Question about Olevia LT37HV 37 in. HD-Ready LCD Television
Crackling noise Olevia 37" hdtv crackles. It's wall mounted with cable tv. How can I stop crackling? TV is about 1 year old.
  • 1 more comment
  • lslovik Nov 14, 2008
    They are built in speakers with component wiring
  • lslovik Nov 20, 2008
    I solved my own problem as you can see I posted it and I solved it. Thank you.
  • smackey74 May 11, 2010
    are the speakers built in or are you runing an external sound system?
I think I have solved the problem. I dusted the tv completely. Then took the cable box and with a hair dryer in the cool setting blew out the interior circuits to try to remove all dust. Turned the set on no more crackling. Thanks for the posting.
Posted on Nov 17, 2008
Crackling noise in my tv
That means the End is near ,,,sorry man , dust ,,water ,,shocked ,,(ie) falling ,,,hard hit ,,, internal damage ,,,
Mar 15, 2015 | LG Electronics 60PA6500 60-Inch 1080p...
First of all, sorry for the mix up on model the model #. I was viewing a problem regarding LG LCD TVs and found your link. My problem is with an LG 42LGX LCD HDTV. It has worked fine without any issues...
welcome to fixya and thank you choosing my service..
OK,that is the most and common problem of all LCD TV...
Usually dim and totally have no back-light is cause of bad inverter board.One of the inverter board is shorted that cause dim light and crackling sounds..
This are the sample images of inverter board.
to make sure that the problem is on the inverter board kindly try to disconnect/unplug it from your TV and power ON then observe if the crackling sounds remain or not..If the crackling sounds gone replaced the inverter board..Also I need to how many inverter board you have? if 2 or more disconnect it one by one to determine if where is the specific faulty inverter board..
Example:
I disconnect #1 inverter still have crackling sounds..next disconnect #2 inverter and reconnect the #1 inverter until you found the faulty one..Note when you doing this make it sure you power off the TV before you unplug or disconnect inverter board because its high voltage..
I need the picture your TV screen..just send it to chesterpendilton@yahoo.com
Regards.
Chester
Jan 20, 2012 | LG 42LC2D 42 in. LCD HDTV
Speaker problems. Crackling sounds like theres a short
Check your HDMI cables, does it do it on other video sources like component or cable in? If not you can single out a single cable.
Otherwise a loose wire in the tv could cause it.
Mar 03, 2011 | Dell W3706MC 37 in. LCD HDTV
TV makes very loud crackling noise
crackling in the speakers of 42"flat screen tv
Jul 20, 2010 | LG 42LC2D 42 in. LCD HDTV
My 37" TV
if the set has a headphone socket try that with some headphones if noise vanishes then is probably a loose speaker nacelle if noise is in headphones this is a set issue check all connections are good my set occasionally gets a loose hdmi connection this affects the sound badly.
Feb 17, 2010 | Akai LCT3785TA 37 in. LCD HDTV
WHEN I TURN ON THE TV ITS MAKES A VERY LOUD CRACKLING NOISE.
If you have lost your freeview channels & your picture has been breaking up (pixelating / freezing) etc as well as crackle on the audio, then I would suspect you check your antenna, it could be your incoming signal is weak which would give you these problems.
Aug 13, 2009 | LG 37LH55 37 in. LCD TV
Crackling noise
my flatscreen LG television crackles all the time, what can I do to stop it?
Feb 20, 2009 | Insignia 42" LCD Flat-Panel HDTV
TV SCREEN GOES BLANK
Yes your inverter is bad, I have the same problem my set is about 1 and 1/4 years old. Because Olevia makes a terrible product there inverters are attached directly on to the panel, which means they will only sell the inverter along with the panel i.e $700+ to replace + $100 dollars labor if u don't know how to fix it ur self. I am currently searching to find the manufacture that makes the inverters because olevia will not disclose that information. I believe it is darfon, if so the inverter should cost about $150-200 depending. If you dont believe you can fix it ur self ur best bet is try and sell the set for scrap take ur $100 or so dollar and buy a quality product! Oh and dont call there support they will tell 10 different things before u find out this long for seen truth!
May 04, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Olevia LT37HV 37 in. HD-Ready LCD Television Logo
580 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
