210 all in one ?
I have a 7310xi All in One...this is how I do it.
1) click the setup button
2) Select 2. Print Report
3) Select 1. Fax Reports Setup
4) Choose from1-6, I chose (4) Every Fax
Press OK, then cancel to get out of setup.
Jun 07, 2010 | HP OfficeJet 6210 All-In-One InkJet...
My machine won't receive faxes! I can't figure out how to set the rings incoming to make it work
Page 18 of the manual describes how to setup the fax Page 39 of the user manual - see link below to user manual - and I have also copied instructions at end of this post
Direct link to the manual http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=uk&lang=en&os=2093&product=441125&
Heres the support site for your machine http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=uk&cc=uk&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=Officejet+5610+&submit=»
  1. Press Setup.
  2. Press 4, and then press 3. This selects Basic Fax Setup and then selects Rings to Answer.
  3. Enter the appropriate number of rings by using the keypad, or press or to change the number of rings.
Apr 07, 2010 | HP Officejet 5610 All-In-One InkJet...
Nedd to change fax ring pickup
Page 79 of the user manual shows you how to change a number of settings - see the link to user manual below
  1. Press Setup.
  3. Enter the appropriate number of rings by using the keypad, or press the left or right arrow button to change the number of rings.
The setup and user guide available here http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=ph&product=2512010&lang=en&
direct link to the user manual http://h10032.www1.hp.com/ctg/Manual/c00863866.pdf
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 31, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
How to use with ansering machine : can I setup an ansering machine on the same phone line as my hp officejet 6210 all-in-one
Hi
Yes I use the same line for Fax. But my printer not same as yours.
I have just put on my website to download for you.
Just click on the links it will download for you.
It got all you need to know in this file.
You can read it on site and print it strait off the website or save it to your PC then print it out.
Click LINK= http://www.4all2sell.com/pdf/HP-OfficeJet-6200-6210-Manual.pdf
You will need an adobe reader to see this file If you not got an Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 05, 2010 | HP OfficeJet 6210 All-In-One InkJet...
HP Officejet 6210xi All in One
You can actually change the fax header by following the steps:
1, Press on SETUP button on the printer, then scroll down using the ARROW RIGHT BUTTON;
2. Look for Basic Fax Setup, then press okay;
3. Under Basic fax setup, scroll down and look for FAX HEADER, then press okay.
4. From that option, it will allow you to change the informations for the fax header.
please let me know if the steps i gave to you is a big help.
thank you so much.
adonscott
Jul 23, 2008 | HP OfficeJet 6210 All-In-One InkJet...
I need to change the ring time on my 6210- how do I do it?
Press the Setup button on the control panel > press ok > go to Basic Fax Setup > press ok > go to Rings to Answer (choose Rings 2) .
Thanx
May 13, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Ben Johnson
