Question about Canon Office Equipment & Supplies
Canon Image Class D340 Printer... Copies come out very black like muddy. Image is there but almost invisib le. A low toner has been sugested to me, but I hate to buy a cartridge and not get a fix out of it...
  • 1 more comment
  • Parentejr Nov 14, 2008
    The machine seems to be ok otherwise. I've tried all the settings availablel but unable to get a clean copy. Is it possible that a low toner is my problem.?
  • Parentejr Nov 15, 2008
    Not the answer I wanted, but I have allready ordered the cartridge since it seemed to be the only logical way to a solution. Thanks anyhow////
    Thanks for coming back with some new ideas. I'm hoping the toner cartridge will do the trick. I have already tried all the adjustments that the machine alows. I hope it's not some of that other stuff you mentioned because I read the instructions about how to clean the scanner and it didn't make any sense to me. If this cartridge doesn't work I may have to learn how to clean these other parts...Thanks a lot.
  • Canon Master
  • 1,879 Answers
Got this from Canon's website to back-up our suggestions here.
Issue: Copies, scans or sent faxes are completely black or have large vertical stripes
Solution: Replace the toner cartridge
Replace the toner cartridge.
Posted on Nov 14, 2008
  • 103 Answers
Even I would have suggested a new cartdridge....Its supposed to fix your problem...and make the images more visible,,,,use your printer utility to check for the ink level...
  • 1,183 Answers
Could you tell the the age of the toner you are using ? A noramal tonner last 3000 pages or 1 year
Thanks
proton
  • Canon Master
  • 19,396 Answers
Try first lowering brightness in print settings. |If this does not work you need to buy a cartridge, at least to test it.
  • Ginko
    Ginko Nov 15, 2008
    It is possible that the toner is the problem, particularly if the toner is not an original replacement.
    Dark copies ralso caused by a defective scanner lamp.
    A dirty glass or mirror.
    Settings, in this case adjust exposure manually. And check that the machin is not set on
    automatic exposure, adjust the brightness/exposure manually.
    In any case it is necessary to test a new toner first, to understand if the toner (as often happens ) is the core of the problem.
    If it is not the toner, second common reason is a bad lamp.
    Check also if the glass and the scanner mirror are clean.
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Canon imageclass d340 making a loud clicking sound
It sounds like you may have sheared a gear tooth off the roller drive or the traversing mechanism. If you are getting copies just leave it alone.
Oct 12, 2016 | Canon imageCLASS D340 All-In-One Laser...
Blank page printing from canon image class mf4412
Could be many things. Check the drum make sure its turning ,or the corrona wire . this is in the toner cartrage.
Oct 30, 2013 | Canon ImageClass MF4412 Toner Black Repl -...
Helloi need toner for canon copier model PCD340 please let me know the model which will fit in this copier ?
Have you looked at the toner in it now for a model/part number? Have you checked the owner's manual in the list of consumables? That is where they will list it.
A simple Google search of PC-D340 toner brought up many results, showing S35 as the toner for it. Here's a listing on Amazon for around $30 for one
http://www.amazon.com/Compatible-Cartridge-ImageCLASS-PC-D320-PC-D340/dp/B0038ZSPM4
Jun 22, 2010 | Canon PC-D340 Black and White Copier
Our copies are streaky like the drum is not clean.... help! There is black streaks on the top of all of our copies on our canon imagerunner 3300.
A) Black Streaks, Shadows, And Ghosting
Adjust the printer's lightness/darkness setting to 2-3 different variables and see if problem disappears. Look at the fusing assembly - is the roller torn or does it have any black buildup? Use caution!!! It gets HOT!
Try another toner also.
Feb 17, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
D880 printer won't put toner on the paper (prints blank)
make sure the replaced toner is in good condition and is placed properly in printer refilled toner often alarm about low ink but work properly
Jul 22, 2009 | Canon imageCLASS D880 All-In-One Laser...
Copies are blank pages and doesn't indicate toner problem.
Bad lasrer shutter. There is a redesigned one going in warranty claim machines. the shutter can be removed but it breaks safty laws.
Apr 22, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Canon Image Class D320 does not copy entire page. New toner has been installed.
Has anyone changed the paper size in the paper tray to another size by accident? Have you tried the manual feed tray? If that copies the whole image then the problem is with the paper size input of the paper tray.
Apr 15, 2009 | Canon imageCLASS D320 Digital Copier
Black streaks
This is caused by a rotating part that is contaminated, most likely the drum that transfers the toner to paper.
A new drum or drum cartridge is probably needed.
There is a very remote chance that the high voltage that charges the drum is being modulated but I have seen this once in decades of service.
Aug 15, 2008 | Canon imageCLASS D320 All-In-One Laser...
Canon IR 3100 error code (E000020-0081)
error code E00020-0081 my canon printer IRC3170i.what is the problem?Anybody can help?
Feb 19, 2008 | Office Equipment & Supplies
19 people viewed this question
old marine
old marine
