Question about GE WBSE2090A Top Load Washer
Final agitation and spin do not happen, timer does not stop
Model: WHDSR209D1WW, top loading. In all washing type (casual, dark, permanent press), the final agigation and spin do not happen. I have removed the front cover and verified that agitation and spin take place in earlier phases. The tub gets filled in and drained as usual. Another symptom is that the timer does not stop at the end of a cycle - it should get pulled in and stop rotating to the next type of wash cycle, but the knob stays 'out' and keeps on rotating. So the washer is washing alright, leaves clothes very soggy. My very minimal knowledge is suggesting it is a bad timer, but it seems this part gets blamed too often. Please help. Thanks a lot.
    Problem Solver:
  • 6 Answers
Check your knob and sleve on the timer to see if they are the right ones or if they line up. if they doit might be the pin in side the timer.or it might be faulty. another suggestiion is check everything out twice. good luck
Posted on Feb 11, 2008
I have an old Maytag top load washer. It just started cycling through all the wash cycles. It doesnt stop. Wash a regular load. went back and it was just starting a fill on the permanent press cycle. I am...
you probably have a bad timer which can be replaced by taking the screws out of the top of the console and pulling the console towards you. the timer should stop after final rinse spin cycle.
Sep 17, 2009 | Washing Machines
Washer Stops Mid-cycle
HI. this is a defective timer mechanism. it must be replaced asap, if possible. the timer is the principal initiator of the units cycles. The motor is defective at this point.
Replace this damaged timer control device asap.
Aug 20, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series 110 washer won't drain or spin, but agitates
You have a broken lid switch. Check to see if the switch is broken off of the two screws that hold it under the lid. If it is, get a new one, take off the case and replace old switch with the new one.
Apr 06, 2009 | Kenmore 24932 Top Load Washer
GE TOP LOAD WASHER DOES NOT AGITATE OR SPIN
ck lid switch can be acessed by pressing clips at front edge of front anel and pulling panel off
Nov 20, 2008 | GE WWSE5200B Top Load Washer
Whirlpool top Loading washing machine won't spin on spin cycle
If the washer won't finish a spin cycle, it probably means that your timer went bad or stalled. You can take the control panel off and look at the contacts for scorching or corrosion.
Sep 21, 2008 | Whirlpool LCE4332P 2.1 cu. ft. Top Loading...
Whirlpool Two Speed Automatic Top Load Washer. Problem:Won`t drain or spin. Will go thru the wash cycle, and then stops with no thurver sounds from motor.The lid switch seems OK with clicking sound...
I would start with a timer replacement, since the motor circuit works for fill and agitate.
Question if you want to repair or replace washer, cost vs age, useage, etc. etc.
Jul 16, 2008 | Whirlpool Washing Machines
GE WBSE2090A Top Load Washer Logo
129 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
