Mower was driving fine until ran across stick, now still runs but won't go forward or back.
SOURCE: john deere x340 wont move
there is a release usually behind the seat that has to be pulled in order to push it physically. make sure that the release is pushed in for the forward/reverse to work.
SOURCE: I have a John Deere GT225. The hydrostatic drive
sounds like your linkage is disconnected, With the tractor off raise the seat and back panel (if possible) and work the shift and look for failing linkage.
SOURCE: john deere runs then stops
I fixed my mower stalling issues on the L111 by loosening the gas cap. I ultimately drilled a hole in the gas cap and screened the hole. Sounds ridiculous but without that venting the engine would run approximately 20 mins and die. It was also much more difficult to start the next time. Something else to pass along to whomever might view this... I replaced the cranking battery with a battery that had allot more cranking amps and I no longer had hard start issues ( this was after I vented the gas cap). Hope this helps.
SOURCE: John Deere GX85 Riding Mower engine surges
did you drain the gas before putting it away last season? If not, I would drain all of the gas and put in fresh gas, also replace any in line gas filters
