Question about Sony CMT-EX1 CD Shelf System
Cd stuck listened to cd, left it in, listened to radio, left alone for a while. Now I can't get the load/unload mechanism to work? It's a few years old and I can't see a way of forcing it to work. Any ideas?
My 2000 Audi A6 CD changer doesn't eject the magazine and I also can't select different modes on the radio can you please assist me
  • The magazine will not eject if a CD is stuck in transit loading or unloading
  • Radio operation is disabled while the magazine is stuck
May 12, 2018 | Car Audio & Video
CD changer in my 1998 Saab Estate will not eject? Anyone?
You may have a CD stuck part way between the player mechanism and the magazine. You can try loading and unloading several times to correct the problem but in some cases the only cure is disassembly
Oct 24, 2012 | Car Audio & Video
Saab cd changer
You may have a CD stuck between the player mechanism and the magazine. You can try loading and unloading several times to correct the problem but eventually you may have to resort to disassembly to get the CD back into the magazine
Oct 24, 2012 | Honda Auto Changer Board
2000 Buick Century. Put in a replacement radio/cd/casset player. Radio works, clock works, but CD and casset do not. The message comes up E 13. What does this e code mean?
if its a radio shack radio, it means E13 means "Tape Communication Error". It is caused by the
microprocessor reading speed pulses from the tape deck either too fast, most other makes mean about the same thing, normally a stuck tape will cause this code to show up, either that or the drive gear that loads and unloads the tape is broken, cracked, or jammed
Sep 26, 2011 | 2000 Buick Century
Radio stopped working properly! Pontiac G6, 2006, 6 cylinder.
The CD load/unload mechanism appears to be malfunctioning.You have to take the radio out and see if you can manually remove the disc or pick up a used radio from the scrap yard
Dec 24, 2017 | 2006 Pontiac G6
Some cd's wont load
Currently I have one that won't load or unload.
That problem is a slipping drive belt. It is a small square profile belt near the front left of the machine. There is not enough tension and the motor spins its pulley inside the belt. The mechanism it drives is the load and eject function.
Feb 23, 2010 | Stanton C314 Tabletop CD and Mp3 Player
Code 99
e-99 indicates that there is some type of mechanical jam, the microprocessor requires reset, or the system had some major failure. try to remove power from the system for a few moments, and then reconnect. this will rest the microprocessor and possibly restore function. if there's a disc stuck in the magazine, or stuck somewhere in the loading or unloading sequence, it's sometimes possible to free this but the changer will have to be removed from the vehicle and partially disassembled.
Jan 17, 2010 | Sony CDX-540RF 10-Disc CD Changer
Cd player reads err on display
internal problem in radio,you would have to take it to a dealer to send out for you,
Jan 01, 2010 | 2000 Chrysler 300M
05 Ford F150 Radio doesn't work.
I had the same problem and i brought a new ford oem cd player 2 times and my mechanic says its an electrical problem with some fords not the Cd player or the radio. So your cd player may not be junk, it may be electrical or wiring problem.
May 25, 2009 | 2005 Ford F-150
Sony CMT-EX1 CD Shelf System Logo
61 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
