Question about Amana 30 in. ACC3660AS Gas Cooktop
Connecting new fan/motor assy
From the capacitor there is a black wire and brown wire that I assume are speed control wires.
The motor has a yellow/green wire (ground I think) a black wire (hot) a blue wire and a brown wire.
From the power source there is a green wire, white wire and black wire.
I have figured out the brown of the capacitor goes to the brown of the motor, the green/yellow wires connect together. Now I have the blue wire, and black wire, of the motor and the black wire and white wire of the power source. Does the black from the capacitor connect with the black of the motor and the black of the power source? That leaves the white in the power source and the blue from the motor. Do they connect?
    Problem Solver:
  • 7 Answers
A capacitor is typically inline with your power source and stores a large amount of power to supply bursts of power when heavy draws occur. it sits between the source and the motor so you should have the (source - capcitor - motor) hot wires all conecting at the same place. The other wire on the capacitor should be the ground (if they have +/- markings use the negative as the ground).
Posted on Nov 14, 2008
Helping a friend install a new unit... he has 3 wires where we took out the old unit (the old unit had 4 wires) .. the (source) 3 wire is black, white & bare.... the old and new unit have black, red,...
I suspect on teh wiring from the house the black&white will be the hot wires and the bare will be ground/neutral
use a volt meter before connecting tonew cooktop and check for;
black/bare to have 120volts
white/bare to have 120volts
if that is what you find...connect new cooktop as such;
black to black
red to (house) white
(cooktop) white and green to bare
GENE
Sep 07, 2011 | Whirlpool GJC3034 Electric Cooktop
Do the 2 black wires go with the live brown wire?
The two black wires went to live, brown and blue to neutral and the earth as normal. This was for an induction hob.
Feb 05, 2010 | Cooktops
Hello: I am trying to replace a cooktop (installing a used cooktop - GE model# J P651 002 AD). My problem is making sure I understand the wiring connections. The cooktop has a black, a red, and a green...
The green goes to the bare ONLY.
Likely the black was used as a neutral and the reds were 240 volts.
You need to investigate at your panel. If you see the black going to the neutral bar, abandon it by capping with wire nut. If you see both the reds going to adjacent terminals on a double breaker, connect one red to the red and the other red to the black of the cooktop,
Oct 07, 2009 | GE 30 in. JP328 Electric Cooktop
Just installed a new Jenn-Air Model JED8430. Burners work well but fan will not turn on. Two black wires and a ground coming out of my wall....presumedley no neutral. Any suggestions
I suspect that the two black wires were attached to a wall switch or a wall times, along with the ground.
Check to see if you have a hot wire there. then temporarily wire the two black wires together and see if the fan comes on, i believe it will.
Jun 13, 2009 | Jenn-Air JED8430 Electric Cooktop
Jenn Air Cooktop wiring issue.
Thank you for your enqiry!!
Mar 21, 2009 | Cooktops
Burners not working but fan is
Are you sure that is the proper wire from the wall? What you are describing is a 110 volt circuit. THis cooktop should be connected with at least #10 wire and fused at 30 amps. You should have black red and at least white with possible bare ground wire. Assuming somebody used the wrong wire during original install job, you have it connected right. Please replace with heavier wire if it is not #10 Or at least make sure it is fused at no more than 20 amps if smaller wire. (You may sometimes blow circuit breaker if all burners are used on high at once) Use a volt meter and check voltage. If this is a 220 volt circuit you should have 220 volts between black and white and 110 volts from either one to bare ground wire.
Jul 02, 2008 | Jenn-Air JED8430 Electric Cooktop
Old jennair cooktop
The wiring diagram is pasted on the inside of the panel you remove to get to the wiring. If no wiring diagram The blower operates on 110 volts not 220 So the wire goes from one of the hot sides (Black or red) to the switch controlling the fan to the motor , from the motor to the neutral (white/Bare) wire terminal. Pilot light for fan is attached to the same wires as the motor. If you don't know what you are doing disconnect all wires from the burner switches to the fan motor. This will mean you have to switxh on the fan yourself whenever you need it.
Jun 25, 2008 | Jenn-Air JED8230 Electric Cooktop
Wiring a cooker top
Thios induction hob (Electrolux) has 4 wires - Y/G, brown. blue and black.
The Y/G is obviously the Earth conductor, and I would assume normality says that
Brown is the live conductor and Blue the neutral conductor.
The quandry is whether or not to disconnect the black wire completely, as this appears to have no function in a domestic wiring circuit.
Regards, Albert.
Oct 27, 2007 | GE 30 in. JP326 Electric Cooktop
Wiring installation
You do need a 208/240 volt supply from your service panel. The green is ground, white is nuetral, and the red and black should measure 120 volts each to ground or 240/208 between each other. It is normal for most breaker panels to supply 208/240 between adjacent insulators. If you are only getting 1/2 of that then the circuit breaker may not be straddling the insulator bar but be 1/2 notch out and both breaker pins contacting the same 110 supply.
Apr 14, 2007 | Jenn-Air JED8430 Electric Cooktop
Amana 30 in. ACC3660AS Gas Cooktop Logo
173 people viewed this question
Top Amana Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Thomas Perkins
Thomas Perkins
Are you an Amana Cooktop Expert? Answer questions, earn points and help others
