Engine revs up an dwn
SOURCE: vauxhall astra horn
The problem is in the loom in the steering wheel, it requires removal of the airbag and a new wheel loom to be fitted. The loom costs about £15.00 I think.
SOURCE: my vauxhall astra engine is reving on its own at
have you had it on diagnostic machine cos i did with mine and ended up being the EGR valve?
SOURCE: Instrument panel on my vauxhall astra does not work
i think vauxhall used the canbust system on this car and you cant cut into the wiring m8 you can buy a repair kit from internet but it might be expensive
SOURCE: Vauxhall astra 1.4 16v Idles fine but will not rev
Some cars with an ecu have a default setting whereby they run but only at idle. Go to your local Vauxhall dealer, look sweet and ask the service people if they can offer any idea, I mean the mechanics not the counter staff who generally don't know a handbrake from a halfshaft.
Or go on line and scour the astra owners helplines to see if its a common problem.
Don't spend a penny in a garage without checking all possible areas first. Like the other answer, it may just be a cable or electrical plug come off.
