Question about Hotpoint Washing Machines
I have a hotpoint washer/dryer - Aquarius 1100 and the powder is not being taken from the drawer
  • 135 Answers
This is usually caused by a poor feed to the hot water valve.
Posted on Nov 14, 2008
Hi, my hotpoint Aquarius 1100 washer dryer keeps leaving the soap from washes in the drawer. Any ideas why? Thanks
Try removing the draw and cleaning it thoroughly i would recommend running a few hot washers with no powder through the machine too.
Thankswww.TalkAppliance.co.uk
Apr 24, 2012 | Hotpoint Washing Machines
How do I remove the powder draw from the aquarius wml520, please?
1. Extend the dispenser drawer until the stop is reached.
2. Press the locking tab located in the centre rear of the drawer and pull the drawer out.
Mar 19, 2010 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint Aquarius 1100 WM63 Not Spinning Clicking Programmer
I would suggest you check the brushes in the motor, as it sounds like they are worn out.
Replace them if they are less than 3 or 4 mm long
This would give you the symptoms you are describing.
Please rate my solution.
Thankyou.
Feb 09, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Can this machine heat its own water? It has a hot and cold water intake. also mashing machine is not taking the powder from the powder drawer. Can you help?
Yes, this washer does have a heating element.
Make sure there is a good water pressure at the inlet valve/s,
or the powder will not dispense.
Make sure there is no blockage or obstruction in the drawer, \also make sure you have the powader in the correct compartment.
Hope this helps.
Dec 20, 2009 | Hotpoint Aquarius WD640 Front Load...
Machine not taken away the comfort but taken away the wshing powder
The fabric conditioner syphon tube is blocked up.To clean, do the following.
Depress the plastic clip situated towards the rear of soap drawer, this will let you pull the drawer out altogether.
Thoroughly clean all parts of the drawer, remove the plastic insert in the condtioner compartment, and get a piece of thin wire or simliar, and poke the sypon tube clear, then run water through it, fit back drawer, and it should be o.k.
Trust this helps.
Dec 01, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
How to remove the drawer on the wmd960
pull the draw out as far as it will go, there is a blue tag in the middle to the back of the draw, push this down and pull the draw all the way out
Jun 09, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius
hi..the reason for this problem is the powder drawer
could have got struck.The pin that is attached to the
tray could have got strucked somewhere.u dont try to
pull it.please call your mechanic to do this job.
try this out..
thank u..
rate me..
Feb 09, 2009 | Hotpoint Aquarius WD640 Front Load...
Powder drawer wont open
Grasp the drawer firmly, and pull out until it reaches its stop, then press the plastic lever down in the middle of the drawer at the rear, and pull the drawer out.
Please rate my fixya solution.
Thanks.
Soap powder remains in the soap compartment
Depending on which compartment the powder is remaining in, it could be low water pressure causing the problem.
If it is taking some down, but not all the powder, then try putting the powder towards the front of the compartment.
If all else fails then I suggest you get one of these dispenser balls that you put straight in the drum with the washing.
Plz rate this solution.
thanks.
Dec 28, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
90 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
