You may have fuses under the dash on drivers side as well as a fuse box in the engine compartment. Good luck. Ps you should pull the fuses one at a time and check for continuity.
If the anti theft light is blinking and you say that everything else fine.. My first thought is that the key is not programmed to the vehicle. The key has a internal chip that must be programmed to vehicle in order to start. Now my other question is, Is the key your using for the vehicle the original key or have you just recently had a key made? Regardless, in order for the yur Tribute to start, the key. Or keys have to be program to vehicle by your neighbor dealership. Thats the reason for your anti theft light is blinking
Are you sure you checked ALL the fuses? For multiple items to not work at the same time, it has to be the Power going into that particular system... I would check your Fuses again
It sounds to me like you may have a defective dimming switch. Are the instrument cluster lights working as they should? Do they dim/brighten with the dimmer? If the instrument cluster is working OK, then it could be an internal problem in the radio unit itself. Your panel lights are computer controlled. The processor in the instrument panel controls them. It uses a digital signal to "tell" the radio to either dim or brighten its lights. If the radio is failing to do so, the radio is the most likely cause since the lights work on "full power" which is also commanded through the same data lines. (this eliminates the signal from the cluster and the connection through the data lines.)
Lighting of the lcd ? Could be an internal radio component. Check the web - seems to be fairly common with the radio ( made by Panasonic) where there is a small resistor that gets fried and results in the loss of the lighting . The CD changer also has problems.. I should know.. It happened to my 03 Accord also.. You can get a remanufactured unit on ebay for < $100 . Also, there are online tutorials on how to remove the radio. Good luck
