Question about Regal Ware K6725 Kitchen Pro Bread Maker
Regal 6725 belt
To the person who says their belt has stretched: Can you please measure your existing belt and tell me the dimensions? (circumference and width) Mine disintegrated, so I can't measure it. There is a belt supply house online and if we can figure out the dimensions we can order from them. This belt is ridged, so I don't know how well that o-ring would work, since that is smooth. The online supply house does have ridged belts and I think they have the size we need.
  • threeks3 Feb 19, 2009
    Is the Regal Kitchen Pro breadmaker's belt ridged and is it 24 inches? How do you get it on?
  • 3 Answers
I too am looking for a belt. I have measured the circumference and it is 24 in. My belt also disinigrated so I don't know about the width. I think it would be about 1/4 in. Where are you finding these at? Please email me @ EM_920@msn.com
Posted on Nov 21, 2008
Need drive belt for a AKAI GXC-709D tape recorder, .015 thick x .150 widex4" D. full circle
Take these measurement and either look on the MCM Electronics web site or Mat Electronics web site. The Diameter does not help much the measurement they use is Inner circumference or IC. The IC is near double the length id the belt is pinch and measured on a scale. Also allow for the belt being stretched so you may need a belt 5-10% less than the old one.
If you can not figure this out then just contact Marrs Communications and tell him the model and he will have the belt kit but this is more expensive.
Feb 06, 2013 | Audio Players & Recorders
I have a Troy-Built Rototiller, 7 HP OHV, PONY. The drive belt for the tines is broken and I don't know what size belt to replace it with.
Belt sizes denote the circumference of the belt. Since your belt is already broken the easiest thing for you to do is measure the length of the belt using a tape measure. Get a belt that matches your measurement to the closest inch rounding down to allow for stretching of the old belt.
May 31, 2011 | Garden
Disk drawer will not open
A small motor turns a belt, which then drives the gear that operates the drawer. Over time this belt stretches or breaks, and the drawer doesn't open. Replacing the belt cures the problem.
I've looked at the couple of belt catalogs I have, and nothing for NAD is listed. You'll need to measure the old belt circumference and thickness. Almost all of these are square belts, usually in the range of 2.5 to 3.5 inches circumference. If you're measuring the old belt, take off 10 to 15% since it has stretched.
A local electronic service shop may have a suitable replacement. Otherwise there are many sources online (MCM Electronics is one I deal with frequently here in the US). In a pinch, you can even use a small rubber band until you find the right replacement.
Hope this has helped. Thanks for using Fixya!
Feb 12, 2010 | NAD C542 CD Player
Regal Ware Kitchen Pro Breadmaker model6725 belt
You can order both here:
http://www.vendio.com/stores/breadmakerguru/category?top_searchString=6725+regal+ware&searchString=6725+regal+ware
Nov 25, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
The drive belt on my kitchen pro breadmachine has broken. Its a toothed belt and I have not got the model #
Is it a Regal Kitchen Pro? If so, it should say so on the housing of the machine.
Follow the instructions on how to measure for a belt below. I used yarn because it gives a little, and just using a measuring tape would not give as precise a measurement.
Remove the safety cover from the bottom of the machine, exposing the wheel and drive shaft (it's easy, that's all you will see, those two parts) and run yarn around them, pull it snug, knot it, cut the yarn, remove the yarn, stretch the yarn a little on a measuring tape or yardstick, that is the length belt you need. If your machine is a k6725 it will measure 23 and a half inches. Proceed as below.
If the measurement is different, you have a different model, maybe. Google the measurement you get and the words bread machine belt, and see what you can find. Good Luck, read below how I fixed my Regal machine, which I got for free, with an Oster belt, for $14.90.
My Regal Kitchen Pro 6725 Breadmaker belt was in tiny rotten pieces...I wound a piece of yarn around the wheel and drive shaft (lie the machine on a kitchen counter, lid open and hanging down off of the counter, bottoms up, and remove the screws from the teardrop shaped brass colored safety cover, remove the cover and expose the wheel and drive shaft) pull the yarn tight and knot it. Then cut the yarn about an inch from the knot. Measure the yarn when pulled on a little. Mine measured 23.5"....I then googled bread machine belt 23.5" and up came one for an Oster Bread Machine (The one I was repairing was a Regal Kitchen Pro 6725) from totalvac.com located at 2 De Bush Ave Unit A8 Middleton, MA 01949
It was $7.95 for the belt, $6.95 S & H to a VA address, total cost $14.90 so I decided to give it a shot. When it got here, I removed the safety cover, held the machine up and shook as much of the old rotten rubber belt pieces out as I could, and replaced the belt by placing it over the sticky string on the drive shaft and teasing it over the wheel. It is an exact fit. Be sure the ribbed side of the belt is down against the wheel. Screw the cover back on and run it through a dough cycle so that the belt will get coated with the sticky stuff from the sticky string on the drive shaft. Until the belt is coated, it will turn the mixing blade, but it will slip. Hope this helps. Patti
Patti Wilson
September 2009
Sep 13, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
Need manual for regal kitchen pro breadmaker model 6725 and recipes
Please follow the link below to access a PDF copy of the manual for the Regal Ware breadmaker model 6725:
http://www.regalware.com/documents/Breadmaker_Books/K6725_3rd_setting_sweet_Breadmaker_Guide_Cookbook.PDF
Pat Seitz
Director, Communications
Regal Ware, Inc.
Sep 08, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
Regal Kitchen pro breadmaker turns on, drive shaft doesn't move
Remve the safety cover as instructed below and turn the machine on to see if you have a belt anymore (they rot) and if the drive shaft is turning...
Hi, I have the same machine and the belt was in tiny rotten pieces...I wound a piece of yarn around the wheel and drive shaft (lie the machine on a kitchen counter, lid open and hanging down off of the counter, bottoms up, and remove the screws from the teardrop shaped brass colored safety cover, remove the cover and expose the wheel and drive shaft) pull the yarn tight and knot it. Then cut the yarn about an inch from the knot. Measure the yarn when pulled on a little. Mine measured 23.5"....I then googled bread machine belt 23.5" and up came one for an Oster Bread Machine (The one I was repairing was a Regal Kitchen Pro 6725) from totalvac.com located at 2 De Bush Ave Unit A8 Middleton, MA 01949
Patti Wilson
September 2009
Aug 06, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
Machine frozen
Read this on how I fixed a Regal Kitchen Pro 6725 with an Oster belt. Regal no longer makes or sells parts. My bread machine made all of the right noises, but the mixing blade did not move.....upon investigation, I learned that the drive belt had completely disintegrated. I measured for the length of the belt, found that an Oster belt would be the same size and length, and installed it. It works. I hope this helps you.
image_icon_name.gifPatti Wilson
image_icon_date.gifSeptember 2009
Jul 02, 2009 | Kitchen Appliances - Others
Regal-Oster belt conversion possible?
Patti Wilson
Feb 16, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
Belt for Regal 6725 bread maker
Patti Wilson
Mar 23, 2008 | Regal Ware K6725 Kitchen Pro Bread Maker
Kitchen Appliances - Others Logo
139 people viewed this question
Top Regal Ware Kitchen Appliances - Others Experts
Irene Tulloch
Are you a Regal Ware Kitchen Appliances - Other Expert? Answer questions, earn points and help others
