Question about Welding Tools
Welder not charging battery
Cant find alternator
  • 169 Answers
Most engine driven welders have the charge armature located underneath the flywheel of the engine, but you need to check a couple of other things before you start tearing down the engine. Look for a small rectangular module on the blower housing of the engine, on a Kohler this is at the side, on an Onan it's at the top. This is the rectifier/charger module and it will have 3 wires, the 2 on the outside will be the AC from the armature, and the middle one is the battery charge positive. With the engine not running, use a DC voltmeter to measure the voltage between this middle tab and the engine block, you should see a voltage that's very nearly equal to the battery voltage. If you don't see a voltage there you may have either a blown fuse, a tripped circuit breaker, or a broken wire leading to the battery. On some welders the fuse or circut breaker is inside the welder cabinet on the bulkhead between the engine and the generator parts of the welder.
If you did see battery voltage at the charge terminal, start the engine, switch the voltmeter to measure AC voltage and measaure the voltage from one of the outside terminals to the other, you should see 15 volts or more (be careful not to short out anything). If you get a nice AC voltage, switch back to DC and measure the charge output again (engine block to middle tab), it should be greater than the battery voltage we measured before and it should be slowly getting greater, if not the rectifier/charger module is bad.
If you didn't see enough AC going into the module, stop the engine, disconnect the plug from the module and use an ohm meter to measure the resistance between the 2 outside wires that go back to the engine, something between 100 and 1500 ohms is good. If you measure an open circiut (OL on my meter) or if you measure 0 ohms, the armature is probably bad. You have to take the flywheel off the engine to see the armature. If you got a good restance reading but the voltage is still low you may have one or more broken magnets inside the flywheel, again you have to do some serious disassembly to see if that's the case.
Posted on Nov 29, 2008
    New Friend:
There is no Alternator. The welder is a big generator. The welder uses the battery for stored energy to start the engine which in turn spends the generator. By use of a voltage regulator the 115 volt plugs on the welder work and the battery is recharged. If you find that the welder will not start and the toggle switch wiil not work properly, its probably the voltage regulator. Check the battery first, then move on to the regulator. Chasing parts start with Kohler or with the engine type you may have. Get the model number and serial number off of the fly wheel cover. Good Luck
Posted on Feb 16, 2013
I have a 2001 acura cl type s n my alternator wont charge my battery cant find the fuse or relay?
With charge up battery max voltage from alternator should be 14.4 volt check if you got battery voltage on the alternator therminal in the back of your alternator if you got the same voltage as your battery your alternator is no good you need to change your alternator if you put 1 in dont forget your battery need to be full charge
Mar 25, 2015 | Acura CL Cars & Trucks
My Truck starts and runs, but the lights dim quickly even when running.
Have some one check the charging system for output. Have them check for voltage drops in the battery cables and the charging circuit.
Oct 24, 2014 | 1999 Nissan Frontier
Does a miller 225 charge off of the flywheel or does it have and alternator?
Flywheel. Check for AC voltage on the two outside wires of the voltage regulator with it running. At fast speed, should be 30-40 volts ac. It that is there, then check dc voltage on battery, which should be close to 14 volts dc.
Aug 25, 2014 | Welding Tools
Where is voltage regulator
You don't say what kind of welding you had done or where but I can tell you that if it was a MIG welder or an ARC welder and they didn't take the appropriate precautions this could very well messed your car up and ruined the ECU.Your alternator should be charging from 13.2 to 14 volts.Check the ground on the battery to make sure you have a good circuit. The fact that the car will start is a good thing.I would go looking for a bad connection or wire controlling the gauges.The voltage regulator is in the alternator,it controls volts output. I'm jumping around here a bit but I empathize with you in a big way.Go back and double check everything.There must be a fuse to the instrument cluster,or perhaps a bad wire. good luck
May 06, 2014 | Nissan Almera Cars & Trucks
Why will it not charge the onboard battery
do you have a clean connection on the battery terminals?
Feb 20, 2014 | Bobcat Miller 225 Welder Generator 907209...
2000windstar havenew and good battery and new agood altanater wont charge
If the alternator was not charging before you replaced it, the problem could be a bad connection between the battery and alternator, or a problem with the computer.
The computer controls alternator output.
Apr 12, 2013 | Ford Cars & Trucks
Battery alternator visit workshop is flashing on
MERCEDES C200 Kompressor 2001. battery alternator visit workshop is flashing on trip computer. i have replaced alternator. everything is ok. battery getting charge... i cant see any thing wrong so why workshop flashing?? maybe something wrong with new alternator 4 exampel voltage sensor??
Jan 02, 2010 | 2003 Volkswagen Passat
Charging problem.. Wont charge battery
The instructions for installing a new alternator usually read to fully charge the battery (12.3 - 12.8 volt range). Otherwise, the alternator will be damaged when it initializes. I have seen some extreme damage result from installing a new alternator with a low-charge battery. The torque required to turn an alternator when damaged in this scenario is unbelieveable!
May 02, 2009 | Honda Accord Cars & Trucks
Welding Tools Logo
1,033 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
