Seal is good. when shutting, door on produce side. slightly opens up. not keeping a good seal. no suction. freezer is ok.
There is no suction normally. The door has a spring type mechanism to keep it firmly closed, and the magnetic seal takes up the slack. Check the door/ hinge is straight and tight and look at the top of the hinge. There is a small cylinder about 5mm high with a number of dimples in it. One of these should have a pin in it that operates the spring mechanism; if it is missing the door will not close well.
Also make sure there is nothing in the fridge protruding, stopping the door from closing and the seal sticking!
SOURCE: Freezer Door Popping Open
Look at the bottom of the freezer door, there is a little plastic stopper there. It may be worn out or broken. When you close the door this is what holds it there. Start there first.
Sgt 48
SOURCE: Amana 22 side-by-side refrigerator, freezer door opens slightly
There are three possibilities to this problem:
1. Door seal which should be magnetic is faulty.
2. Ice maker caddy (container) has not socketed properly into ice maker rear drive tang.
3. Door stay closed plastic hing pieces are damaged. These are tapered pieces that fit in hinge area that allow door weight to help close and hold door. Some are black in color and some are white. As far as I know they are interchangeable.
SOURCE: refrigerator side not sealing tightly when shut.
Sounds like you may need a new magnetic seal. It is worth the money to fix it, saving electric and your food items.
Good Luck
SOURCE: GE Profile freezer door problem
I wil let you know of things you can do to solve this.
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
Hope this helps, Thanks Sea Breeze
