Question about JBL PB12 Subwoofer
Sub freaking out! :-(
My JBL PB12 suddenly started flickering on and off repetitively. Oddly enough, it seems to do it with the bass line. We've never had a problem out of it before - always gotten exceptional bass but now, after 3-4 years, it started this. The lights on the front will flash from green to red and the bass won't make it through. You can trick it by leaving it off for awhile and turning it back on but it will only work for a moment. I have tried changing the power cord, the a/v inputs, all the settings, EVERYTHING but I cannot figure it out. Please help!! :-) Thanks!
  • Arienne Wyatt Jan 19, 2007
    HA!! This is what JBL customer support said (in 2 different e-mails)
    E-mail #1:
    Good afternoon and thank you for your inquiry. I can understand your
    concern. It's possible the power amp may be the issue. Depending on
    the serial number of your sub, it's possible it cannot be repaired.
    Unfortunately, if your serial number begins with "AM" or a number, it
    cannot be serviced. The company that manufactures the amplifier
    assembly's main Power Amp Module is no longer in business. Because of
    this, they are no longer able to supply us with the main part of the
    amplifier assembly. However, if your serial number begins with a "HA"
    it can be serviced. If this is the case, please reply to this email
    with your zip code and I can locate the nearest service center in your
    area.
    The serial number is printed on a white label on the back of the
    subwoofer near the ac cord.
    I hope this helps.
    Best Regards,
    Vu Le
    Internet Support Specialist
    E-mail #2 (after I prodded for more information on the exact problem):
    The issue could be the power amp itself. However, it is very hard to
    tell what the actual problem is without physically testing the unit.
    It's possible the issue can also be with a small resistor.
    I hope this helps.
    Best Regards,
    Vu Le
    When I called the service center, it's going to be $50 just for them to take it in the door and if it's the amp, which it most likely is, it will be $65/hr labor plus parts. I'm probably going to replace the amp myself (you can order replacements pretty cheap).
    GOOD LUCK!!
  • 3 Answers
Exactly......I bought a Klipsh
Posted on Oct 31, 2007
JBL pb 10 sub keeps going into standby mode
Did the same fix as Bratcop on my PB10 with the 7.2 amp board. Replaced C42 and it seemed to fix the issue of rapidly switching in and out of standby mode.
Jan 21, 2014 | JBL PB10 Subwoofer
JBL PB12 will have loud thump or pop!
First try to find the source of your problem. The easiest way would be to try your sub with a different audio source to see if the problem still occurs but is sounds more like there's a problem with the receiver.
Oct 18, 2012 | JBL PB12 Subwoofer
I need a new power amp for a JBL PB12 Subwoofer
Alf, when there is no parts available you have to start looking at local non authorized repair shops that will inspect and repair the board instead of trying to source a replacement board.
This can be very difficult and could make for alot of expensive deposits. Running out of parts is an ongoing problem with all electronics and sometimes replacement is the most cost effective option.
Cheers,
Kevin
Feb 09, 2010 | JBL PB12 Subwoofer
I have a JBL PB12 sub, no power - prev wrenching sound on startup
these a internal power control board defective, send to repair
Jan 17, 2010 | JBL PB12 Subwoofer
I purchased a JBL PB12 (120v) subwoofer from a friend. It worked excellent for a month or so, but completely went on the fritz yesterday. Whenever I turn it on, I get a loud whining noise, that starts high...
It sounds like something on your main board of your amp is going out. It is most likely the finals, or as you said a capacitor. Test the port with another speaker, if al is well then the wooferis bad. if not you will have to go inside the amp for repair. Depending on the brand it can be a little complicated. Try and narror it down to the proper componet, post back the results and we will go from there. Also is this sound comming from all channels or just the woofer?
Sep 28, 2009 | JBL PB12 Subwoofer
Pb12 makes thumping sound after warming up
Hello there..Thats normal only if your sub volume and the pre amp is turned up..Your amp is the cause of the speaker jump..Turn amp volume sub level down a few and check your wire from sub to amp..If all of that is good is a normal operation for pre amp warm up in sub if level is turn to max..Try unplugging amp freom sub then turn sub on stand alone(just sub outlet plugged in and no wires from base amp plugged in..If sub stops the its the amp making the problem..If it still is there then the pre amp is either dusty on inside or the outlet plug that it is plugged in doesnt have a good ground..Hope these help to solve your problem..Have a great day...
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
Apr 02, 2009 | JBL PB12 Subwoofer
Fuses keep blowing
This particular product has a lot of comments posted on it and I've answered a few of them now so I'm beginning to think you may want to look into weather or not the manufacturer has received any complaints or this is just a freak occurrence. Keep in mind not all commments are the same so this may just be nothing. Either way I can tell you this much, if fuses keep blowing quickly, over and over again-You have a direct short somewhere and will most likely be in need of professional assistance of some sort with the possiblilty of having to replace it. I'm sorry it's not an easier fix but it may not be too expensive.
-Dynami
Mar 22, 2009 | JBL PB12 Subwoofer
Jbl PB12 powered sub woofer
if your serial number starts with ha then it's probably a bad capacitor C72 . 6.8uf 100v np electrolytic. replace it with a higher voltage capacitor of the same value.
Mar 10, 2007 | JBL PB12 Subwoofer
JBL PB12 Subwoofer Logo
456 people viewed this question
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
