Question about RCA P60920BL 60" Rear Projection Television
Home theater My set will come on at random and switch channels.the only way to stop it is to unplug it.It also has a guide plus feature.
  • 61 Answers
The front pannel,on and off channels and vol. switches are going bad,if you dont use the front pannel, unplug the set and remove the back cover,just below the top screws you can look under and see the top of the picture tubes,in front of the middle tube is a little board about two inches wide and four inches long,unplug the right plug it has one black and five or so white wires,this is the top cable,then just use your remote.
Posted on Mar 04, 2008
Why does my 52" RCA randomly go through menu and features and I can't stop it?
That is why you got it for free. Lot worse if you paid for it!
Circuit board responsible for remote operation and menus is fubar.
Apr 30, 2017 | Televison & Video
What is the time delay switch for on a sa 5760 receiver
Hi,here is the basic info for your question..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Surround Sound System Settings ---- Correct Time Delay Setting in Multi-channel Audio
A correctly set surround sound system can yield dramatic improvements to your
home theater sound or multi-channel music listening experience. In particular,
a correctly set time delay setting between the different channels is essential
for a realistic and unified surround soundfield.
Luckily, most of today's surround processors make setting the time delays
between the rear and the fronts a matter of a few entries in the setup menu.
Yet having a proper understanding of the principles behind correct time delay
settings is essential for the best results.
In this guide, we explain the principles behind time delay settings in surround
sound and show you how to adjust your surround processor or AV receiver for the
best surround sound field.
Time Delay Setting in Multi-channel Surround Sound Systems
Correct home theater speaker placement and properly balanced sound levels
between the different channels in multi-channel audio, while crucial, are not
enough to sustain a unified soundfield in a surround sound setup. A correctly
set surround sound system requires that sound from all the different speakers
reach the listener at exactly the same instant.
This explains why all fronts, left, right and center channel speakers, should
be set at exactly the same distance from the listening position. At the same
time, in a typical home theater setup, the surround speakers are closer to the
viewer than the fronts.
To compensate for this distance discrepancy, surround sound playback systems
apply a split-second delay to the surround sound channels.
Jun 22, 2011 | Technics Audio Players & Recorders
I have Philips DVDR7260H recorder where the guide plus system will not set up. I have done as insructed on automatic and with manual setting with host channel set to bid up tv channel 23with no lck . C...
Firstly, my DVDR7260 (so I guess yours too) can only use analogue channel updates so it should be set to ITV, that is channel 03 (if you have usual analogue channels tuned). BUT by now that suggestion is redundant as Guide Plus updates have been stopped since 1st Jan 2011 as part of the Digital switch-over. Nice one! If anyone knows how to invoke the Freeview EPG on the DVDR7260, that may be the one thing to keep it out of the bin.
Dec 15, 2010 | Televison & Video
RCA Home Theater Premiere 36" TV comes on automatically
Only two possible reasons I can think of for this--
ONE: you have looked in the customer menu and there is no item listed as Timer?
TWO: Does THIS SET HAVE THE GUIDE PLUS LOGO ON THE FRONT OF THE SET? IF IT HAS THE GUIDE PLUS--YOU WILL FIND IT IN THE MENU ALSO---
LET me know if it has the guide plus feature and I can tell you how to end the problem--most of these the set will come on at the same odd time and usually with volume up high.
SD TECH
Dec 26, 2009 | RCA P52937 52" Rear Projection Television
Remote control ceased functions to RCA Home Theater Guide Plus
Frist of all your main problem is that you have a rca. You probley have some bad capastors that have lost there value. You probley will have to take to a shop for repair.
Mar 05, 2009 | RCA F32648 32" TV
DJM 909 button isnt using desired feature
Yes. You need a new micro switch. I had to get both of mine replaced for the same reason.
Nov 01, 2008 | Pioneer Djm-909 DJ Performance Mixer with...
Rca f36648 & rca HOME THEATER
Have you tried just hoooking up the DVD player by itself? Is the DVD player output setting correct? Also, make sure the "video input" is set for the correct channel that you are viewing (i.e. Channel 3).
Jul 31, 2008 | RCA F36648 36" TV
Panasonic DVD player problems - switches to
get the dvd player len cleaned using a len cleaner.
are you operating the unit with the remote when find the mentioned issue try manually.
Jul 31, 2008 | Audio Players & Recorders
Rca guide plus gold 32'
pull the ac plug for about 5 min and start your set up again paying atention to the features you want and don;t.set the menu to suite your requirements.
Jan 16, 2008 | RCA 32F531T 32" TV
Mitsubishi CS-32509 TV
Unplug the TV for 4 hours or more. This is called a 'Hard Reset'. Then plug it back in, turn it on and let the TV do it's thing. It will set itself up. Just follow the TV setup prompts. Guide Plus is a feature on the TV. Much like a TV guide showing all channels, shows, description of shows, times, etc..
Jun 30, 2007 | Mitsubishi CS-32509 TV
Televison & Video Logo
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
