Tures on with apple logo them go to red x in a circel and then gos blacks
For now my suggestion is: Again, try to Restore from Disk Mode. If that doesn't work you may need a repair. Do the reset, then after the screen flickers to the gray Apple logo; let go of both buttons and then quickly press and hold the center and play/pause buttons. You should see a black check mark on the iPod screen. Plug it in and restore.
SOURCE: apple ipod keeps flashing apple
if u hav already sorted the problem ignore this
when your ipod stops flashing the apple hold menue+select then as soon as the apple starts flashing again hold select+play/pause for several seconds a white screen should appear, if this happens connect it to ur pc ur i tunes should then reconise ur ipod, u should then restore it
SOURCE: ipod touch can not boot.It show apple logo
Hope u have back-up...Do a reset..soft one ....
hope it helps...keep the hope:)
SOURCE: ipod troubles
Put the switch on hold then unhold it
now press the center and the menu button simultaneously for about 6 seconds
till the apple sign appears.
SOURCE: Apple iPod video 30 gb black will not start
Yes, this happens to me as well. However, it's only when the ipod has no battery life left at all. The only solution I have for myself is that I cannot plug it into the wall when it has completely died. It HAS to be plugged into the computer, that's the only way it will charge when it has reached that point. I'm pretty sure, but not completely sure, that it has to do with the battery. I'm planning on buying a new battery off ebay and installing it, just to see if this fixes anything. Hope this helps!
--Sarah :]
SOURCE: my ipod 120gb ipod classic does nothing but show
When the Apple Logo is stuck
If this happens, put the iPod into Disk Mode through the diagnostic menue. Then connedct the iPod to your computer and update or restore the iPod.
Sometimes you can get away with just updating the iPod, so try that first, but usually you have to restore the iPod .
As always make backups of your music files, because the restore procedure will eliminate them.
Good Luck,
I hope this helps
ipod red X. In test mode stops at detect test what dose yhat meane
